Question about Philips Televison & Video
Elements FLX-3710 screen is bright white ive replaced the power supply board the picture seems to be visible but very hard to see because of the white is so bright
  • mj14 Jun 01, 2010
    yes it concluded my thoughts and was to the point with answers. not an economical repair
    thanks
    mike
  • 10,594 Answers
First thing that most likely could be bad is lcd panel (screen) itself for over bright screen and second is main board that provides video signal data to lcd panel.
Does over/ high bright screen problem happens in all inputs?
Thanks.
Posted on May 31, 2010
  • 1 more comment
  • mj14 Jun 01, 2010
    it is on all inputs
    any ideas what a screen might cost?
    the power board had 2 caps blown and some power issues, that is why i replace it, hoping to take care of the problem.
  • Shahid Electronics
    Shahid Electronics Jun 01, 2010
    One question about power board:
    Was tv give correct picture before power board repair?
    If yes then double check power board and measure its output volts on connectors going to main board.
    LCD screen would cost about 80% of new tv price, that is not economical fix.
  • mj14 Jun 01, 2010
    it had the exact problem as now
Element tv dark no picture
This is a very common issue with that model. There are filter capacitors on the power supply board that fail and keep the back light power section from starting up correctly so you get no picture on the screen. The FLX-1910 uses the same power supply board of the Polaroid TLA-01911, below is a link to information showing how to repair this power supply board.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
Nov 08, 2012 | Element Electronics FLX-1910 19 in. LCD...
My lcd element FLX-3711B dont turn on.. I plug the cord cable and only flashing front red light? Whats the problem?
The Element FLX-3711b TV is the same unit as several model of Polaroid and Visco TVs. They are all made by the same company just labeled fr different brands. The flashing power light is a very common problem and is caused by a failure of the power supply board. The capacitors on the board short out and this causes the board to not power up correctly. Here is a link to a repair guide for the Visco TV that is the same as the Element FLX-3711B so the information will be the same for both units. The repair guide shows the parts that will need to be replaced on the power supply board to rebuild it.
http://www.ccl-la.com/blog/index.php/visco-vsc-37v1-no-picture-lets-repair-it/
I hope this helps you out.
BuddyMc
Jul 10, 2012 | Televison & Video
My XP will not recognize my Element FLX 2210 TV/PC Flat Panel. Is there a driver I can't seem to find or am I to run thru my little ritual until I give up and buy a new monitor?
Slow picture display like this is usually a symptom of failing filter capacitors on the power supply board. I will take longer and longer for the capacitors to hold a charge and allow the power board to initialize correctly. Here is a link to a repair guide that shows what to look for and replace on the power supply board to rebuild it.
I hope this helps,
BuddyMc
Jun 28, 2012 | Element Electronics FLX-2210 22 in. LCD...
Element flx 2210 does not power up automatic after pressing the power buttin
You have classic symptoms of a failing power supply board. As others have stated this is caused by the filter capacitors on the power board. This model uses the 200-000-xxxxtltx power supply which is the same one found in the Polaroid TLS-01911c TVs. Here is a link to a repair guide that shows what to look for and replace on this board to get you TV back up and running again.
I hope this helps,
BuddyMc
Jan 07, 2012 | Element Electronics FLX-2210 22 in. LCD...
Where is the inverter board located on the element flx-3210? Is it somehow combined with the powersupply? I've taken the TV apart and have found everything except a part that resembles an inverter...
Yes, inverter circuitry is combined in one board together with the power supply circuitry. It is beside the connectors of the power supply board to the mainboard. You can see two high voltage transformers, these are the one producing high voltage feeding the bulbs...
Nov 01, 2011 | Element Electronics FLX3210 32 in. LCD TV
My screeen has gone white on my tv how do i fix it on my element flx-2210 tv
White screen only / no picture is a sure sign of a failure in the power supply board. Your TV is getting power to the back lights but the control board voltages are not getting through so it is not displaying the picture right. This is an easy repair to do, you will just need to replace the filter capacitors on the power supply board. This Element model is actually made by Funai and is the same as the Polaroid FLX-01911c TV. Here is a repair guide for that model that will show you what needs to be replaced to get your TV back up and running again.
BuddyMc
Jan 30, 2011 | Element Electronics FLX-2210 22 in. LCD...
I have a Element tv model #FLX-3710 and when I turn it on I only get a blue screen.
checked first the signal from ur cable/antenna it seems you haven't a signal from there that's why u got only a blue screen....
Dec 26, 2010 | Televison & Video
I have an element 37in. flx-3710 tv. lately whwn i turn it on the screen stays blacks and flickers for a few minutes untileventually the picture appears.however the picture is either washed out or so dark,...
ldq781, I think you or electronics technician should investigate the units internal "switch-mode-power-supply/cold cathode-fluorescent lamp electronic ballast circuit(inverter) for "failed" "swollen" electrolytic filter capacitors and or "poor quality" soldering of the electronic components to the copper foil traces of the printed circuit board(power supply board) The first thing to do is visit YOUTUBE for video clips of lcd monitors being repaired for these typical types of "failures" which are most common to both types (monitors and lcd tv's) After you do your research then return here and leave additional reply if you still need help. 12fixlouie
Sep 24, 2010 | Element Electronics FLX3210 32 in. LCD TV
Element FLX-3710 37" LCD tv will not turn on
power supply problem of course...set is not dead so line fuse would be good as you said...regulating power supplies are very stable but do contain >>>CAPs<<< caps can leak ,swell do to heat ,etc.
check for visible signs of damage to caps. on circuit board...check regulating transistor( on heat sink)
the >>> on off on off routine<<< makes me think check caps!!!!!
May 19, 2010 | Element Electronics FLX3711B 37 in. LCD TV
There is no picture just a black screen. Had it for about a year and a half. The "element" word appears on the screen when I turn it on and I get sound but no picture. Could it be the bulb?
Look in the back of the tv when its on and see if there's light from the CCFL lamps inside. If so then the timing control board needs to be repaired or replaced. If the lights are off then either the master-or-slave inverter boards need to be repaired or replaced. Get someone who's technically savvy and I'll show them what to do and fix your tv. Get back too me when you can...
please rate this answer :-)
Dec 05, 2009 | Element Electronics FLX-2210 22 in. LCD...
Televison & Video Logo
59 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
