Question about Polaroid TDA-03211C 32 in. LCD HDTV
SMOKE CAME OUT THE BACK OF THE TV AT THE TOP
THE SCREEN WENT BLACK BUT WE STILL HAD SOUND. I PULLED THE PLUG. I AM TRYING TO GET THE BACK OFF SO I CAN SEE WHAT BURNT. I WAS LOOKING FOR A DETAILED MANUAL. THANK YOU FOR ANY HELP YOU MIGHT GIVE.
I have this same exact tv, but the 42" model and it did the same exact thing with my mom. she gave it to me to look at and fix. my friend came over last night and we checked it out and it looks like either a tube or two needs to be replaced or maybe the inverter board needs to be replaced.
turn it on and see if it does anything... turn the lights out with the tv turned on an input and shine a very bright flashlight on the screen to make sure the lcd is still working. if you can see the picture with a flashlight the lcd still works, but the backlight it out and that either means replacing some tubes or replacing the inverter board. keep in touch if you want, like i said, we have the exact same problem it seems my email is cgrif033 at hotmail.com replace the at with @
Posted on Jun 02, 2010
Model 3221. Observed smoke out of the top of TV. Screen went blank, but sound and all other functions are fine. No sign of anything appearing burnt on inside circuit boards.
Where there is smoke be careful---something burned---If you cannot see it voltages will have to begin with be tested and it is possible it happened inside a place where it cannot be seen.
Look down in the area where the smoke was seen--a part or a wire or a plug even may have smoked.
May 27, 2012 | Memorex Televison & Video
I have a 52lb5d lcd tv and i have a black screen i plug my lap top in it then it went blank but i still have sound
I have the same TV and this morning went to turn it on. I have crystal clear sound but a black screen.
Feb 02, 2011 | LG 52LB5D LCD TV
The tv came on then the screen went black but there was still sound for a sec. Now the green light keeps blinking and the tv won't turn
Unplug the tv for 5 minutes, then try this. Keep holding the VOL+ and CH- buttons down while you plug the tv cord back into the wall ac outlet till you get sound and picture for a second or two. You should be able to turn the tv on and off with the power button now. Next turn the power button off and unplug the tv for a few seconds and then plug it back in and turn the power button back on. Watch the screen and see if the sound and picture comes on, best to check in a dark room to see better, if sound stays on and picture comes on a few seconds and back off you have a bad CCFL backlight lamp in the LCD panel. This tv hads (10) CCFL lamps part # RLMPLA029WJN1 cost $15.93 at www.partstore.com or $19.49 at www.encompassparts.com in it and if one is burned out it will not let the tv picture be powered on till it is replaced. To check and replace the CCFL lamp you will have to unplug the ac cord from the tv back and remove 10 screws holding the back on. With back removed unplug the wire plug on the power button circuit at top left side of the black LCD screen trim, remove 4 screws holding the top of black trim, lay speakers off it, and release trim clips, (4) at top and (2) at bottom with a flat screw driver, and lower the trim to unclip the LED circuit board at bottom left side on the trim. With trim removed, at top of LCD panel remove the (2) PC ribbon wire clips with thumb nail by lifting up on it to release the flat PC ribbon wire. Lay the tv back on a soft pillow with screen up, and look on the LCD panel front for and remove the (10) silver screws 1/2" long with an arrow mark beside them. Do not remove any gold colored screws or any without marks. The LCD panel screen can now be lifted off, lift the backlight plastic thin sheeting and thick sheet off to see the CCFL lamps. Plug the ac cord back into the power supply inverter circuit board and plug the power button plug wire back in its circuit board on the LCD black trim panel, and power the tv on while looking at the CCFL lamps. If the lamp is dim or burned out, take the (2) white plastic covers off the ends of the lamps with a flat screw driver and unclip the lamp to replace it, Check the lamp socket part # QSOCFA003WJZZ by putting a good lamp in it and if it lights up the sockets are good and the bad lamp was the problem. If all the CCFL lamps do not light up, unclip the top lamps and move them to differant sockets to the center and the center lamps to the top, if the lamps do not light up, then it is a bad power supply inverter circuit board the ac cord plugs into, part # RUNTKA448WJQZ , cost about $160.00 for new one or less if you buy a used one on www.ebay.com , replace it and the tv should work ok then.
Dec 06, 2010 | Sharp LC-32SB23U 32 in. LCD TV
Screen went black smoke coming from back tv is 2007 according to back sticker still have sound
Smoke = overheating = big short = big failure of a part.
Unplug the tv immediately - you don't want t set your house on fire - and call a repaiman. Since the tv has been smoking then the damage will be extensive - a lot of parts, even entire boards, have been damaged. Te repair will be costly.
Oct 05, 2010 | Element Electronics FLX3210 32 in. LCD TV
I have 2 Polaroid flat screen tvs. The 19
A trip to the dump may be the most cost-effective answer.
Jul 19, 2017 | Televison & Video
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Polaroid TDA-03211C 32 in. LCD HDTV Logo
166 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
