Question about Chapin 2 Gallon Spectracide Sprayer
The air relief valve on my two gallon spectracide sprayer leaks and the sprayer will not hold any pressure for any length of time.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
Buy a new one not worth reparing
Posted on Jul 27, 2010
What is the mixing ratio to 1 gal of water?
Their products are here, but they don't tell you the usage. It has to be on the label by law. The rear label usually lifts up to reveal a small book of three or four pages. If it isn't there, contact the company via the website.
http://www.spectracide.com/Products-and-Solutions/Lawn-Weed-Killers.aspx
The does have label details here
http://www.spectracide.com/Customer-Help/Labels-and-MSDS.aspx
For the Spectracide it is 1/2 oz to a gallon, but it depends on what type of grass you have. I will copy and paste the label details, but I doubt the format will stick, but it is all there.
Ounces of Concentrate to Use for:
St. Augustine*,
Bahia,
Centipede
2/3
2 2/3
13 1/3
21 1/3
32
32
1/2
16
250
1,000
5,000
8,000
Sq ft
to be
Treated
Bluegrass,
Fescue, Rye,
Zoysia
Gallons
of
Water
*DO NOT USE ON FLORATAM VARIETY OF ST. AUGUSTINEGRASS IN
FLORIDA.
HOW MUCH TO USE
SPOT TREATMENT
To spray small areas or individual weeds, use a pressure sprayer for better
control. Do not use a hose-end sprayer. Mix as directed in table below. Shake
well before spraying. Be certain to wet each weed.
ENTIRE LAWN
PRESSURE SPRAYERS
Measure amount of concentrate from chart below into sprayer tank and dilute
with 1 gal of water. Close tank sprayer and shake well before spraying. Use a
spray pattern that gives small spray droplets without any ne mist to treat
250 sq ft.
HOSE-END SPRAYERS
"CONCENTRATE ONLY" (DIAL) SPRAYERS
1. From the chart below, determine amount of concentrate to be applied for
each 250 sq ft of lawn.
Bermuda,
Bentgrass
St. Augustine*,
Bahia, Centipede
1/2 - oz
2 - oz
2/3 - oz
2 2/3 - oz
1 - oz
4 - oz
1/2 - oz
2/3 - oz
1 - oz
Grass
Type
Ounces in
Sprayer
250 sq ft
1,000 sq ft
250 sq ft
1,000 sq ft
250 sq ft
1,000 sq ft
Area
Treated
Dial
Setting
Bluegrass, Fescue,
Rye, Zoysia
FLORIDA.
2. Fill sprayer jar with enough concentrate to cover area to be treated. Do not
add water to sprayer.
3. Set dial on sprayer to the setting from the chart below.
4. Attach sprayer to hose. Extend hose to the farthest area of lawn to be treated
and work back toward faucet so that you do not walk over treated areas.
Apply evenly to lawn.
EXAMPLE: To treat 1,000 sq ft of fescue lawn, add 4 - oz of concentrate to the
sprayer with sprayer dial set on 1 - oz. Check the directions you received when
you purchased your sprayer for further details on the proper use of your dial
sprayer.
"CONCENTRATE-PLUS-WATER" SPRAYERS
For sprayers that require the addition of water as well as concentrate prior to
application:
1. From the following chart, determine amount of concentrate required to treat
2. Pour concentrate into sprayer jar to the required "- oz" level.
3. Then add the appropriate amount of water to the "gallons" level. Replace
sprayer top on jar and shake well before spraying.
treated and work back toward faucet so that you do not walk over treated
areas. Apply evenly to lawn.
EXAMPLE: To treat 1,000 sq ft of fescue, pour in concentrate to the 4 - oz mark
and add water to the 4 gal mark. Check the directions you received when you
Lawn Weed Killers
Apr 18, 2016 | Spectracide Bug and Weed Killer for Lawns...
How do you refill?
Remove all pressure by keeping the hose open until no pressure is left. place pump handle down toward tank. Turn count counter clock wise to unscrew. Take assembly out of tank then fill tank. Reinstall in reverse order.
https://www.chapinmfg.com/sprayers
May 24, 2014 | Chapin 2 Gallon Spectracide Sprayer
Is the reed valve part of the pressure switch
relief valve should only open in a over pressure condition. If it is opening prior to reaching pressure ....replace it.
May 21, 2012 | Air Tools & Compressors
No pressur in my home and garden sprayer
You have a leak. First ensure the pressure relief valve is closed. You can try spraying soapy water on the outside while pumping it up, and look for bubbles. The one way valve might be leaking, too. Good luck.
May 21, 2012 | Chapin 2 Gallon Spectracide Sprayer
Can I find the nozzle tip for this sprayer at Home Depot or Lowes?
Yes. Home Depot sells Spectracide sprayers, hoses, and tips. Typically they are by the lawn mowers and rakes.
Jul 16, 2011 | Chapin 2 Gallon Spectracide Sprayer
I would like to obtain the nozzle and tubing for Chapin Spectracide pump sprayer. The containers is in good shape. Who sells just parts
You can get the parts for those at home depot and lowels, I just bought one a couple of weeks ago for mine, most are adaptable. Also Sears seems to have good supply as well. Thanks Mike from Fixya
Jul 07, 2011 | Chapin 2 Gallon Spectracide Sprayer
Roundup 2 Gallon Sprayer -- must have exceeded pressure. Now it will not hold ptessure. Gasget seal seems OK is there any "reset"
There is a built in relief valve that is not keeping the pressure in...
these are very cheap plastic valves and so there probably is no fixing it...
I would buy another roundup with the sprayer and then dump the contents from the bad one into the new one ... the stuff does not go bad...
heatman101
Sep 18, 2010 | Garden
Pressure relief valve
The pressure relief valve only leaks when there is excess pressure in the system, possible causes could be excessive static pressure, overheating, faulty pressure vessel or undersized pressure vessel.
Apr 11, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
No spray at all, line clean, hand valve not opening
usually have to take it apart! Try the lime away products for bathrooms to get rid of the hardened product left in the line. I don't remember any filter being on this model or any easy way to disassemble. Hot soapywater might be another choice.
Dec 29, 2009 | Chapin 2 Gallon Spectracide Sprayer
COMPRESSOR RUNS, FILLS TANK, AND THEN LEAKS OFF ALL THE PRESSURE. WHAT IS GOING ON?
Is the air "leaking" from the pressure relief valve? If so it is either faulty or it is doing what is supposed to do. The pressure relief valve is there in case the pressure switch fails.The tank could blow up if the pressure switch fails, so the pressure relief valve is there as a secondary measure to insure the tank does not receive too much air pressure. Assuming your gauge is operating properly, watch the gauge to see if it reaches the maximum pressure (check your manual to find the maximum PSI) or if it goes over the maximum pressure. If it goes over the maximum pressure then replace the pressure switch. If it the motor stops at the maximum pressure, replace the pressure relief valve.
Jun 07, 2009 | Dewalt D55250 Factory Recondition Heavy -...
Chapin 2 Gallon Spectracide Sprayer Logo
330 people viewed this question
Top Chapin Garden Experts
Nick Olsen
ray gallant
Are you a Chapin Garden Expert? Answer questions, earn points and help others
