Question about Polaroid TDA-03211C 32 in. LCD HDTV
Screen is showing a no signal, and is being fed from directv sat
Was wondering if the receiver was bad
    President:
  • Polaroid Master
  • 775 Answers
Well try different inputs and also different sources.
The problem may be in the source, might be input specific or might be that the whole board in the TV was damaged, usually as a result of a surge thrugh the cable or antenna.
If the same result is seen with different sources, then you'll need a new main board like this:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=110524990768&ssPageName=STRK:MESE:IT
Make sure to match the board number in your TV *before* ordering anything!
- bobby
Posted on May 31, 2010
Sat Nav. Vehicle position on screen wonders off after 30 mins and screen shows 'no signal'dealer says no fault found! can you help? what receives the signal?
did you check how many Sats ur Navi found??? if it found only 1 then it could be it  usually for perfect work it needs 3 and more Sats
Jan 29, 2010 | 2006 Land Rover Range Rover Sport
Can't watch anyother shows while recording another
Check the back of the DVR to make sure BOTH cables from the dish are properly connected to the receiver. Make sure they are properly tightened. It sounds like one of them has come loose, because if the receiver only has one working cable coming in from the dish it can only do one thing at once- you can only record one show at a time with one cable. You can also go into the receiver's setup menu and run a system test, which will help you diagnose the issue.
Feb 08, 2009 | Directv (R10) DTV Receiver / 70-Hours...
HDMI interface issues
If you swapped directv receivers and the problem followed to a different tv then there is something wrong with the directv receiver. Need to run satellite setup again on this receiver to fix. repeat satellite setup is accessible through the setup submenu by pressing menu from the directv remote. look under satellite submenu once in setup
Dec 23, 2008 | JVC HD-52Z575 52" Rear Projection...
No signal
if you have switched them around and u still have the same problem from the receiver, them the box is bad. call directv and let them know. they will either send u a new one or send a tech out to replace the bad one
Sep 19, 2008 | Directv D10 DTV Receiver
Will not boot- Sits at searching for sat forever and does not get past this point
I had this same issue recently. Unplug the receiver, for approx 30 seconds and after you plug it back in, it should receive the signal and boot up when you turn it on.
Mar 19, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Second DirecTv box unable to locate a signal
it is multi sat multi sat compatable!My opinion is buy a powerd multi switch you can getem at radio shack or from a sat dealer that will clear p your prolem i belive also check all your rg6 coax ends u may have a a bad splice or a fraid shiel wich will make your reciever do the same thing but hope you can fix it
Goodluck
Please rate
Dec 11, 2007 | Televison & Video
Lost locals thru multiswitch
Do you have at least a 2-channel LNB on your system?...accordianman
Oct 15, 2007 | Samsung SIR-S4040R DirecTV DTV Receiver /...
DIrectv Sat internal box.
You can try eliminating whethor or not the receiver is actually the problem by moving it to another TV and seeing if it works on one that isn't having any problems. Or moving a working receiver onto the TV to see if it will pick up signal with a working receiver. If you don't have any receivers in your house working, then odds are something needs to be serviced outside your home, like the Dish and/or LNB.
Did DirecTV actually come out to the home and troubleshoot at the site? If not, they would have no way of knowing if it's the TV or Satellite that's causing the issue.
Aug 09, 2007 | RCA F38310 38" TV
Polaroid TDA-03211C 32 in. LCD HDTV Logo
90 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
