Question about Jandy AQUALINK RS TELELINK KIT
What does the "Clean Mode" do? We had a pool party and the water
Is not clear.
    Top Expert:
  • Jandy Master
  • 8,686 Answers
Clean mode is if you have your cleaner on make sure chemicals are correct super shock and clean fitlers
Posted on Apr 29, 2016
How to clear water in my pool
bring a sample of the water to any pool place. they will test it and advise what chemicals you need to add to clear it up.
Apr 17, 2018 | Pool & Spa
Spa indicator says Water SW Open...what does that mean and how do I fix?
This means that the pressure switch is not closing. Generally, this is a lack of water flow issue. The main cause is a dirty filter. Clean cartridges, backwash sand, backwash and recharge DE, whatever is needed to clean the filter, this should fix the problem. If not check other sources of restricted flow: filter baskets, pump baskets, shut-off valves. If everything is clear and there is good flow returning to the pool it could be a bad pressure switch. Replace with the correct switch for your heater.
Sep 13, 2014 | Rheem Pool & Spa
Pool water stays murky.Hard to get water sparkly clean.above ground pool
clean filters and super shock after clear then clean filters again
Jul 15, 2014 | Pool & Spa
Can I use pool salt in my summer escapes pool?
if you have a salt system add salt but you have to shock pool to get it clear
Jun 09, 2014 | Intex Automatic Salt Water System for ...
Water is greenish brown
run run run that pump 24/7 clean clean that filter check ph first then balance other chems it will take awhile with well water to clear
Jul 14, 2017 | Intex Automatic Salt Water System for ...
Im getting a blinking 93 and my water wont clear up.
93 is stand by mode indication of the cycle completed.. You may need to increase the cycle time.. The manual is very conservative!!! I have a 14000 gallon pool and I run my intex salt system during the summer at 10 to 12 hrs pump and 8 to 10 hrs chlorination in between those 12 hrs and my pool stays very clear. But..... If you don't clean the unit and let it alarm for low flow, low salt or not run the unit log enough, you WILL HAVE GREEN WATER!!!
Hope this helps, If it does, please rate the tip!
I
Jul 24, 2011 | Intex Saltwater Chlorine Generator 2000...
My pool water turned green after I put an alkalinity and ph stabilizer in it what can i do to get it clean again?
Pure bleach, gets mine clear when it turns green. If its just clear water with a green tent then i would use bleach. I only use bleach to maintain my pool. I have a 20 round 88,00 gallon pool and i use 1 and half gallons of bleach every week to keep my pool clean and i use a bag of shock it every month or so, all the shock is used for is to drop everything to the bottom so i can vacuum it. If u have a smaller pool then i would use about 3/4 a gallon a week on a 15 round 5,000 gallon pool and about a half a gallon for a smaller pool. But it will for sure get ur water clear and if u dont want to use bleach then shock it will do it and to maintain use the shock it atleast once a week. When u use the bleach make sure u pour in over the where the water returns in your pool slowly to help it not hit the bottom. When u pour it over the clean water that is returning to your pool then it will help spread it throughout your pool and dilute it so it wont spot your liner up with lil bleach spots. So just pour it slowly over the return water comin out of the side of your pool. Also if its an algea problem then bleach will def work to prevent and kill the algea and u can u an algeacide to get rid of it if u dont want to use the bleach. The bleach is the cheapest way and fast way i have found to keep a pool clean. My pool is cyrstal clear, u can see any specs that is floating in it I hope this helps, please let me know what u think and rate solution. thanks and good luck
God bless
Jun 15, 2010 | Intex Easy Set Pool 15x36
Cant get pool clean
Copper shows green in water........check for copper level.
Aug 17, 2009 | Intex Krystal Clear Model 635 Pool Filter...
LARS LITE #LLG175N BURNER WON'T STAY LIT.
Make sure your pool filter is clean. Low water flow through the heater will be detected by water pressure switch
Jun 19, 2009 | Teledyne Laars Teledyne_ Laars Lite2...
Jandy AQUALINK RS TELELINK KIT  Logo
188 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
