AEG Lavamat 240 On-Off Program Selector Knob Needs Replacement
Need to replace the Selector Knob. but do not know where to find it in South Africa. Willing to ship from anywhere in world.
See indication(in red) below:
  • Anonymous Feb 24, 2009
    broken knob
5 Suggested Answers
rizla
  • 1463 Answers
SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Posted on Mar 03, 2008
EngineerGR
  • 119 Answers
SOURCE: need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
Posted on Apr 09, 2008
SOURCE: AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Posted on Jun 12, 2009
  • 174 Answers
SOURCE: How do i re set an EFO code on an AEG LAVAMAT
you just need to mop up the water inside the cabinet to allow the float switch in the base to reset.check there is nothing stopping the float returning to the floor. a small leak from the door seal can cause enough of a leak to trip it . clean the door glass and seal to stop this. or change the door seal.
Posted on Jul 24, 2010
blueextc3221
  • 15935 Answers
SOURCE: AEG Lavamat 518 manual
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
Want to know if I will be able to use Sony Bravia KDL 32S4ooo bought in Australia, in South Africa?
if south africa power supply is 240 volts then yes -but -- you will have to go to the onscreen menu and change the setting from PAL to what ever is used in south africa
if the voltage is not 240 volts then leave the set behind
Jan 14, 2017 | Sony Televison & Video
AEG OKO Lavamat 74640 update wont spin. Pump and rinse works ok but doesn't spin.
  1. E52 is a motor fault, i.e. motor not turning or tachometer is faulty. It is most likely that the carbon brushes are worn out and need replacing. These are readily available online
Nov 12, 2016 | AEG Washing Machines
Why AEG Lavamat 88840 Front Load Washer doesn't spin?
either the pump is blocked so cant pump water out so stops program.or brushes in motor worn down(both cheap fixes)
May 22, 2015 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
Switched on AEG Lavamat 971and checked door shut. (No sign of either Model or Serial under soap drawer as user manual info). No sign of life at all except light on On/Off switch which was on, even when...
The problem seems to be with the control board that is bad and needs replacement. However, get back with a more detailed information and also let me know the make & model# of your unit.
Kevin
Oct 22, 2011 | Refrigerators
F9 WHAT SHALL I DO
The fault code F9 means that your washer thinks that the motor brushes are worn and need replacement. It is a fairly simple matter to replace the brushes (you can get them online or from your local appliance repair center.)
There is a possibility that the code is being reported in error, in which case you can try to reset the computer using the following procedure: Unplug the unit for 10 minutes, then plug it back in. Turn the program knob to Off (usually at 12 O'Clock), after which you hold down the top 2 program buttons while turning the program knob 1 click counterclockwise. Release the buttons when all the lights are lit up, but not flashing, and turn the knob to Off again.
Here is a link to the complete manual for your washer:
http://www.serviceforce.co.uk/pdfs/U22473.pdf
Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this answer. Happy holidays!
Dec 05, 2010 | AEG Lavamat 88840 Front Load Washer
HEAD REPLACEMENT FOR FELECTRIC TWHERE IN SOUTH AFRICA DURBAN AREA
Go on the WEB and contact Ryobi. You should be able to obtain a replacement.
Dec 25, 2008 | Ryobi 15" Electric Factory Reconditioned...
AEG Lavamat 1000
hi
riz.
Mar 03, 2008 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 72620 door does not open
It seems that your problem is with the lid switch and it should be replaced. The switch is inside the washing machine main housing near the door frame. You have to raise the top of the washer to get to the switch. Good luck!
Sep 05, 2007 | AEG Lavamat 72640 Front Load Washer
Washing Machines Logo
820 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
