Question about Logitech Cordless Mouse
Is there a battery compartment in the mouse?
The mouse is now constantly turning itself off and I need to push the connect button almost every 5 seconds. I am wondering what is wrong or if a battery slot is found somewhere in the mouse because I cannot find it.
    Problem Solver:
  • 8 Answers
If your mouse is the one in the picture, there should be a sliding panel in the bottom of the mouse. Flip the mouse upside down with the scroll wheel facing furthest away from you. Now place your thumbs on either side of the base where the bumps are and press/slide towards the ball in the middle. It should unlock and you'll be able to lift up the compartment door and find the batteries. They should be AAA if I remember correctly. Also make sure that nothing is blocking the signal to the receiver. A weak battery combined with this would equal your problem.
Posted on Jun 01, 2010
How to setup ge 99916 wireless mouse
Instructions
    • 1Hold the mouse in your hand, press down on the battery compartment cover (the back of the mouse) then slide it off.
    • 2 Insert two AAA batteries into the mouse. Make sure the positive and negative terminals match up with the diagrams inside the battery compartment.
    • 3
    • Replace the battery compartment cover.
    • 4 Connect the USB receiver to a USB port on the computer. The computer will acknowledge that a new device has been installed and you will be prompted to install the software.
    • 5 Insert the software installation disc into the optical drive. Follow the instructions provided by the installation wizard to install the software.
    • 6 Press the link button on the receiver, then turn the mouse over and press the link button on the mouse. The mouse is ready for use.
Jun 07, 2014 | GE Wireless Optical Mouse
PC recognize wireless mouse GE 98808. Install driver succesfully. Mouse not working
Check the batteries and the receiver,
You can remove the batteries for 2 mins. and put it back in, also you can try to restart the wireless receiver.
Feb 21, 2010 | GE Wireless Optical Mini Mouse 3087897985
Green light on USB for wireless mouse not constant/working
Look on the mouse itself or on the USB stick and see if there is a small button. Press the button once and see if the mouse respondes. If not push it again until the mouse starts towork. This will match or pair the USB reciever to the mouse.
Feb 09, 2010 | Belkin DBF8E825USB Mouse
Trying to add the Dynex wireless remote to my HP Notebook
Right below the scroll button there is an eject button. Push this and slide out the cover. You will find the battery compartment. Insert 2, AAA batteries. Be careful about the polarity. It is marked. Just match the polarity. In between the 2 batteries you will find the receiver unit. Slide this one out. Insert this receiver unit into the USB port of your laptop. Close the battery compartment cover. Turn the mouse upside down. You will find an on/off (on the right side top) switch. switch it to on position. If the mouse is not detected, press the connect button below the on/off switch. Good luck.
Feb 08, 2010 | Dynex Wireless Optical Laptop Mouse...
The batteries died on my cordless mouse. My
Make sure that the switch is turned ON after replacing the battery. If it's ON, try holding down the connect button on the USB receiver (that's connected to the computer) and then hold down the connect button underneath the mouse AT THE SAME TIME for 5 seconds and release them both.
If same problem occurs, make sure that there are no possible wireless interference near the mouse. Example, base of a cordless phone or a mobile phones. These devices' signal might interfere with the wireless signal of your mouse.
Thank you!
Dec 09, 2009 | Logitech S 510 (967555) (DH967555)...
Brand New Wireless GE Mini Mouse 98807 - trying to set up with brand new Acer Netbook. Light comes on mouse but will not sync with receiver.
I would suggest trying new batteries as well as making sure the receiver is about 8in to 12in from the mouse and at least 6in from the monitor. If you are still not able to connect, uninstall any drivers you have install for this mouse, reboot your pc and reinstall the software 1st, then connect the hardware and reboot your pc.
Good Luck
C2Solutions
Aug 07, 2009 | GE Wireless Optical Mini Mouse 3087897985
Logitech mouse needs constant resetting
I assume it requires batteries-have you replaced these?
Jun 18, 2009 | Logitech Cordless Mouse
Logitech cordless V220 Battery compartment - can not open.
push on the little button at the bottom of the mouse and slide the top bottom half of the cover toward you. The mouse require 1-AA.
negative of the battery towards the left click button.
Jan 30, 2009 | Logitech Cordless Mouse
Where's the battery????
If you consider the button and wheel side to be the front -
There is a silver oval button at the back of the mouse. Press it and the top of the mouse just behind the mouse buttons will pop open.
It takes 1 AA battery with the negative side going to the front.
Jan 12, 2009 | Microsoft Wireless Notebook Optical Mouse...
My USB plug in for my GE wireless optical mini mouse
There should be a button on the usb itself.You can try removing it plugging it back in then push that button if still red then you can try changing the batteries.
Dec 29, 2008 | GE Optical Mini Mouse ho98094
Logitech Cordless Mouse Logo
115 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
