Question about Kenmore 71279 Bottom Freezer Refrigerator
Freezer works as usual. refrigerator food area not working.
Refrigerator is approx 10 years old and has worked fine until this am. I found door open this morning..no idea how long it was open through the nite. I checked the vents and coils and vacuumed. Front vent was almost plugged not alowing air to flow.
  • Kenmore Master
  • 2,699 Answers
If you have another fridge you can put the food in it and leave this fridge unplugged and just let it melt out overnight or melt out the air vents with a hair dryer.empty the freezer,remove the back inside wall and melt everything out and clean the ice off of the packages,you should have no problems with the fridge after that.common problem with kids.
Posted on May 31, 2010
  • Sal De May 31, 2010
    be careful with the heat in the vent areas,you could damage the plastic and the styrofoam in these areas
Refrigerator not cold turned up setting to 7 with no change however freezer is working well
Some things to start with. Defroster not working and evaporator is iced over. Fan that circulates air has failed. Solenoid on flapper that opens air passage is not opening.
Dec 11, 2014 | Maytag Refrigerators
E402b freezing food
there is a little door between the freezer and the fresh food usually when that happens the motor on that door is bad and sticks open and allows the fresh food to get to cold since your freezer actually cools the fresh food side, sorry i cant tell you where it is on yours since they are are different, it will be where the cold air blows in the fresh food side and the part is not usually expensive and fairly easy to replace.
Mar 23, 2014 | Fisher and Paykel Active Smart E522B...
Kenmore fridge, model 253.63754302 freezer working fine, main fridge not cooling much (approx 62 degrees F.) Have been away for 7 months. Usually plug it in to restart and all works fine. Not this...
Your refrigerator is made by frigidaire it sounds like your damper is opening up if your freezer cold and the fresh food compartment isn't.
Nov 03, 2013 | Kenmore Refrigerators
GE side by side gss25jepbb not cooling any longer, probably 10-15 years old
HI LISA.getting old.could be a no of things.try these simple checks1-is motor making noise.(compressor).if not is hot?2- condenser is it hot or cold3- any ice at all inside freezer?if yes defrost all and try.(could be defrost timer/heater/t/stat/fan)4-if NOice it could be lack of refrigerant condenser fanmotor.or motor .hope this helps otherwise call engineer.good luck.Ali
Jun 24, 2012 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Have Kenmore refrigerator and fan in freezer is not working ....any suggestions ?
Frost build up is normal... and SHOULD be expected...
You should check your DEFROST PAN at the bottom
(it should have STANDING WATER evaporating daily
(dust is usually an indication of DEFROST FAILURE
(easy to fix))
ALSO the FAN should NOT run with the door open...
My best advise ... if indeed that was ICE...
typically caused by air intrusion...
(sometimes just result of a cube stuck in the
(door service) chute.. or a pizza box holding a
door ajar (worlds will not end)))... Clear that ICE
and easily expect another 9 years of faithful service...!!
You need to allow that machine to defrost at room temperature
for as long as it takes to melt that ICE... COMPLETELY.
Helping it with a fan at ROOM TEMPERATURE is fine,,,
but ABSOLUTELY use no heated air (damage can occur).
Good temperatures in Refrigerator/Freezer sides is a
VERY GOOD indicator...
ELSE...
look over your door seals and make sure they are in full
contact ... ALL-THE-WAY-AROUND.
Comment me back...
You can do this (inexpensively)
Common Refrigerator Symptoms Symptom Diagnosis Sears PartsDirect ... SEARS parts were getting pretty competitive...
Now I cannot push it into a PRICE without talking to one of their CLOWN HEADS (pushy parts folks... My opinion).
Carnac the Magnificent
Nov 20, 2017 | Kenmore Refrigerators
My samsung side by side was working great untill
You have an automatic defrost problem. The refrigerator is not defrosting
Three important parts. It probably is one of these.
Defrost Timer
Defrost thermostat
defrost heater.
The fan is probably fine, but has nothing to do with Defrost
Check the heater continuity and change the heater defrost thermostat
then replace timer if those don't solve it.
Leo Ponder
imufo2@sbcglobal.net
Jul 30, 2010 | Samsung RS2630SH Side by Side Refrigerator
10 yr old, sits in a garage. Worked fine until a
is the fan operating,if so then check your damper vent door that throttles cold air from freezer to refrige compartment they can freeze shut and a hand held hair dryer will thaw them out,then adjust its control to make sure the door moves when control is adjusted
May 08, 2010 | Kenmore 72102 / 72104
I Have a side by side fridge freezer approx 3/1/2 years old the freezer is fine but the top half of the fridge isnt cold yet the bottom crisper etc is
Check to ensure that the freezer fan motor is operable (you may need to open the freezer door and activate a button inside the freezer door frame in order to make the fan operate). If the fan works, then you may have an issue with the damper assembly (located in the fresh food compartment at the top left side). It will either be a "manual" or "electronic" concept. Adjust the temperature settings for both the freezer and fresh food compartments at the "half-way mark". You should also have a vent or two at the bottom left side of the fresh food compartment (check to see how far they are openend or closed and adjust accordingly). If the aforementioned doesn't help, contact an appliance service company.
Feb 17, 2010 | Samsung RS2556 Side by Side Refrigerator
LG Refrigerator has no cold air for fridge but freezer works fine
Sounds like the freezer fan(FF)is wearing out, This problem is very hard to diagnose because the fan spins but not fast enough to circulate the chilled air thru the freezer and refrigerator. This repair costs parts and labor around $300.00
Jul 31, 2009 | LG Refrigerators
Kenmore 71279 Bottom Freezer Refrigerator Logo
125 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
