Question about Frigidaire ATF6000ES Front Load Washer
E 20 error code cleaned out the rubber boot thing it was stopped up put it back together still not working right getting e 20 still
  • 327 Answers
  • Get the washer laying on it's side and using the access hole on the bottom carefully remove the screw clamp holding the large hole of the rubber housing to the tub drain (it will be obvious all other clips are green compression clips).
  • Carefully work the strainer out of this flexible rubber drain housing through the large hole.Clean it out and replace you will be good to go. Also remove all the hoses and check for a buildup of gunk. Hope this will fix your problem.
Thanks
Posted on May 31, 2010
Panasonic how to clean rubber rollers
What I have done in the past is take a piece of 8 1/2 x 11 paper card stock of thicker than 20 lb. Put alcohol on bottom part of paper and start feeding it in BUT HOLD ON TO IT DO NOT LET IT FEED THRU. The friction will clean rollers. You'll get a paper jam of course. Reset and do it again. Has always worked for me.
Oct 11, 2014 | Panasonic Office Equipment & Supplies
Error code 20
Is it an E20 error code? The E20 error code is usually something clogging the pump system follow these steps to check. From the bottom and back panel you can access the drain hose/pump/coin catch. With a pair of pliers you can remove the clamp holding smaller end of the rubber coin catch to the tub, with a Phillips screw driver you can remove the larger clamp of the rubber coin catch to the tub. From the back panel you again use your pliers to remove the clamp to the drain line, and finally with a Philips screw driver remove the two screws holding the pump to the bottom of the washer. Oh yes, do not forget to unplug the wire from the pump. Now pull the pump out with the black rubber boot still attached. Mark the orientation of the pump to the boot with a sharpie pen, and remove the last clamp. Now look inside the black rubber boot and gently remove the plastic basket inside and remove any thing that does not belong, reassemble ant test.
Nov 25, 2013 | Frigidaire Washing Machines
My dishwasher stops annd displays E1 error message on panel
Hello there and welcome to fixya
The E1 error code is a fault code for the pump meaning that the pump may be clogged or it may have failed all together so you are going to want to first unplug the machine or disconnct the power to it the code will never go away if there is power going to the unit ok?
check to see if there is a little plug looking device that has a part that you can take out to clean if so great clean this screen and remove all of the debris then put it back together and try it again
If it comes back again you will have to get to the pump itself and remove it and visually look at it first to see if there is any cracks or obvious things here
Next dissassemble the entire thing to see if it has parts inside it that are bad if so replace them you can get parts from your local appliance dealer or the manufacture
And lastly simply replace the pump if all of the above does not work ok
Hope this is very helpful for you
Best regards mike
Sep 16, 2011 | Dishwashers
The remote got moisture from the air conditioner, and buttons 1-6 stopped working. I cleaned the inside with purel and a soft cloth. A week later, 7-9 stopped working. I'm on $670 a month...
Take the remote aparts,take some Q tips dipping it in with some rubbing alchahol.Clean the remote PCB board and the battery - + connections and wait like about 20 mins.Than put the remote back together again,than the thing should work fine.If not CPU it dead,the thing is a paper weight.The universal remotes look in ur owner manuals for codes to program ur tv make and model codes,for it to work.If not try website like Remodes.com for might have some more codes belong to ur tv make and model to tries.
Dec 10, 2010 | Televison & Video
Frigidaire GLTF2940ES0 Front Load Washer Washer won't drain, makes humming sound, did diagostics received error code E23 which is linked to drain pump relay and manual I found online said control panel...
before buying anythings, you have too check the manual too see if you didn't put it in factory test mode by accident. the manual is suppose to be under the top,(two screws on the back)
After that, second thing you have too do, remove the back (six screws) the drain pump is located under the the baril. there is a black rubber tube attached to it. In this tube, there is a basket that keed hard thing away from the pump. In my case, some hair pin pass the basket and block the pump rotor. The computer of the machine told me it was Error E23 but after cleaning, everything work like new!!
So try cleaning it yourself, it is easy even with basic skill. You will need a star screwdriver, a scare-screw driver, pliers.
Remember, better have the machine empty before doing anything, because you'll be working on the DRAIN LINE.
Hope that help someone.
Vincent D.
Jun 02, 2010 | Frigidaire GLTF2940E Front Load Washer
Keys: r, t, f, g, v, and b have stopped working. Previously they started working after about 30min, but now have stopped completely. I have cleanned the keyboard w/ compressed air and they still don't...
usually keyboards are pretty simple to clean once you take them apart.
There is a rubber (normally) surface with some black conductive poins under each key. un screw the keybard clean the contacts and put it all back together.
Note: be careful certain keyboards do not have a way of "holding" the keys in place once you take them apart. So if you arent in the mood of putting a big puzzle back together and losing 30 minutes rearranging keys (wheres that damn ~ go again?) be very careful as you pull it open.
Apr 29, 2009 | Fujitsu FPCKB41A1P Keyboard
Freezes\stops at the bios start up screen...
hi, there is a common fault on this model, to do with a bga chip (ball grid array) just underneath the touchpad. try appling a small a mount of pressure with 2 fingers just above the touchpad on the plastic between the keyboard and touchpad while it is booting . if you get any further response from the laptop then this is your problem. i have this model and same problem occurred i took the unit apart and placed a rubber wedge ontop of the intel BGA chip. put it back together and with the pressure applied from screwing the case back together hey presto works fine. hope this helps.
by the way please dont attempt to open the laptop unless you are confident you can put it back together :-)
Feb 20, 2009 | HP Compaq nx6110 Notebook
Error Code E1
I had the same error message E1 at 10 seconds according to the LCD display on an older Treadclimber TC1000. I called Bowflex 1-800-792-6784 and first thing they told me was to check the drive sensor on the back left corner of machine. It is two wires connected by 2 white connectors that snap together. The end of the sensor has a rubber cap that is supposed to be approximately 1/8 inch from the drive pulley. The rubber cap plugs into a small hole within the "firewall" of the drive pulley, but the end of the cap does not actually touch anything. They can email you a picture of it. If it ever gets knocked loose, the machine will register this e1 error, in some cases- hope this helps.getattachment.aspx&hm__qs=file%3d3d2f2ee0-2668-46ea-b32c-db049d56cb37.jpg%26ct%3daw1hz2uvanblzw_3d_3d%26name%3daw1hz2uwmdiuanbn%26inline%3d1%26rfc%3d0%26empty%3dfalse%26imgsrc%3dcid%253aimage002.jpg%254001c99c08.13bd6320&oneredir=1&ip=10.12.128.8&d=d6608&mf=0&a=01_0b590aaade5e800af268d347750ab151eca93264be20cd9ce2166e583b18cfe9
Jan 24, 2009 | Bowflex Treadclimber
Error code ER then UO any ideas?
So far so good. I fixed mine by removing the vent and even though it says no repairable parts I disassembled it then removed the rubber gasket and cleaned it with a brush under hot water. I then cleaned the plastic ring it seals against. Next I removed the spring and stretched it to make it about a quarter inch longer and then reinstalled the spring then the rubber gasket and then closed up the unit. So far it is working fine. I suspect the real problem is that there is a tiny sensor that needs to be covered when the vent is closed. If this is not covered the uo error code is generated.
Apr 22, 2007 | Frigidaire 24 in. PLD3465REC Stainless...
Frigidaire ATF6000ES Front Load Washer Logo
57 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
