Question about Maytag 24 in. MDB8600AW Jetclean II Built-in Dishwasher
Unit will not start, normal wash lamp wont lite up
Maytag model MDB8600AWB The other lamps will lite up, cant run diag code, Turned breaker off for hours, still same problem unit will not start.
  • Ron Jun 02, 2010
    thank you for a place to start
    President:
  • 949 Answers
It sounds like you may have a failed key pad, the key pad control is part of the console.
The other component that may have failed is the control board, to determine which one has failed, you can do a test on the key pad. Below is the key and which terminals would be read with the ohm meter. You will hold the ohm meter leads on the pins that go to the console, then push the corresponding button on the chart, you will get meter movement if the key is good. Let me know if you need assistance with this test.
Posted on Jun 02, 2010
Power is to the dishwasher put it wont turn on
hello first check yor breaker make sure not tripped.
next check for lights in your panel.
perform a normal wash if no luck
next perform a service diagnostics cycle.
note sercice diags. works on Maytag MDB7600 series.
press the following keys in less than 6 secs.
HeatedDry > Normal > HeatedDry > Normal
to advance machine cycles press Start/Resume key.
blessings,
e.
May 22, 2014 | Maytag Dishwasher
Mitsubishi hc3000 wont start
this is a problem in your power board.
thi unit is getting OFF due to heating problem
Jun 29, 2008 | Mitsubishi Office Equipment & Supplies
Inverter manuals
Model No Required below Model No AH-X18MEV Self diagnosis mode given
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
• If the power cord is unplugged or the circuit breaker is turned off, the self-diagnosis memory is lost.
AUX
Operation lamp(red)
Timer lamp(orange)
Super jet lamp(green)
Oct 12, 2013 | Sharp Heating & Cooling
LG RU-60SZ30 when turning the tv on the power lite changes from red to flashing amber, flashes 6 to 7 times then turns back to solid red. The tv never actually starts. Before this the tv would randomly...
I have read another solution which may indicate the light engine has failed and will likely need replacing. The cost is quite expensive. $1500 range and apparently the part is no longer available from LG. Best you might do is get an estimate to repair just to be sure.
Dec 04, 2010 | LG RU-60SZ30 60" Rear Projection...
What is code H4-01
H4 01 Heat roller low temperature
detection (HL2)
•The set temperature is not reached within
the specified time (normally 3 min) when
warming up or resetting from pre-heating.
•Under the ready state.
(An input voltage of 1.21V or below is
detected 5 times continuously.)
Cause
thermistor trouble
Heater lamp trouble
Control PWB trouble
Thermostat trouble
AC power trouble
Interlock switch trouble
Use DIAG (SIM5-2) to check the heater lamp
Blinking operation.
If the heater lamp blinks normally:
Check the thermistor and its harness.
Check the thermistor input circuit in the
control PWB.
If the heater lamp does not light:
Check for heater lamp disconnection and
thermostat disconnection.
Check the interlock switch.
Check the AC PWB and the lamp control
circuit in the control PWB.
Use DIAG (SIM14) to cancel the trouble.
Jan 25, 2010 | Sharp Digital Imager AR-407 Black and...
Code h4-01 it displays code right away, will not do anything else
Clear all the paper out of your fuser (don't use a sharp object) and anything in the paper path before and after it. Clear the code with pound-star-C-star-14-start-yes-CA. If it still comes back you have a broken sensor or sensor flag in your fuser.
Jan 18, 2010 | Sharp AR-M237 Copier
When I was unscrewing a burnt out hood lamp on
I would not use the lamps. Sounds like there is a shortage in the wiring for the lamps. They lamps should run together, and if one of the sockets have a short or burned wire it will not let it complete the circuit. This could be a fire hazard, so I would replace the whole microwave. It would be more trouble to tear it apart and find the exact problem than it's worth.
Jan 04, 2010 | Maytag MMV4205 Microwave Oven
Lamp wont stay on. fan continues to work after lamp goes out. When power is turned on light comes on and fan starts working. with in a second or so the lamp turns off but fan continues to run.
Most likely you need to replace the lamp. It is possible the your lamp ballast is failing as it scales back to low-voltage DC drive, but more often than not this problem is traced to the lamp needing to be replaced.
Mar 29, 2009 | Office Equipment & Supplies
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Service Code of H4-01
H2-01 Fusing Temp. to low
Use DIAG (SIM5-2) to checkthe heater lamp
Blinking operation.
If the heater lamp blinksnormally:
Check thethermistor input circuit in the
control PWB.
If the heater lampdoes not light:
thermostatdisconnection.
Check the AC PWB andthe lamp control
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKINGON MACHINE***
You have to reset fuser errors with simulation 14.Push P * C * then 14 then Start (the button you use to make copies)and it should reset the code. If not then replace the fuser.
SM5-1 should turn the lamp on. If lamp blinks on and off it is thethermistor, if it does not it is the lamp, but check the contacts onthe lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defectivereplace.
Jan 25, 2009 | Sharp AR-M237 Copier
Maytag 24 in. MDB8600AW Jetclean II Built-in Dishwasher Logo
91 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
