Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Riding mower-starter relay clicks-no start even with jumpers.
Craftsman 17 hp ohv, mod # 311707, type 0132-ez,I/C platinum, relay clicks one time with each attempt to start, did not test starter to see if getting power, also did not direct connect battery to starter terminal as did not see reconizable negative terminal. does starter have negative ground thru frame? tnank you for your advice, grump.
    President:
  • 1,627 Answers
The frame of the tractor is the same thing that starter grounds to,so yes ,put the ground any where on the frame or engine block to test the starter.An easier way to test everything is to cross over the large posts on the solenoid with a screwdriver and if it turns then the starter is not the problem.Then you will need to put power from the post on the solenoid that has the battery positive connected to it ,to the post on the solenoid that should come live with the key,if it starts then then you likely need an ignition switch if not you need the solenoid.
Posted on May 31, 2010
Testimonial: "thankyou for your expert help, I feel a lot more confident now about the problem.will run the system checks you described. thanks again, grump."
My craftsman riding mower wont start when i turn the key all i hear is a click ,it has a new starter
Terry,
Sounds as if your battery is drained. Or it also couldbe a the solenoid. You can use a multimeter to test the battery to see if it has the 12v needed to start the engine, also you can use it to test the solenoidto make sure it's relaying the voltage.
If u have a set of jumper cables, u can test by simply hooking them up to another battery source, as in a car battery, and then attach to the mower battery, won't hurt anything..
If you KNOW the starter is good, then it can only be these 2 other things that I have mentioned. Hopefully the starter is not defective...
Oct 08, 2015 | Craftsman Garden
I have a briggs & strat 17 hp ohv intec model 311707 on my craftsman lawn m. it was running then with a large puff of smoke it quit. now the starter runs it with no compresion, removed the s p (oi
does the engine when it is turning over sound normal? does the engine have any compression at all or is it just not as much? sounds like a burnt valve
Sep 07, 2012 | Measuring Tools & Sensors
17 hp craftsman lawn tractor valve adjustment
You watch the videos, they said different. I go with .004 on intake&
EXHAUST. Type in adjust valves ( your engine) in Goggle, watch a
video.
Jul 26, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding mower clicking noise - wont start
RIDING MOWERE JUST CLICKS AND WON'T START HOWEVER IT WAS RUNNING FIND JUST 5 MIN. BEFORE I TURNED OFF.
May 22, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
My mower wont start...i replaced the battery and it just clicks
Have a friend jump start the mower while you a seated on it. Turn the key to the "on" position. Connect the black jumper cable from a known good battery to a good ground on the mower and the red cable directly to the electrical connection of the starter. If the starter does not engage, it is faulty.
Apr 18, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
We need the electrical diagram for a 17 HP Craftsman 42" cut riding mower. Model-311707 Type-0321-E1
this is as close as i can find.. take a look and see if you can use this diagram...good luck. go to page numbers 34 and 35
http://www.hammerwall.com/Download_Manual/18200/
Apr 12, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The cable broke which engages my blades on my craftsman 17 .5 hp 42 inch. I need a model part number for the same . I have lost my owners manual with that information
locate mod # on tractor may be under seat
go to sears.com click on parts direct and enter that number and it will take you to the parts section for that mower.
Jun 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,465 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
