Question about Philips Magnavox 51MP392H Rear Projection Television
I have A 57 inch stand up t.v and it has lost its colorIt is an
It is an hd t.v. Is there a bulb or something simple to change out to restore its color..?
  • danemisti May 31, 2010
    my television has ost most of its color and has a very dull screen. can I change a part out on it to fix the problem/?
  • Philips Master
  • 3,459 Answers
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
I have A 57 inch stand up t.v and it has lost its  - bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Jun 06, 2010
Measurements of hisence 50 inch 4K tv
From Best Buy's site I found this 50" 4k HiSense TV
http://www.bestbuy.com/site/hisense-50-class-49-5-diag--led-2160p-smart-4k-ultra-hd-tv-with-high-dynamic-range-black/4982500.p?skuId=4982500
With the following dimensions listed:
  • Product Height With Stand 27.7 inches
  • Product Depth With Stand 9.7 inches
  • Product Height Without Stand 25.6 inches
  • Product Depth Without Stand 3.3 inches
  • Product Weight With Stand 28.2 pounds
  • Product Weight Without Stand 27.6 pounds
  • Width 44.1 inches
Apr 03, 2017 | Televison & Video
Lost picture
When was the last time u replaced the projection bulb,yes it could be that simple the projection bulb it dead.The bulb last only about 1 or 2 years,by using the tv on about 4 or 5 hours a day.
Jun 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
easyab
Apr 22, 2010 | JVC Televison & Video
I own a Sony 57" HD CRT Projection Television (Model KDP-57WS655). The unit is about 4 years old. Within the last couple weeks, it has not consistently turned on. I've checked the Sony site, and they...
sounds like it is overheating and shutting down to prevent further damage. i would recommend checking for a local repair shop to see if they can get a look at it. it could be as simple as a blocked airvent and the unit is overheating or there may be a more serious problem.
Jul 11, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Just wondering when to replace the blulbs on my Toshiba 57H81 CRT
Hello, Im Ismail A, and I would love to help you with your problem. Ok, well you should change your bulb every 2 years.
Jan 12, 2009 | Toshiba 57H81 57" Rear Projection...
Tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Sep 01, 2008 | Insignia LCDTV26 26 in. Television
Tv help
Sound like you have a convergance problem, This will involve unsoldering and replacing some Ic's. But this is the most common fail of projection sets like youres so many shop can do this fairly fast, So if your soldering skills are way off you might want to have someone else do this for you
Feb 13, 2008 | Toshiba 57H81 57" Rear Projection...
Sony 57 Inch XBR 2001
I don't have the XBR, but on my sony, using the cable box remote, I had to go into menu/display/etc. and mark the 1080i, 720p, and 480i settings. you usually get a "if you can see this" comment if your tv accepts the settings. for standard tv i set the screen to normal, and when the upper channels go to HD, they auto go to full screen. Sounds like you are using the component cable, and also make sure you are on the video port of remote, and the the TV input. The above worked for mine. Hope it helps.
Dec 04, 2007 | Sony KP-57XBR10 57" Rear Projection...
2002 Sony 57 inch XBR
YOU MAY NOT HAVE THE HD COMPONENT CABLES AND CONNECT THEM TO ONE OF THE VIDEO LINES..
Dec 04, 2007 | Sony KP-57WS500 57" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
73 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
