Question about IBM ThinkPad T23 2647 Notebook
Will not power up with power source on - IBM ThinkPad T23 2647 Notebook
  • 2,418 Answers
I just went through this with my Think pad, used a volt meter and found the power supply was not putting out any voltage. Ordered a new one.
Posted on May 31, 2010
Will not start, no click from starter, like its getting no power, but I have checked and pwr at ignition and pwr at starter but nothing but if I turn ignition on and jump solenoid it will start up !!
If under your own power source, vehicle is not starting...
then you connect an alternate power source, and it starts (as you said - right up) then your power source is bad!
Power Source = Battery
Jun 09, 2015 | 2000 Hyundai Accent
Freezes at log in screen
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB.
Mar 22, 2011 | Acer Computers & Internet
Brand new computer-keyboard does not work
Have nice day :)
Mar 13, 2011 | ASUS 90-A4C1K1000 Keyboard
Kyocera mita 5035 code 6400 c
Zero-crossing signal problem
• The main PCB does not detect the zero-crossing signal (Z CROSS SIG) for the time specified below.
Causes
Poor contact in the connector terminals. - Check the connection of connectors YC1-3 on the main PCB and YC2-6 on the power source PCB, and the continuity across the connector terminals. Repair or replace if necessary.
Defective power source PCB. - Check if the zero-crossing signal is output from YC2-6 on the power source PCB. If not, replace the power source PCB.
Defective main PCB. - Replace the main PCB if C6400 is detected while YC2-6 on the power source PCB outputs the zero-crossing signal.
Dec 18, 2010 | Kyocera Mita KM-5035 Printer
No power even thougth power source is OK? No
If you know the power source is good then it's either a fuse, the cable itself or the power supply for the monitor.
Oct 25, 2009 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
I can't get the computer to power up. the power
You have a bad power supply.
The computer power supply is a central point for the compute powere BUT it divides the power into severl "flavors" it creates a source for hardware line drives but it also creates a source for the mother board which is a different coltage and current level fro the hardware source.
The suspect is that teh compents in teh powersupply that bracch the mother board sources is dead.
Oct 03, 2009 | Computers & Internet
Printer will not print hp error messsage oxc19a0024 removed all cartridges pupluged as recommended
OKSolution 1:
  1. Turn off power and unplug from power source.
  2. Open right side of printer.
  3. Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
  4. Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
  5. Unplug power source.
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
  7. Plug in power source and turn printer on.
Solution 2:
  2. Open right side of printer (looking at the front).
  3. Disconect,by pulling gently, the flat ribbon cable off the main circuit board that is the smaller of the two.
  4. Plug in power source and turn printer on. Wait till you hear no more movement from inside from unit booting up.
  5. Press both cancel and power button at the same time.
  6. Message on printer screen will be, "Enter Special Key Combo".
  7. Push keys; Left-Ok-Right.
  8. When printer screen changes, scan through and look for "System Menu" and push "Ok"
  9. Scan agan and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan agan and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  11. Press "Cancel" 4 times
  12. Turn off power and unplug from power source. Wait for 2 minutes.
  13. Reconect the flat ribbon cable by aligning and carefully pushing into the conector on the main circuit board.
  14. Plug in power source,and turn on power.
  15. When printer boots up, answer the questions on the printer screen for your area.
  16. The printer will cycle the ink from the cartridges to the print head and back.
Pineworks
Oct 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error0xc19a0024 on a hp 6180 will not print
Follow the below 2 solutions :-
I
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the connectors on the main circuit board.
II
  9. Scan again and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan again and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  13. Reconnect the flat ribbon cable by aligning and carefully pushing into the connector on the main circuit board.
If problem persists, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 07, 2009 | HP Office Equipment & Supplies
Power source not charcing battery
Its not the battery, its AC power source providing your problem.
Check if AC connector goes in as far as it should on your laptop, check so you dont have a weak link on the cables on the AC. My guess is that the power sorce or the cables on is defect someway.
Nov 19, 2008 | Toshiba Satellite A100-S8111TD Notebook
IBM ThinkPad T23 2647 Notebook Logo
52 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
