Question about Refrigerators
Freezer frosts up, frzer & frig loose temp. Need to defrost freq
Freezer frosts up, frzer & frig loose temp, I defrost, then problem begins again. Intervals between frost/temp problem getting shorter. Last year, had to do this for 1st time, then several months, later, then fewer months, etc. Defrosted last WED and now MON problem again. Cannot afford repairman!
  • Refrigerators Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
RefrigeratorFreezer frosts up, frzer & frig loose temp. Ne - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 01, 2010
MY LG FRIG MODEL # LRSC26923TT IS SHOWING ERROR CODE DH
poor defrost - more than one hour since defrost began and temp has not reached 46F. you will likely begin to notice frost forming on back of freezer. pull back cover (frosted area) and ck the temp sensor pack. (there is a sensor pack that contains a bimetal and sensor in one plastic pouch. do not open it but ck at its connection. the orange wires are the sensor 77K-9k ohms and the other two are the bi metal, open or closed, open above 50F.
Sep 17, 2012 | LG LRSC26923T Side by Side Refrigerator
I noticed in the mornings that the temp on my freezer and frig will increase a few degrees then go back down. Then occasionally here and there during the day it will go up a little again. Sometimes the...
if it is a frost free the temp will vary room temp and the warm food you put in will affect it or the electronic controler is not operating properly frost free also defrosts its self in a 24 hr time frame this will affect the flux temp
Nov 07, 2011 | Refrigerators
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Frigidaire frig model FRT18SGAQF Serial BA44035278. Freezer works fine frig does not cool. Both have own temp control. How do I repair.
First your Model# is FRT18S6AQF :)
Now you need to open the freezer section back wall to see if it have frost all over if not :( its a sealdsystem problem... but if you have frost see if the fan working , if not your fan is bad , beside that there ar 2 othe unit that need to be check
Defrost heater kit and the Defrost thermostat you can by them at sears part if they bad any other Q? visit my company web site :) www.911servicetoday.com
Dec 30, 2009 | Refrigerators
Hotpoint frig,top freezer motor runs contiunally, thermostat set in middle of temp. control. side of frig stays cool all time.[does not get warm as it used to] is defrost thermostat bad or timer?
niether. is there frost on back wall of freezer? if no look behind back wall and see if there is frost on all the coils when running. if less than 80% is frosty...freon. or is there frost covering back panel..if so then defrost problem would be correct. but side would be warm so I think not.
Jun 12, 2009 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
FRESH FOOD SIDE OF FRIG NOT COOLING
i would take the back freezer panel off and see what kind of frost pattern your coils have.they may be frosted over and the begining of a defrost problem.
Mar 11, 2009 | GE GSH22KGM Side by Side Refrigerator
Auot defrost problem?
cleaning the condensor is nothing to do with evaporator freezing up. keep an eye on it - you may have a problem with the defrost cycle. problem can also happen if freezer door has been left open
Jul 21, 2008 | Amana AFD2535DES French Door Refrigerator
My reach-in frig. building ice around the coil & then the temp. starts rising
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 28, 2008 | Refrigerators
Frig won't cool, freezer works fine
Defrost unit completely. You're frosting up. Then, avoid leaving the door open, leaving liquids and food uncovered. Clean condenser coils. If it happens again, you need refrigerant.
Jun 09, 2008 | Refrigerators
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
89 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
