Question about GE DWSR463EGWW Electric Dryer
The belt squeaks - GE DWSR463EGWW Electric Dryer
  • 10,319 Answers
Generally the belt does not squeak although the roller the belt rides on does from a dried out roller bearing
It will be time to replace both items
Posted on May 31, 2010
There is a recurring loud squeak from under the hood. What is it?
May be a worn on loose drive belt that squeaks as the engine idle speeds up as you change gear. Spray the belt with WD40 or similar . If this stops the squeak tighten or replace the belt.
Sep 28, 2014 | 2000 Toyota ECHO
97 Buick Park Ave. Non-Ultra. Mileage 200K. Was squeaking at morning cold start for about 5 to 10 min. Replaced Serpentine Belt, belt tensioner, alternator, and PCV Valve. STILL squeaking at cold start....
How's your engine coolant level? If you've got a water pump leaking coolant, your belt will squeak, as the pump will leak the coolant directly onto the belt. You'll see the spray pattern under the hood if it's been going on for a while.
Oct 18, 2013 | 1997 Buick Park Avenue
Squeaking fan belt
fan belts squeak for several reasons 1 incorrect belt for pulley.2 belt running on the botton of the pulley and worn pulleys. To check measure across the top part of the pulley and the widest part (back) of the belt should be the same if not marginally bigger. V belts work best at t5he top of the pulley.If you can see that the pulley is polished at the bottom the belt is slipping and not driving Check if the pulley sides where the belt runs is not stepped from wear. Recheck the tension as new belts stretch slightly. If you have a multi groove pulley check the tension setting. As a last resort CRC make a product that is used to stop belt but it is best to fix the real fault first
Jan 21, 2013 | 2000 Mazda MPV
I have a 1999 dodge durango and the enigne is squeaking, what would be the cause of this?
Many things can make an engine squeak. First you have to determine if it is in fact the engine, a belt or something driven by a belt. I would start by taking the belts off and briefly starting the engine. If it still squeaks you may have a major engine problem. If the squeak is gone you'll have to figure out if it's a belt or something driven by a belt.
Mar 02, 2012 | 1999 Dodge Durango
97 plymouth vourger new belt still squeeks
It sounds like one of your pulleys may be having bearing issues, one way to check this is to go to the parts store and buy some "belt dressing" it is a spray that stops belt squeak. Find a safe spot where you can spray the belt while its moving and only spray the belt. If the belt stops squeaking its just a squeaky belt. If it keeps squeaking then you may have one of your pulleys going bad.
Sometimes pulleys will squeak too if they are just not very lubricated. If the belt dressing works you are good to go, if it doesn't work, go ahead and give the belt area a good spray down avoiding your electrical components. Thanks.
Mar 20, 2011 | Plymouth Grand Voyager Cars & Trucks
Toyota echo 2000 - airconditioner belt squeaking
well the belt could be loose or the compressor may be seized.....or the belt may be old and squealing.
Jun 09, 2009 | 2001 Toyota Echo
05 XL-7 I changed my old belts (with no squeaking) now one of the new belts squeaks loud, mostly in the morning when neighbors can hear and give dirty looks, like "get a new belt you incompetent grease...
Take a bar of soap at touch it on the side of belt when it is running. Becareful!!! or spray some WD40 on it. Should stop it. If not it must be something wrong with whatever it is running. If that is a serpentine belt spray it. Soap is good on v-belts.
Jun 05, 2009 | 2002 Suzuki XL-7
93 Accord belt squeak at start up
worn pulley on the crankshaft will cause belt to squeak.pulley has worn to a point where it become to smooth belt cant grip it while turning so it start slipping making squeaking sound.
May 25, 2009 | 1991 Honda Accord
2000 jgc making squeaking nosies from belt
It is the belt tensioner pulley.
The bearings are worn out. Quite easy and cheap to replace
Jan 30, 2009 | 2000 Jeep Grand Cherokee
2008 Silverado 10,000 miles. 2wd has squeak
it may be the fan belt. The belt may need tightend or need a new one.
Jun 06, 2008 | 2008 Chevrolet Silverado 1500 2WD
GE DWSR463EGWW Electric Dryer Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
