Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Water is leaking into the refrigerator from the freezer also the bottom of the freezer is icing up
  • Whirlpool Master
  • 43,501 Answers
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from Freezerwater is leaking into the refrigerator from the - 2_bing.gif
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Jun 01, 2010
Ice forming on bottom of freezer with water leaking out from under
I'm guessing the drain from the freezer defrost pan (below the freezer coil) is clogged and overflowing into the bottom of the box. You'll have to turn off an defrost the freezer, then remove the sheet metal on the back to expose the coil. Try pouring some water into the drain pan and if it backs up, use a fine wire like a sewer snake to clean it out.
Feb 28, 2018 | Maytag MBF2256H Bottom Freezer...
Water leaking into bottom of refrigerator section
Make sure you dry everything in the freezer when you have the door open and remove ice. It won't be a leak it will simply be the warm air inside the freezer that has turned into condensation. Double check the seal around the door to see if it curled up as that could be letting warm in and cold out giving same results.
Mar 02, 2012 | GE Profile PFSS6PKX Bottom Freezer French...
Freezer leak, Ice inside the freezer (AMADA ARB220ZC)
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
heatman101
Jul 08, 2010 | Amana ARB220ZC Bottom Freezer Refrigerator
Water leaking from under the freezer
Until defrosting the block of ice you canot see if is a hole or crack in the bottom. But I suppose is leaking from the door gasket under the pressure of the ice inside. Anyway, if you want to keep alife your refrigerator, better unplug it, defrosting and clean it before complete annihilation.
Sep 10, 2017 | Frigidaire Refrigerators
Ice Maker leaks water inside the freezer
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Apr 19, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
Kenmore bottom freezer refrigerate leaks
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Aug 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
May 19, 2009 | GE Profile Stainless Bottom-Freezer...
Water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Apr 18, 2009 | Refrigerators
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Water collects in bottom of freezer forming ice which leaks.
your drain hole is frozen over u need to unthaw with a steamer
Mar 18, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
