Question about Microsoft Windows XP Professional
Please help with this assignment on computers
A department store plans to upgrade its IT infrastructure to support a new order-processing application with rich features. The store currently uses eight stand-alone computers when customers check out. The specifications of these computers are:
  • Pentium processor
  • 4 GB hard disk
  • 128 MB RAM
  • Windows 98
The management of the store wants to upgrade four of the computers and use them to process client orders. The initial study done by the management reveals that the computers will perform the following tasks:
  • Run an order-processing application that requires a multiprocessing operating system. The application will take orders from customers over the Internet, process the orders, and create invoices.
  • Communicate with customers using e-mail to resolve customer queries.
  • Store customer data on the local computer. The store will use this data to promote new products.
The department store needs you to upgrade the four computers. Find the necessary equipment from online vendors to upgrade the computers. submit a cost report, a list of hardware/software needed, and a labor estimate for upgrading the four computers.
  • 428 Answers
Its better if you could do this by your own. Othewise you won't learn anything :D.
Multiprocessing - An operating system capable of supporting and utilizing more than one computer processor. Multiprocessing refers to an operating situation where the simultaneous processing of programs takes place. Below are some examples of multiprocessing operating systems. This also comes with Multi Tasking and Multi user (and multi threading as well). There are SMP and ASMP systems. Read further from here It can be a system which controls a computer or any other hardware device. Examples: Unix/Linux (true support), Windows NT, Windows 2000, Windows XP Professional Windows use SMP and XP sometimes tends to give errors). Vista Business, Enterprise, or Ultimate support multi core and multi processing/processor technologies. (Same applies for Windows 7) Any Server OS such as Windows 2000, 2003, 2008 (not good for client computing. they are servers)
You have to analyze the actual requirement here. Multi processors or multi-core/mthreading/mtask. I don't see any necessity to run a multi processor OS though. You can select a Unix version if the cost cutting applies but need to find an application which suites it. Not sure whether you could find such an advanced application according this scenario.
RAM requirements. Depends on the OS, Workload and the Application. You can check for each OS and use recommendations. Check the application requirements and compare it with the OS. To get an idea of the work load you have to simulate a system and use compmgmt.msc and add a Performance Counter. Each application has workload data in their web sites.
Processor requirements: Pentium which class? 4 is good 2.4GHz and upwards. Better a dual core for the scenario. No need to go for a core 2 or quad core if the cost cutting involved.
Hard drive: Depends on the OS requirements. And the applications + storage. The number of customers will affect this very much. You have to re adjust it after examining the Application requirements.
If you need to share the data you have to think of a storage server and file sharing as well. (If the application supports running an internal database one of your machines should hold the database or run in in a server to support multiple users. Nowadays most apps require such. But the requirement says to store data in local PCs so you can ignore it).
Internet requirements. Analyze the required bandwidth for application in the LAN/WAN. 100mbps would be enough in most cases. Internet speed depends on the number of transactions a day. 1. Application 2. Per User. 3. Per employee. Its easier to find the app requirements. It should be available in the product sites. If not assume. (Availability, Response time, Reliability) Per user: Only if users access from the internet. Ignore otherwise (Availability, Reliability). Per Employee: Add user traffic to the findings. (Availability ,Response time, Reliability)
Internet requirements : No clue given. Check available options in your country. ADSL 2+ would suite with 1Mbps or more. This must not be a bottleneck ( in case of a single gateway failure).
Scalability Issues. You have to support scalability (in case of an expansion) Each app must support it. The network requirements must support it.
Availability = Approximately Real-Time.
Response time: Avoid bottlenecks (OS or app or network and specially no slow machines due to RAM/ Processor over utilization and HDD slowness) Sata would suite in your case (but its possible to use iSCSI since its reliable and fast).
You need a corporate printer (if cost cutting not applied - a print server). Otherwise a shared printer. (You can use Windows work group - May differ in Unix) Fax if necessary. Its fine if all in one machine could be purchased. There are low cost solutions from HP.
A backup database or a HDD.
An E-mail solution. (You can utilize public platforms as well such as Yahoo - Offers more security).
Reliability : The major factor Bottlenecks >>> 1. PC hardware (you can use the required). 2. LAN Switch and/ or Router (If and only if the network needs to be analyzed. Use a hot standby switch / router to avoid bottleneck. How ever if there is not much necessity for a Network environment you can just use an ADSL router with a switch. Switch should address scalability issues). 3. Using a backup connection such as a Modem connection for internet.
I don't think labor requirement is an issue. A user who has capabilities to administrate the systems will be enough. 1 Person. Antivirus / File Antivirus / Firewall (a must). Recovery software if needed.
Hope this helps to give an idea.
Please be kind enough to rate this answer with a testimonial.
Please feel free to contact any time.
Thanks for contacting Fixya.
Posted on Jun 02, 2010
How do I upgrade Netflix on my Toshiba smart tv? serial # E31283C55548D1
Log in and go to my account
Netflix
https://www.netflix.com/ChangePlan
Forgot your email or password? Sign In. Remember me. Login with Facebook. New to Netflix? Sign up now. Questions? Call 1-866-579-7172 · Gift Card Terms ...
How do I change my plan? - Netflix Help Center
https://help.netflix.com/en/node/22 If you want to upgrade or downgrade your Netflix streaming or DVD (US only) plan, use this article to guide you through the process.
Netflix Streaming Plans - Netflix Help Center
https://help.netflix.com/en/node/24926 To see current plan pricing and sign up for Netflix, visit Netflix.com/GetStarted. If you are already a member, you can change or upgrade your plan anytime from ...
upgrade Netflix Google Search
Oct 03, 2017 | Toshiba Computers & Internet
Is it worth upgrading to a Dimension 5000 (taking the existing HD and RAM from the 280 into the 5000), if that's all I can afford? Is there an official benchmark bar chart between the two?
Paul,
Hi....The Dimension 5000 is definitely an older machine, but depending on what you plan to use it for and assuming everything still works ok, the PC can still be useful. You can still get parts for the machine, especially if you go to Ebay. www.ebay.com
For everyday computing like word processing or spreadsheets, it should still work ok, but will be slower than a newer machine.
Jul 15, 2015 | Dell OptiPlex GX280 PC Desktop
Service management software
Some of the best open source ITSM tools are listed below
  1. Spiceworks
  2. FreshDesk
  3. C-Desk
  4. Sysaid
  5. Zoho
  6. Comodo One
  7. Bugzilla
  8. OTRS Free
Dec 19, 2013 | Buffalo Technology Computers & Internet
Roku worked now won't connect
Unfortunately that model of modem does not support assigning DNS.
Call 18009218104 option 2. This will get you tech support. Ask for a new modem. They should give you a Netgear 7550 for no extra charge. If they want to send you to another department tell them that there is no need for that and to ask their supervisor how to send up a modem upgrade order. It may take a day or two for you to receive the new modem. Once you have the new modem and it is fully set up you can assign the DNS by followiing these steps.
Browse to 192.168.254.254
Log in with username: admin and the password you set when configuring the modem (If the modem is configured by Frontier then the password will be also be admin like the username.)
Click My Connected Home at the top
Click Network Connections on the left
Click the Action button next to Broadband Connection (DSL)
Under the VCs sections Click the edit button to the right of where it says PPPoE or PPPoA.
Here you will find a spot for DNS Primary and for DNS Secondary
Enter the numbers given to you by Roku in these to spots.
Click Apply.
And you are done.
If you have any issues with following these steps just call 18009218104 Option 2. This will get you Frontier tech support. Ask them to show you were to assign DNS servers for the PPPoE connection in the modem's firmware. They will guide you through it.
If they claim they cant help you with that it probably just means they dont know how. There are definitely people there who do know how and can help you further. Tell them to ask someone else there.
If you have any additional questions for me please feel free to ask by replying here.
Please note that all information here considering Frontier's modem replacement policy assumes that you are not behind on your bill or have a payment plan and could change at any time. The information I have given is based on what the policy in place as of 5-7-2013 at 10:19pm Central Time
May 08, 2013 | Siemens Gigaset Se567 54 Mbps 4-port...
A department store plans to upgrade its IT infrastructure to support a new order-processing application with rich features. The store currently uses eight stand-alone computers when customers check out....
HI
i have seen your requiment
we have a devloped software for online orrder appilication along with all kind of report and up-gration of order procesing we have allready implimete in company in india
if your you would like to know more about then please contact us
M/S IT INN Enterprise - india
my email is (m42153@gmail.com) or (info@itinn.co.in)
May 31, 2010 | Microsoft Windows XP Professional
How to set up the internet for the hip top 3 please some one help please...
it depends on what carrier you have. usually all you have to do is call them, go to there sight, or actually go to the carrier store. there will be different rates, for certain carriers you cant just get internet, you must either get an entirely new plan, or make a huge plan upgrade. call, email, or go to your local wireless carrier for details. if i did, i'm happy I could help! :)
Sep 04, 2009 | Sharp Lands Phones
NCC assignment
the network support infrastructure required to utilise
Network Computer
Jan 24, 2009 | Gateway Essential 400 PC Desktop
Service plan
Greetings sisystem,
As long as you are within your return period of 30 days on the product, you can call 1-888-BestBuy™ and ask for the Consumer Relations Department. Once there, please tell the person who answers the phone you would like to purchase a "walkaway" service plan on your unit. There is a 2 year and a 4 year option! The representative should be able to process your sale for the service plan as long as you have a major credit card. It can even be placed on your Best Buy™ card!
I hope this helps!
Thank you,
Dorothy
Go Ahead. Use Us.
May 13, 2008 | Samsung DVD-V4600 DVD Player/VCR
I ordered Nero 8.2.8. I am trying to set up the program on my pc. The program keeps asking for a serial # but I don't have one. The serial # was not sent to my email address.
Did you order it through the Ahead site? Follow the link below. You'll need your email and password to login. If you don't have a password just click on forgot my password and they'll give you a new one. Once you're in, find the link that says resend confirmation email. This should have your serial #. If you did not order from Ahead or this doesn't help (such as receiving another email without your serial # let me know and I'll be happy to help you all that I can. If this solves your problem please rate as fixed. If it doesn't, don't rate it yet and just add a comment letting me know what's going on. Thanks.
https://shopping.nero.com/cgi-bin/pages/login/ml=EN
Apr 26, 2008 | Computers & Internet
Need to increase hard drive and memory
Easier said than done...
If you have the specifications of your current memory, you should be able to find higher capacity compatible RAM at any computer or office supply store. If you can find the right kind, then you simply need to buy it and put it in. Older and more rare types you may need to order via internet.
Upgrading the hard drive can be a tough process. Some drives used to come with upgrading software right on the drive (like Maxtor for example) but they don't seem to do that any more. So, besides buying the right type (either PATA or SATA connector) drive, and the size you want, you have to check your system specs to see how large a drive you can put in, older systems are limited. In addition, you would need to buy hard drive duplicating software, like Powerquest Drive Image.
To see the process of upgrading a drive, I found a page for you, as the details are quite extensive...
http://www.dansdata.com/sbs27.htm
Apr 21, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
716 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
