Question about HP Photosmart R937 Digital Camera
My touch screen is not working correctly can it be repaired
  • 45 Answers
In settings menu you will find a test to set the touch screen. Every device with touch screen have this test. After you will run this test, every thing goes back to normal. This test it should look like a white screen with small cross. You should push in the center of that cross.
Posted on May 31, 2010
Touch screen not working
Touch screen is not repairable only change
change your touch screen then use your machine
Feb 14, 2014 | Minolta bizhub 350 Black and White Copier
Bizhub 200 touch screen is not working correctly
Utility/Counter Details Stop00 Stop02 Maintenance Mode then touch screen adjust does not work get a new control panel try web site below Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Mar 12, 2012 | Minolta bizhub 200 All-In-One Printer
Screen of mobile phone Samsung F480T sometimes does not work at all, other times perfectly normal. Resetting by removing the battery seemsto correct temporarily.
Touch screen problem
If your touch screen is not working, there's just 2 major causes of such, either a hardware cause which might be either the phone falling on a hard object or in water which could damage the sensor board and either the screen is malfunctioning and needs to be calibrated.
If you can access the menu of the phone, i will advice you calibrate the screen first before you send it to a repair shop. There is no updates to download for such problem as updating the firmware of the phone would do nothing but change the settings of the phone.
To calibrate the screen, you will have to go to the phones menu, go to settings, then you select the calibrate screen, it will show you some stars to touch and once you touch them properly, then your screen will be able to work effectively.
But if you cannot access the menu because of the touch, then i will advice you send it off for repairs, and what to repair on the phone is the sensor board.
Hope this helps you.
May 23, 2011 | Samsung Cell Phones
My touch screen does not operate properly. When I attempt to press/touch a character another character appears. Example when touching 1, 4 apperars on the screen. How can I correct or reset the touch...
The touchscreen portion of your display is severely out of alignment. Try finding the utility(use hardware keys) to align the display (under settings). Try to align it. If it is too far out of range, it will kick out your "presses". If this happens, you *might* be able to try a reset, but it likely will not work. Otherwise, your only recourse will be replacement or repair.
Jun 23, 2010 | Samsung Behold Cell Phone
My touch screen isnt working. All images appear but i cant unlock the slide screen. i did not get it wet. How do i fix it?
There may be a physical issue with your touch panel. You can get the part at Droid 2 Repair and there is a guide that shows you how to put in the part at Droid Repair Guide.
Jun 17, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
The touch screen on my Samsung U600 has stopped working.
The advice you were given is correct there is no way to copy music or pics....ect... if your touch screen is not working sorry
Aug 05, 2009 | Samsung SGH-U600 Cellular Phone
Dacor Touch Screen is flickering and doesn't respond to touch
You can get that repaired for $39.95 in most cases (details here) or order a control / display unit here.
Mar 31, 2009 | Dacor DMT2420SS Microwave Oven
Broken touch screen
if it is cracked then most likely it will need to be sent back to the manufacturer for repairs. If its not working correctly you could always try to do a screen calibration.
Jan 21, 2009 | Magellan Maestro 4250 GPS
Touch screen repair
The LCD needs to be replaced to correct this issue
Aug 19, 2008 | Motorola Mobility A1200
Broken Elo Monitor Screen
Touch screens are even more expensive that straight LCD panels. This repair may cost more than the original monitor. Why do you need another panel? Is the panel cracked or is the touch screen portion not working correctly?
Dan
Mar 28, 2008 | Computers & Internet
HP Photosmart R937 Digital Camera Logo
395 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
