Question about Friedrich QuietMaster SM18J30BR Air Conditioner
How to remove front cover for cleaning
I have a Friedrich QuietMaster SM18J30 window air conditioner and want to remove upper air vent section for a good cleaning.
  • 960 Answers
I don't know too much about your particular make / model but most window units have a 1 piece front cover which is usually held on to the main cabinet with 1 or 2 screws at the sides and 1 or 2 behind the filter panel. You will need to remove the front panel to remove the vents as they are usually fitted from behind the panel.
Posted on May 26, 2015
4 Suggested Answers
  • 744 Answers
SOURCE: REMOTE CONTROL
Start here:
http://www.friedrich.com/
Posted on Mar 28, 2009
roniecon
  • 6826 Answers
SOURCE: Friedrich AC through the wall ac leaking water out front vent
pull it out and check for packaging left in ac unit, and make sure drain is clear and large enough for water flow ,,,go ahead and tilt ac unit more and see if that doesnt do the trick
Posted on Jul 04, 2009
heatman101
  • 43501 Answers
SOURCE: Friedrich QuietMaster SS08J10R Air Conditioner is not working
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
My Friedrich QuietMaster Series KS15L10 115V model will being to blow cold air and then after 5 to 10 minutes will trip the circuit breaker. We recently had a heat wave for about 2 weeks in which the unit...
Hello
Yes the northeast had temps that went past the limits of modern a/c.
Try cleaning the outside fins and coils.
Spray a product called simple green on the fins while unit is off.Leave on for 5 min.
Then rinse off with a hose.
This should keep your compressor running cooler.Also clean any filters in the inside unit.
Aug 03, 2011 | Friedrich QuietMaster KS15L10...
Where is the drain hole on my frederich quietmaster wall air conditioner?
Hello, if there is no drain hole under the unit then it uses the fan blade to sling water on the condenser to evaporate the condensate. Some window units are made this way instaed of using a drain hole.
Jul 12, 2011 | Friedrich QuietMaster KM24L30 Wall/Window...
Where is the vent on my Friedrich AC unit? I don't know how to close or open it.
the fresh air vent open close tab should be located somewhere along the vent louvers look at the bottem of them starting from right to left its their use a flashlight to see it good luck ..let me know /joe/
Aug 25, 2010 | Friedrich QuietMaster RS10J10 Air...
I need a replacement for my Quietmaster window air conditioner
Wal Mart, Target, Sears, Lowes, Home Depot etc. Replacements are available all over the place.
Aug 02, 2009 | Friedrich QuietMaster SS12L10 Air...
The switch on my Friedrich Quietmaster panel is
you can find them at any A/C supply house for window unites or on line. try Sears
Jul 14, 2009 | Friedrich QuietMaster SL36L30 Air...
Jul 04, 2009 | Friedrich CP12C10 Wall/Window Air...
Friedrich RS10J10-C: Only half the coils are chilled...
If the evaporator coil is only half coated with water, this means it is low on Freon. You need a repairman to fix the leak and add Freon, but this costs way over a hundred dollars.
Jul 23, 2008 | Friedrich QuietMaster RS10J10 Air...
Cleaning
My husband figured out that the grilles themselves click out--not the whole assembly. Now he is going to have to figure out how to click it back in!
Jul 01, 2008 | Friedrich QuietMaster Electric SS10J10AR...
Friedrich QuietMaster SM18J30BR Air Conditioner Logo
348 people viewed this question
Top Friedrich Heating & Cooling Experts
Bill Long
Michael Vincent Cruz
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
