Paper Feed Problem Sharp AL-1461CS
The automatic feeder won't take paper at all. I see the little gate open up, but the rollers just squeal. After calling Sharp they want me to send the copier/scanner to the warehouse for repair - I'd rather not. Do you have any suggestions?
  • 1 more comment
  • LadyBrid Apr 08, 2008
    Oop,s the model is AL-1641CS not 1461.
    Cleaning the rollers used to work for me, but not this time.
    Model No. is actually AL-1641CS - sorry for the mixup.
    The top roller is not spinning at all.
    Genius:
  • 3,422 Answers
HI,
It is a paper jam problem.
Two examples of “false” paper jams are:
  1. The printer is unable to pick up the paper at all, so it never gets out of the tray. Since the paper never reaches the first sensor, the printer thinks there is a paper jam.
  2. Paper successfully passes through the printer, but one of the sensor flags gets stuck and fails to return to its initial position. This makes the printer think that paper is still present at that sensor, once again causing it to display “paper jam.” Be sure to investigate these two possibilities if you don’t find any paper jammed anywhere.
Please CLICK HERE to try out some solutions to fix your problem.
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 08, 2008
  • Priya darshan Apr 08, 2008
    Did you go through the link which i gave you?
  • 4,102 Answers
Hi can you see if the rollers are turning round at all
  • paul proctor Apr 08, 2008
    Hi probably one of the first things you can do and the cheapest is to clean the rubber wheels because if these get to dusty then it wont pick the paper up as it should the best thing to try is using cleaning alcahol on a cue tip and clean all the wheels you can see and then try it again this usually solves the problem your having.
    Also dont think your model number is correct please have another look ok
    hi if the top roller is not working then you need to check for jammed paper as this is the usual cause of the problem failing this then the only other option is to remove casing and check the rollers and make sure nothings come lose or broken but it could just be jammed paper.
    Is their anyway you can try turning the roller this would tell you if its free to turn or not turning at all if its stuck then it could be jammed paper or even the roller needs greasing on the rail although this is less likely.
    If its free to turn and their is no pressure then this would indicate broken or damaged parts.
    Let me know the outcome ok then i can assist you further ok
    Master:
  • 555 Answers
Can you verify the model number as Sharp AL-1461CS?
  • Matt Jurach
    Matt Jurach Apr 08, 2008
    It definitely needs new rollers. You can get your own and replace them here. A service manual is located here.
Paper jams and error P shows up on my sharp al1000 printer
Dear Friend
the paper jam in the machine is due to the rubber feeders present in the tray bin that pick the paper up and forward them.
so i suggest them to take a cloth and dip it in water and then (just like moisturized cloth) resin it completely that it do not form droplets that gets into the copier.
now switch OFF the machine and try wiping the rubber feeders with the cloth.
you will see a lot of darkness on the rubber feeders.
clean all the runner feeders with it and close the machine.
now your problem will be solved for paper jams.
thankyou
Gagan Gupta
Is that Useful?
Mar 18, 2011 | Sharp AL-1000 Laser Printer
The belt inside my scanjet 4200c has come off. How do I reattach it? I have opened the scanner. It looks to be relatively easy but I don't know how to attach the belt to the motor etc
Instructions
1 Lift the hatch on the feed tray and pull up the large green tab to the left of the roller. Remove any jammed or torn paper from under the roller and around the feed tray.
2 Pull the input feed tray out of the automatic document feeder. Grasp the feed tray with both hands and pull it straight out.
3 Check the interior of the automatic document feeder for jammed paper. Remove any jammed paper, then reinsert the feed tray into the automatic document feeder. Push down the feeder cover until you hear a click.
Mar 08, 2011 | HP Scanjet 4200c Flatbed Scanner
Flashing p and paper will not feed it jams
Clean the paper feed roller under paper tray use izopropilic alcool.
Sep 27, 2009 | Sharp AL 1631 Copier
Paper feed roller continuously rolling
The problem lies in the solenoid and or the frame that hold the solenoid so your feeder roller never stop rolling
Jun 08, 2009 | Sharp AL-1000 Laser Printer
There is NO paper jam- and the paper won't feed. We have taken the printer apart- NOTHING hung up- gears are okay- still won' feed paper.
hi...
Most of our printers pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
try it out....
Apr 05, 2009 | Lexmark P4350 All-In-One InkJet Printer
Feeder won't work~~
Hello Sir; I believe just replace paper pick up roller feed roller and stop roller, the problem will be gone!
Jan 27, 2009 | Sharp AL-1551CS Copier
Top paper feed jams
if your feeder is jamming you need the roller & pad replaced and usaaly the internal feed roller cleaned this is a repair that should be done by a sharp tech about a $150
Jun 30, 2008 | Sharp AL 1631 Copier
Top Paper Feed Won't Work
Like a worn running shoes, the paper feed roller of the Automatic Document Feeder (ADF) have lost it's traction and has to be replaced or cleaned. Paper just slids and doesn't picked up properly without that little push. Professional servicers use a cleaner specifically designed for rubber rollers. However, YOU CAN get extra miles on it by dabbing a Q-tip in warm water and cleaning the paper feed roller on the ADF. Like all eletrical devices, the unit has to be turned off and unplugged before working on it. Take all precationary measures and goodluck.
Nov 29, 2007 | Brother MFC-3240C All-In-One InkJet...
The document feeder keeps trying to feed
You have a bad Document transfer sensor. Sensor is located under the doc. transfer roller.
Nov 15, 2006 | Sharp FO 6600 Plain Paper Laser Fax
90 people viewed this question
k24674
