Question about Samsung HC-R4755W 47" HDTV
No signal -Samsung HC-R4755
The top terminal marked ant 1 broke off a few years ago. I was still able to use my DirectTV hook up by using the ANT 2 (cable terminal). My problem is that I moved the tv to the basement where I only an antenna hook up (no cable or DirectTV) and now I can't get a signal when I plug in an antenna to the Ant 2 (cable) terminal.
Questions: 1. Should it make any difference if I plug my antenna cable into Ant 1 or Ant2?
2. If it does not make any difference, suggestions on getting a signal?
3. If I have to use Ant 1, any suggestion since I don't have an Ant 1 terminal?
I also tried hooking up a VCR to it and did not work. Could I have just damaged something in the move. My menu still come up and I can do a start up.
Suggestions, Thanks Dave
    Sergeant:
  • 252 Answers
Well Dave have a tech come out and solder your ANT1 connection back on its a simple job that will probably set you back $50.00 or less.
Posted on Aug 05, 2010
Panasoics plasma viera rv will not auto tune telling us to insert aerial already in Model TH-P50X20Z
The manual for this TV can be found here. If you are watching broadcast television, or cable TV service that does NOT require use of a set top "cable box" tuner, you would connect the coax cable from the UHF / VHF antenna or cable into the ANT cable connector on the rear of the TV as shown on page 8 & 9 in the manual.
You would then tell the TV setup to scan for available channels as shown on page 12 of the manual.
If you are using a seperate tuner - like those supplied by Cable TV, Dish, DirectTV, Satellite, etc. you should use (1) the HDMI 1, 2 or 3 inputs (HD) 720P and up; (2) the RGB inputs of AV2 for best picture quality 720P or better (HD), (3 & 4) the AV1 & AV3 (on the side next to HDMI) for 480i and possibly 480P (SD) and finally the ANT connector for 480i. If you have a computer that offers VGA jack to connect to an external monitor, use the PC connector on th erear of the TV to send it HD images.
Page 27 & 28 detail manual channel editing.
Mar 14, 2013 | Panasonic Viera TH-50PX80U Plasma TV
My samsung BD_C6900 has no connectivity to the internet
if this is alap top make sure the ant. is hooked up push blue fn+hold ago to f1 f 2 orf3 should have picture of ant. holdblue fn+push ant key this should solve your prob.
Jul 01, 2012 | Samsung Bd-c6900 3d Blu-ray/dvd Disc...
HCP4363W - No color from AV1, AV2 or ANT inputs
You might have a problem with the intenal board or the AV connection onto the board. Have a TV repair center check the board and the connection.
Apr 27, 2012 | Samsung HC-P4363W 43 in. TV/DVD Combo
We have a new Philips 32" LCD TV, 3500 series/32PFL3505D. We are having problems as we try to connect it to our existing Direct TV receiver. Do we need to call for Direct TV assistance, or can you...
Looks fairly straightforward.
Depending on the output of your DirectTV receiver, you are either going to use an HDMI cable.tomcattech17_0.jpg
A component cable: (Red\Green\Blue for video... White\Red for audio)
Or a composite cable: (Yellow for video.. White\Red for audio)
Hook one side of the cables to the Direct TV receiver and the other into the correct inputs on the back of the TV.
Page 9 and page 25 in the attached manual:
http://download.p4c.philips.com/files/3/32pfl3505d_f7/32pfl3505d_f7_dfu_aen.pdf
Hope this helps!
Jun 16, 2011 | Philips Televison & Video
How to program with cable using remote
Hello
1 Find and disconnect the cable that is connected to the
ANT IN terminal on your cable box.
? This terminal might be labeled "ANT IN", "VHF IN" or
simply, "IN".
2 Connect this cable to a two-way splitter.
3 Connect an Antenna cable between an OUT terminal on
the splitter and the IN terminal on the cable box.
4 Connect an Antenna cable between the ANT OUT terminal
on the cable box and the B-IN terminal on the RF(A/B)
switch.
5 Connect another cable between the other OUT terminal on
the splitter and the A-IN terminal on the RF (A/B) switch.
6 Connect the last Antenna cable between the OUT terminal
on the RF (A/B) switch and the ANT IN (AIR/CABLE)
terminal on the back of the TV.
After you have made this connection, set the A/B switch to the
"A" position for normal viewing. Set the A/B switch to the "B"
position to view scrambled channels. (When you set the A/B
switch to "B", you will need to tune your TV to the cable box's
output channel, which is usually channel 3 or 4.)
OK
Jan 01, 2011 | Samsung SlimFit TX-T2782 HDTV
Samsung Ant 1 (Air) and Ant 2 (Cable)
no ant 1 is for dtv off air siginals ant 2 is for cable chann.
Feb 04, 2010 | Samsung DLP HL-P5663W 56" TV
I have direct tv hooked into my ant/cable hookup I get no channel
pull the card out of the front of the directtv box ...wait 1 minute and put back in...turn box on...hope this helps
Jan 03, 2010 | Televison & Video
Is it necessary to bring the signal from the ant. if I never intend to record? Do I still need to use the "out to tv" hook up?
If you want to watch TV you will need to hook the antenna to ANT. IN and run a coaxial cable from OUT TO TV to ANT. IN on the TV. Otherwise disconnect the antenna from everything. Good luck to you!
Dec 09, 2009 | Televison & Video
The TV cannot locate TV channel source, which is DirectTV box.
use DirectTV box video to tv video1 input
use indoor or outdoor antenna to tv ant input
setup tv cable to antenna
scan channe.....watch tv...
Nov 28, 2009 | Insignia 37" LCD Flat-Panel HDTV
How do i use the ant. passthrough on tv2 in dual mode w/ dish dvr625
ANT. passthrough for an ant. connected to your 625 receiver will only work on tv 1. The only way to do this is to RF modulate your tv 2 coax to an RCA and hook the RcA cable to your tv2. then use another ant. to connect coax allowing you to pick up dish programing on an input and then going to the channels to enjoy local over the air programming.
Nov 26, 2009 | DISH Network DVR-625 DTV Receiver /...
Samsung HC-R4755W 47" HDTV Logo
98 people viewed this question
Henry  Thomas
Henry Thomas
