Question about Jenn-Air JES9860 Electric Kitchen Range
Oven will not maintain tempature with what was programmed
Our Jenn Air will not heat the oven up to what we set on the thermasat on.
For example we set the oven to be at 400 degrees but is will only heat up to 325.
    Problem Solver:
  • 13 Answers
You might try calling Sears, or wherever you purchased the oven. Or even an appliance repairman. It sounds like the oven temp needs to be re-calibrated, or buy a thermostat to put inside the oven and follow the temp it says.
Posted on May 31, 2010
My JENN-AIR oven will only heat to 250 degrees.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 06, 2011 | Jenn-Air SCE30600 Slide-In Electric...
Top oven of our white double oven jenn air expressions does not heat. it is about 11 yrs old
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
heatman101
Jan 03, 2011 | Jenn-Air Ovens
My gen air stove does not maintain heat setting. What is the problem?
heatman101
Nov 25, 2010 | Jenn-Air JJW8530C Expressions Collection...
Oven only heats to 150 f regardless what the
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jul 16, 2010 | Jenn-Air JES8850AAS Electric Kitchen Range
I have a jenn air electric downdraft range. The problem is we set it for 350 and bake and it wont reach the the 350 level. It did make it to 300 but that took quite awhile.thank you for any help you can...
heatman101
May 08, 2010 | Jenn-Air JES9860 Electric Kitchen Range
Oven does not maintain a consistent temperature
Is this oven gas or electric? If it is gas then it can be normal to see 30 to 50 degrees difference in tempature. The tempature in a gas oven works on the average tempature. For example: The oven tempature may rise all the way up to 370 degrees. Then the burner will shut off. And then the tempature can drop all the way to 330 degrees. Then take 330 and add that to 370 then divide that number by two and the average tempature will be 350. If your oven is electric then the tempature should be much more consistant but can have a 10 to 15 degree variance. Also the standard oven tempature guage that you put in the oven or even the temp guage built into the oven are not very accurate. We us a Fluke meter with a thermocouple to calibrate an oven. So to check your oven for proper tempature regulation you will first need to let the oven pre-heat for about 15 minutes. Then place the thermocouple in the center of the oven. If the oven is electric the take a temp reading every 5 minutes and average them out. If the oven is gas then you will need to take a temp reading when the tempature reaches it's highest and lowest points. Take at least 5 consectutive readings and average them out. You should get an average within 10 degrees of set temp(350 degrees). If it is off by 35 degrees or less you can usually caluibrate the thermostat back to proper temp. This procedure can be different for each range model. If it is more than 35 degrees off or you are getting irratic readings then the thermostat or thermostat components might need to be replaced.
Mar 16, 2010 | Kitchen Ranges
Our Jenn-Air double oven is 10 yrs old. Will not
There are 3 things that can cause this:
1. Bake or Broil element faulty. The oven cycles these on and off to reach and maintain the average setpoint temperature. If the elements heat poperly during the time they are ON, then they are OK (may be able to see them glow).
2. The temperature sensor probe is faulty. This can cause the oven to think it's hotter than it actually is.
3. The above two causes can be easily diagnosed by a technician with an ohm-meter. If they are both OK, then the problem is in the controller itself. If this is the case you may want to have us repair the controller. We see this fault quite often.
Hope this helps you out.
Regards,
Bruce
www.fixyourboard.com
Oct 10, 2009 | Jenn-Air JJW8230D Electric Double Oven
5 yr old Jenn Air Electric oven won't maintain oven temperature
Technician just left our house with same issue. Jenn-Air had issued a technical bulletin as the temperature probe is mounted directly to the heating element, and measures the heat of the element, not the oven. Their fix is a revised temperature probe that goes at a 90 degree angle away from the heating element.
If your temperature is consistent, just off by a set amount of degrees, there is an adjustment you can make at the control panel.
Mar 09, 2009 | Jenn-Air JJW8130D Electric Single Oven
Jenn Air Microwave M169W will run but not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
zcvzcv
Jan 28, 2009 | Jenn-Air JMC7000 Microwave Oven
Oven doesn't maintain temperature
When an oven doesn't maintain the set temperature, first make sure no one is allowing the heat to escape by opening its door. If not, the oven control either needs to be re-calibrated or replaced. To have the control replaced, call an appliance service person.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air JES9860 Electric Kitchen Range Logo
167 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
