Question about Jenn-Air JGS8850BDS Stainless steel Gas Kitchen Range
Oven flame will not go on. Broiler flame working
Oven flame will not go on. Broiler flame working ok.
    President:
  • 1,430 Answers
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on May 31, 2010
How do I fix broiler that does not burn hot enough to broil. Oven works o.k. Broiler worked last week but now flame is not strong enough.
Make & model? You are talking about flames so I assume it is a gas unit. I would examine the broiler burner, sounds like a problem there.
Nov 29, 2014 | Kitchen Ranges
The oven emits a strong odor of gas the entire time it is in operation?
The oven has 2 igniters. One for the broiler and one for the oven. We had a similar problem but the oven had no flame. The broiler worked fine. If there is no flame than you are going to smell gas since it is not being combusted. The oven igniter is in the bottom of the interior oven. The bottom plate is removable. Since there are openings in the panel sometimes debris falls through and some debris can accumulate.In our case there was some aluminum foil blocking the igniter and a simple cleaning fixed the problem.
Aug 23, 2014 | Electrolux Ovens
Broiler flame becomes weak
check lower broiler for clogs - spider webs etc
Jul 08, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven wont heat broiler wont heat
is this a gas or electric range. If it is gas it sounds like a flame sensor is not working. The oven will try to fire up, but if it does not sence a flame, it will shut off again to keep the range from filling with raw gas. Also the easy one, is the gas turned on?
Aug 31, 2012 | Kitchen Ranges
My broiler stopped working recently. The oven itself works, but the broiler flames are not lighting. I'm thinking it might be a pilot problem.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
fjfj
Sep 26, 2010 | Maytag MGR5780BDS Gas Kitchen Range
I have changed the brners over and thay work fine. But the only thing I could find to change on the oven was in the back.I flipped the orifice but oven smoke3s heavily And flames are too high.
You must remove the oven racks and the base pan inside the oven to access the bake burner gas valve. Using a 1/2 open end wrench you will tighten the orifice on top of the gas valve until the flame is the correct length.
If your model has a top broiler,the broiler gas valve will have to be adjusted also.
Nov 08, 2009 | Kitchen Ranges
Oven and broiler will not come on.
go to www.repairclinic.com enter model number and look for the igniter it seems to me you need to change this part. Note it is very fragile.
May 02, 2009 | Ovens
Oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Dec 20, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Problem with conversion of used Whirlpool Range from NAT to LP
Take a 1/2 inch open end wrench and adjust the orifice on top of the oven gas valve.
Tighten it down until the flame is normal. Blue with white tips.
Nov 14, 2008 | Whirlpool SF325 Gas Kitchen Range
Broiler not workig
The flame maybe not enough try to clean the gas nozzle at back potion of the oven , look for small wire to clean the clug by dust and rust , after cleaning test the flame , the burner will increase in flame .
Dec 24, 2007 | Amana ARGS7650SS Gas Kitchen Range
Jenn-Air JGS8850BDS Stainless steel Gas Kitchen Range Logo
106 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
