Question about Garden
I have a poulan 2050 chainsaw good spark i try to adjust carb 1 and half turns it wont start what is wrong with it
    Problem Solver:
  • 4 Answers
See http://www.repairfaq.org/samnew/lmfaq/lmadjc.htm.
Posted on Jun 01, 2010
How to tune the carb on 1950le poulan chain saw
H I ONE quarter turn L one turn then adjust the idle.
Oct 10, 2014 | Oregon Poulan/Poulan Pro 12" Chain Saw...
Why 2-Cycle engine poulan chainsaw will not idle
It sounds like you have an air leak from carb to carb adapter.
Jul 24, 2014 | Poulan 2050 2055 2975 2150 2155 2175 Air...
I have a poulan woodshark i traded for a old tv it has great compression and great spark but it wont start i think they might have messed with the carb what should i do thanks
Turn the carb adjustment screws all the way in and then turn them 1 full turn out and try that. If it starts it will probably require some fine tuning or some tweaking to get it to start. I also suggest you clean and kit the carb just to you know it has a good diaphragm and no clogs
Jan 17, 2013 | Poulan Garden
Poulan 18" wildthing chainsaw wont start
have you tried spraying Starter fluid into the Carb to see if it will at least try to run and verify you have good spark?
Dec 05, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan saw wont run
Clean the muffler spark arrestor screen and check the cylinder port for carbon build-up at the upper edge. Try presetting both carburetor H and L adjustments (from lightly CW stops) 1-1/2 turns CCW each. Start the engine and allow to warm up. Pull the throttle wide open and adjust H CW until the engine speed increases, but still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L for smoother running, yet allows the engine to 'follow the throttle'. Set idle speed to keep the engine running, but doesn't try to move the chain. You may have to look closer at your carburetor if the above doesn't help. Go to:
http://www.drystacked.com
for an excellent article (but poor pix) on Walbro carburetors, but related to most all 2-stroke carburetors. Hope this helps!
Feb 18, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I need to know how to adjust carb on a Poulan chainsaw Model number 2050 Preditor
set both jets out 1 1/2 turns and then start it up and fine tune it from there. This will start you out right close to excellent. hope this helps you
Nov 02, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have predator and wont start
Does it have good compression? Is the muffler plugged? Is the spark plug wet after trying to start? If not, try a little starting fluid in the plug hole, and try to start. If you get a few pops, try resetting the carburetor H and L jet screws each 1-1/2 turns out from CW stops. It should run with these settings. Warm the engine up, then apply full throttle and adjust H CW until it runs fast, but 4-stroking. It should smooth out when cutting. Next, set idle L for fairly smooth idle, yet follow the throttle without lag. Adjust idle speed just below chain movement. Hope this helps.
Sep 10, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Require high and low carb settings for Poulan 2050 with WT 324 carb. It has no primer, so have bypassed primer and run lines direct. Has heaps of spark but will not fire.
You will find that saws of recent production allow very little if any adjustment for the consumer. The carb will either have limiters which allow you less than one turn of adjustment or they require a special tool to make the adjustment. You will need to take it to a dealer to have these adjustments made. This is your government in action protecting you from that evil pollution your chainsaw spews out.
If you are able to adjust, then gently seat each screw and open 1 full turn. This should allow the unitto start and you can adjust from there. If it will not start you probablu need carb repair or replacement or you have other problems.
May 09, 2009 | Poulan Garden
I have a poulan 2050 won't stay running
Hi, are you pumping the primer, till it's full, before starting?
Mar 23, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
2375 ''wild thing'' poulan saw hard starting after carb rebuild
Through trial and error on fairly new Poulin Pro, found that the usual 3-half turns for both high and low was too much (flooded) (Used to be good starting point on weed eaters years ago. So, turned both all the way in, and only backed out 1-full turn. (2-halves) Saw fired up perfectly, and ran wide open just fine. Try that.
Nov 13, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
105 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
