Question about Fisher and Paykel GWL11 Top Load Washer
Will not finish cycle - Fisher and Paykel GWL11 Top Load Washer
  • 1 more comment
  • chrizzoclark Jun 01, 2010
    Thats not much explaination..Where did it stop..what part of the cycle..did it stop with water in it..does it fill up..does it pump out? try to give just a tiny bit of information it can help sometimes.
  • luisa_sgro Jun 02, 2010
    when you say it does not finish the cycle, does it stop and beep with a series of lights on?if it does what lights are lit up.starting from the left please tell me if it the 3rd 4th etc on that line of lights.
  • mnelson285 Jun 02, 2010
    the 3rd and 4th wash lights are still on whuil it is beeping
  • 159 Answers
This is fault code 48 wich means the hot & cold inlet valves cold be faulty..But first check that both of your taps are turned on.most of the time someone has turned off the taps on the wall without telling you..The computer board has sensed that no hot or cold water is coming in.Its just unusual that both valves are faulty at the same time.the valves can be gotten to by unscrewing the 2 phillips head screws the the control box.take the lid off first.the valves are to the left.unplug the blue wire clip the the valve & the same with red one.the valves need to be tested for a circuit they should read somewhere around 63 ohms.If they are ok then i'm sorry but it's probably going to be the computer board.can you let me know what you come up with,im interested to know the outcome.thanks,Chris
Posted on Jun 03, 2010
    Problem Solver:
  • 5 Answers
There is a service summary with error codes under the control panel in a zip lock bag. My pump was being blocked by a bobby pin. It has to pump down before it will start the spin cycle. Removing the basket allowed access to the pump and I was able to clean out the suction. I was amazed by the scum build up under the basket. I will now remove the basket yearly to clean under it.
Posted on Jun 02, 2010
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
Ld 14aw3
Most dishes in any dishwasher are still wet when cycle is finished. The heat built up in the dishes during the washing cycle is what causes the water to evaporate when the machine stops.
If you want to accelerate the evaporation, simply open the door very slightly so that as the hot air escapes it causes the dishes to dry quicker.
Aug 04, 2014 | LG Dishwashers
Can anyone help me with my washing machine (aeg lavamat 66840 l).After choose a washing cycle and the timer displays 2.20 h , the washing cycle finishes in 1.45 h !?Any ideas?
HI HAVE YOUR PUMP FILTER CHECKED IF OK CHECK HEATING ELEMENT ..SEE IF ITS IN CIRCUIT.. THATS WHAT NORM HAPPENS IF THESE ARE NOT HAPPY.BET OF LUCK.
MARK 07779933829
Nov 22, 2011 | Washing Machines
Water building up during the dry cycle and clothes getting wetter
1) Make sure wash cycle is 100% finished (sometimes dryer will start before - usu on synthetic cycle & allows water to continue flowing in)
2) Manually start the dry cycle after you ensure wash cycle is finished and push in the wash cycle button.
Hope that helps! If not, you may need a new control module (I did - hope you don't!)
Apr 19, 2010 | Haier XQG65-11SU Front Load Washer / Dryer
Won't finish cycle
The water may not be getting hot enough in the rinse cycle. Usually it needs to heat to 140 to 160 degrees for rinsing. If the heating element is not working the water will not heat. If your DW has a Sanitary setting it will be calling for the water to be 160 degrees. If you have the option to override the Sanitary settin, try that to see if the rinse cycle will finish with cooler water.
Mar 27, 2010 | Dishwashers
I can't open the door of my washing machine it is a front loader lg intellowasher 7 kg wd8013c please help asap
FOR ANY REASON THE WASHER MACHINE DIDNT FINISH ITS CYCLE!!! AND IT IS A SAFETY THAT IF DOESNT FINISH ITS CYCLE THE DOOR WONT OPEN!!!!
I HAD ONE LIKE THAT AND I BROKE IT APART!! AND I SAW THE WATER PUMP WAS THE PROBLEM SO I CHANGED IT AND PUT IT BACK TOGETHER AND LET FINISH ITS CYCLE AND OPEN THE DOOR!!! AND STILLS RUNNING!!!
Oct 05, 2009 | Washing Machines
Door will not open on my WM1480FHD after wash
Hi ii_goldie,What about the RINSE cycle... maybe the washer knows the "full cycle" is NOT finished.
The washer will display DONE... and make the door available to you. If not the cycle may not be finished. OR, turn it off, however, DON'T open the door if your machine has not drained all the water out, allow the system to finish.
Aug 19, 2009 | LG Washing Machines
My washing machine will not drain. It finished all the cycles but didn't drain after the rinse cycle. It still spun afterwards with water still in it.
Aug 10, 2009 | Whirlpool Washing Machines
Kenmore dishwasher not draining when finished full cleaning cycle
sounds like a cycle timer problem. Look for a loose wire on the cycle timer. If yours is a digital timer, it is a board issue. Sorry.
Aug 03, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Bosch axxis door won't open
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
May 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
99 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
