Question about Canon Elura 100 Mini DV Digital Camcorder
My canon elura 100 stopped charging
I don't know if it's just the charger or adapter or if the camera is just broken. How do I find out what it is?
5 Suggested Answers
SOURCE: Canon Elura 100 Power Dead
Just an update.
I sent it back to the factory - and they fixed the power unit.
However, they told me that now my Memory card and memory card operations will not work.
They did not charge me for it - they took it under warranty.
Everything else seems to be working.
Posted on May 24, 2008
SOURCE: Camera won't record
Yes, solution #1 works! Thanks!!!
It took me a while to figure this one out but I finally did and mine is back to working perfectly. The problem: The Play option worked fine but the camera did not. When turned to camera mode the blue canon screen would come up and then freeze. The only way to turn it off was to remove the battery.
The fix: I was brave enough to take the entire outer shell off the camera. On the main board, underneath the screen/battery side, all the different parts are connected together. There is a single connector from the lens that had come out of its port. The ribbon connector must have somehow been shaken out of the port at some point. With needle nose pliers I carefully fit the ribbon connector back into the port. I carefully reattached the outer shell and everything was back working!
I will warn you that this task takes some time due to many many screws. It's a lot better than sending it off for hundreds of dollars though.
Posted on Nov 14, 2008
MNfisherman
  • 11896 Answers
SOURCE: card error
try to reformat the card either from camera or pc. If reformating doesn't work, then try a different card. Some camera's are touchy when it comes to the memory cards
Posted on Nov 12, 2009
arian07gapa
  • 62 Answers
SOURCE: Canon Elura 100 tape will not eject. Pops out but
stockk up inside..
bring it to repair shop!!
Posted on Apr 07, 2010
Don't acccept the tape. When I insert any tape one sound pip pip pip...and don't accept the tape.
try taking the battery out for afew min. mined did the same thing an i took out the battery an it fix it.
Jun 10, 2011 | Canon Elura 100 Mini DV Digital Camcorder
Canon Elura 100 will not turn on or take a charge. New battery does not help
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 18, 2010 | Canon Elura 100 Mini DV Digital Camcorder
Red "faulty battery" indicator with newly-charged Batteries
You can buy new batteries and buy the one it says to buy on the package.
Apr 09, 2010 | Canon Elura 100 Mini DV Digital Camcorder
Card error
Nov 12, 2009 | Canon Elura 100 Mini DV Digital Camcorder
Do not know how to use charger for camcorder its a canon elura 60
Turn the camera off and put the battery in and connect the charger you will see a red light blinking. when the red light is on steady the battery is fully charged.
Dec 20, 2008 | Canon DC10 DVD Camcorder
Canon Elura 60 won't power up
The same thing happened to mine soon after I got it. Turned out the plug I was using to plug it into the wall to charge had gone bad. The replacement was over $100 so I went with a (cheaper) wall battery charger that you conect the battery to.
Nov 09, 2008 | Canon Elura 60 Mini DV Digital Camcorder
Just an update.
Oct 23, 2007 | Canon Elura 100 Mini DV Digital Camcorder
Camera will not charge
If you know someone who has electrical testing equipment, they can test the charger to see if it is still putting out a charge. I doubt it is the battery because you said the charge light doesn't light when the unit is plugged in. Other than that, sounds like a bad component inside. Get it checked by a pro because you can get zapped or ruin something by poking around inside if you don't know what you are doing.
Jun 19, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Canon Elura 100 Mini DV Digital Camcorder Logo
61 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
