Question about Lands Phones
Answermachine base unit bleeps at 1 minute intervals
My puk Code 0=\9043805851.
Posted on Jun 01, 2010
How to turn of answermachine
Press and ANS ON/OFF button on the base unit.
Full details are on page 30 of the manual.
Sep 23, 2012 | Vtech CS62293 Cordless Phone
Setting up answermachine for calls I need to set up answermachine for my calls after a certain number of rings
Hit and hold the number 1. This should bring you to your voice mailbox set-up. Follow prompts from there. If that doesn't work call your cell phone number from your cell phone.
May 02, 2011 | Samsung J700 Cellular Phone
Why does my phone keeps beeping like I have a call waiting?When I am on the phone talking I keep hearing an interruption beep. I have no voicemail messages or text messages and nobody is calling me...what...
hi, to me it sounds like you have got a warning tone switched on then bleeps after every minute, this is a feature on the phone and its just to tell you that you have been on the phone for 1 minute so it helps you work out your charges based on how many times you hear the bleep.
Now it can be turned of you just need to go into the settings and turn the alerts and warning tones off
Mar 26, 2010 | LG Shine CU720 Cellular Phone
L need to find out how to set time and date on this phonw
Hope this helps:
Voice Time/Day Stamp
1. Make sure the answering system is ON.
2. Press and hold the day/check button on the base to set the day of the week.
3. Press and hold the hour button on the base to set the hour (a.m. or p.m.). Example: 12AM, 1AM, or 12PM, 1PM.
4. Press and hold the min button on the base to set the minute. The time advances in 5-minute intervals, or tap and release to advance in 1 minute intervals.
Speaker Volume
Use the speaker volume (- / +) buttons to adjust speaker volume on the
Jan 30, 2010 | GE 25952EE1 Cordless Phone
No instruction manual
On the handset that is on the base is the one you need to use to set the time and date. It will also clear out the CL on answering machine.
On the handset without pushing talk hit the flash key. A message will appear on your phone and it says Answering machine. You can listen to all the options but to set time and date ---push the 8 button.
Set your time by using the phone keys such as it's 09:53 then look up in the right corner and use the + arrow key to set AM or PM. Then hit the # key. Then in the upper right corner it will say Mon---use the + arrow key to set the day. Then hit the # key. The message on your phone will say the day is and then the time is. Then hit flash. Then you can check your answering machine and see if that worked. This took me some time. I would not buy another phone like this again.
Mar 06, 2009 | GE 25952EE1 Cordless Phone
Telstra 7100. we had a power cut and now the phone just flashes with base 1 ....no dialing tone ect help
Disconnect the phone line leaving the power supply still plugged in. Next page the handset from the base unit hold and press button until it bleeps (remove the handset from the base unit first). press menu and scroll down to register.... press menu .....scroll down to select base... press menu then press 1. This should reset the phone. Failing that you can ring customer services the number will be on the bottom of the base unit.
Regards Sheena.
Nov 04, 2008 | Lands Phones
Binatone vantage handset says range out
Had this problem myself today, emailed binatone and they sent me this - and it worked!
You need to press and hold handset locator button on base unit till starts bleeping, on handset press menu, up arrow to register, press ok, press 1 for base unit, then 0000 for pin code, press ok, it will say wait, press ok again
Cheers
Oct 27, 2008 | Lands Phones
Diplomat aca9102 wont start all program lights flashing and making bleeping noise
there is a small/large leek in the base of the unit with the filler module probably as i have just removed mine cleaned it emptied all the water from inside the base, tightened the hoses properly and now its running, i was a hour to repair i am a technical minded person so i had no problems but if you are unsure please contact service engineer any local repair man should be able to fix it! there was a switch controlled by a foat in the base as my unit had a leak this is what cause continuious bleeps and 3 flashing lights!!! good luck
Aug 22, 2008 | Dishwashers
Wharfedale touch dect triple phone with answerphone
Hi Michell,
I have the same unit and mine bleeps when I have new messages.
anthea
Jul 12, 2008 | Harley Davidson KNG America 026711...
Lands Phones Logo
27 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
