Question about Tascam HHB DA30 Tape for DA-88
I am having problems with my Tascam Da-88 8
I am having problems with my Tascam Da-88 8 track recorder ! All channels recieve signals but when playing back only 1-2-4-5-6-7-8 play back ...chanels 3and 4 have crackling and distorted lower volume. My question is could the recording head use a good cleaning or is the recording head worn out for those 2 tracks?, thanks glenn
    Brigadier General:
  • 8,546 Answers
Maybe you could just clean the heads. If anything visible comes off they're TOO dirty. Or or look at it yourself with a strong light source and see the wear by evaluating reflections from the head surface.
Posted on Jun 01, 2010
Behringer connect
Try taking direct feeds from your 8 mic channels by connecting leads from the insert jacks to the inputs of the recorder. In order to not interrupt the signal path on the mixer channel push the jack all the way in and then pull out gently until you feel it click. Then you should get a direct signal going to the Tascam and still have control over the level via the fader.
Apr 01, 2014 | Behringer XENYX X2222USB Mixer
I have a DP2 Tascam 8 track recorder. Can I come out of my 16 channel mixer into my recorder and record my whole band?
The Tascam DP-02 can only record two tracks at a time.
You will have to mix "on-the-fly" and record the master out, or record each instrument seperately, and just record the drums as a stereo mix.
Feb 13, 2010 | Tascam Starter Pack for 4-Track Cassette...
I installed my tascam mk2.under Cubase LE4. Midi tracks work good.In "set-up devices" I see the Tascam inputs and outputs.Monitor VU-meter is not moving in this audio track and consequently there is no...
Have you clicked the little "monitor" icon (looks like a speaker) on the armed audio track so that it goes orange? Once on, you should see a signal on the VU meter (assuming the line in has a good signal etc). Once recorded, turn the monitor off again to listen to the track with all the others.
Jan 26, 2010 | Tascam US-144 Sound Card
Can I record on more than two tracks at one time? I realize I have eight imputs, but can I record each of those on an individual track?
Simple answer = Yes. Make sure you have 2 mics plugged in two separate selected channels/tracks, arm the tracks then record. It will record both tracks. You can record up to 8 tracks at once using mics, guitars, etc.
Oct 22, 2009 | Tascam 2488 Portastudio Multitrack...
Vocal effects on Tascam 2488 MK 2 portable studio
Hi again,
The easiest way to record using an external Lexicon effects unit (without an external mixer) is to connect your mic onto one of the 2488's inputs and assign that input to a channel strip (track). You should have the 2488 sends (output) going to the Lexicon's inputs. Then connect the Lexicon outputs back into another set of inputs on your 2488 and assign those inputs to two empty channel strips (tracks).
Then you will have to take that channel that has your mic input assigned to it and press send and set the levels there to send the signal out the sends (to the Lexicon).
Now you have a channel strip assigned to the mic input which contains your dry signal, and you have the two inputs returning from the Lexicon which contains your wet or effected signal.
You then have some options. You can control the amount of effected signal you hear while recording by adjusting the faders of the two wet tracks and you can either record the dry signal or the wet signal (or both) onto separate tracks.
Typically when recording the singer will want to hear an effect (say reverb) on his voice, but the engineer wants to record only the dry track at recording time (because effects can always be added later, but they can't be taken out). To accomplish this you would use the setup above, but only arm the mic input track for recording. In this way the singer hears the reverb, but only the dry vocals get recorded and the engineer can add reverb to that track again later as desired (and mix it back with the dry vocal etc).
On the other hand if you want to record only the effected signal you would simply arm the two channels to which the inputs coming back from your Lexicon are assigned for recording. This will get you a recording of the effected signal only.
Hope this helps you do what you are trying to do.
Cheers.
bd.
Aug 30, 2008 | Tascam 2488 Portastudio Multitrack...
How do I connect effects rack (Lexicon) to Tascam 2488 MK 2?
I've got a Lexicon too and I love the thing.
To use the Lexicon as a 'send effect' (which is what it is) you'll need to connect the effect sends from the back of the 2488 to the inputs on your Lexicon. Then connect the outputs from the Lexicon into two inputs on the 2488. Then assign those inputs to tracks.
You've got to select the previously recorded track(s) where you want to add reverb or other effects (by pressing the select key) and then press the 'send' key to get into the 'send effect' screen. Here you can adjust the amount of signal is sent from that channel to either of the effect sends (typically you might want to send one track of a stereo set of tracks out eff 1 and send the other track out eff 2).
Pre, post or off will determine whether the fader affects the signal being sent or not and the loop setting on the top of this screen is for the internal effects.
Once you've got this set up the way you want you just arm the tracks where the Lexicon output is coming into the 2488 for recording, mute whatever you don't want to hear and you can bounce record the raw signal through the Lexicon and record (print) the effected signal on the tracks you've armed.
Hope this helps.
bd.
Tascam 2488 Recorder
if the multitrack doesnt have built in effects you need to but an extrenal vocal effects processor that you can wire up to it. try lexicon products, they offer really good realistic vocal effects rack units.
Dec 26, 2007 | Tascam 2488 Portastudio Multitrack...
DA-88 tape problem
seems like you have a blank tape there.
Sep 03, 2007 | Tascam Quantegy 120 Minute Digital Audio...
Electronics - Others Logo
160 people viewed this question
Top Tascam Electronics - Others Experts
Glenn Mayer
Glenn Mayer
Computer Links
rjivaro
Are you a Tascam Electronics - Other Expert? Answer questions, earn points and help others
