Question about Craftsman Convertible 25cc. Gas Line Trimmer
I left gas in my trimmer over the summer, now it doesnt start
The trimmer starts, but doesnt stay on
    President:
  • 1,627 Answers
The first thing you should do is dump the fuel out of it and your fuel jug and replace them with fresh gas and a good quality mixing oil,unleaded gas does have a shelf life and it sounds like yours has expired.A new spark plug would also be a good idea.
Posted on May 31, 2010
  • Craftsman Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes when you leave gas with oil in the carburetor it will form a "shellac" and plug your jets and float assembly.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Craftsman 32cc gas trimmer won't start.
Take out the plug and shoot a shot of starting fluid in it replce plug have a can of carb and choke cleaner to help it along until it picks up fuel spray by the air cleaner the carb and choke cleaner
Jul 21, 2014 | Craftsman Convertible 32cc Gas Line...
What is the problem when my 27cc craftsman weed wacker starts but doesnt stay running
check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to clean or replace carburetor.
May 29, 2012 | Craftsman 27cc 2 Cycle Crank Straight...
Echo trimmer, replaced the spark plug, but trimmer won't crank up. Started up just fine last spring (2nd summer I owned it) Gas appears to be filling the priming bulb, but I don't think it is getting any...
Possibly the gas has went bad, it doesn't take long for that small amount. Try fresh gas/mix but pull the plug and crank it several times to flush out the old gas. Clean the plug and try again. Note; the plugs foul quickly and easily.
Apr 21, 2010 | Garden
I have a Troy weekwacker, and after sitting this winter, it WILL not stay running. The only way to even get it to start is to load the thing with starting fluid, and then it only runs til it eats up all...
Have you changed the spark plug on this unit? If all else has failed, this is more then likely the problem. Please let me no if it takes care of the problem.
Sincerely, Shastalaker7
Apr 14, 2010 | Troy Bilt Tb70ss Gas Trimmer
Right fuel mix spark but wont start..priming bulb stays down-doesnt pop up. trimmer wont start.clean air filter too.
Your carburetor is plugged. What's happening, is the carb can't get fuel via the normal means, so it's trying to draw it through the primer system instead. This will require disassembly, likely a new diaphragm, and cleaning.
Feb 18, 2010 | Craftsman 25cc Gas Line Trimmer
Trimmer won't stay running without starter fluid
drain any old gas/fuel mixture out of unit.
purchase new gas and mix with oil as recommended for your engine.
clean the air filter on the unit.
pull the spark plug and clean with carb spray and reinstall...
you also may need to remove the carb and clean any jets with carb spray... old gas can turn into a shellac'ish type goo and foul up the works...
I recommend draining all fuel after usage...
May 29, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Lost manuel Can't start my Ryobi C530 gas trimmer
trun the on/off switch on,prime it with the bulb 3-6 times choke it , pull the cord 1 or2 times then take the choke off and pull a few times till it starts if it doesnt start you have problems.
May 17, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Gas Trimmer will not stay started
My straight shaft trimmer will idle but dies when the I pull the trigger.
Apr 03, 2008 | Ryobi 15" Electric Factory Reconditioned...
Craftsman Convertible 25cc. Gas Line Trimmer Logo
129 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
