Unable to cancel closed caption feature even when following instructions
  • 666 Answers
You will want to look in the user guide for a factory default reset option and where to find it what I assume happened is someone has locked the setting menu and you may just need to look into a security setting preventing you or someone else from changing setup features
hope this helps
Robb
Posted on May 31, 2010
JVC model AV-32750..... The close caption feature is toggled on and a large black square is blocking picture. I have no remote to enter the menu settings so using buttons on bottom front. I am unable to...
just look in the section for closed captions----the box is the "text" feature and just needs to be turned off; if you did it without a remote it can be undone the same way.
SD TECH
May 13, 2011 | JVC AV-32750 32" TV
How do I enable closed captioning on my Zenith PIP System 3? Thanks.
Hello
To enable close cationing on your TV follow this:-
[1] Press "Menu" button on the remote control to appear "Setup" menu on the screen.
[2] Use "Up and Down" arrows on the remote contol to select "Captions/Text" on your screen.
[3] Press "Right or Left " arrows to select any one of the following options. Caption-1, Caption-2, Caption-3, Caption-4 Text-1, Text-2, Text-3, Text-4.
[4] Press enter to return TV viewing.
To turn the caption feature to "On" or "Off'
[1] Press menu key on the remote control to display "Setup" menu.
[2] Using "UP/DOWN" buttons to select captions on your screen.
[3] Press "Right or Left" arrow to switch the captions feature 'ON" or "OFF" or "EZ Mute"
[4] Press enter to continue.
Ok.
Oct 22, 2010 | Zenith C27A24T 27" TV
I have enabled the closed captioned feature on the suddenlink dvr and now I cnn not turn it off, please help
Hi - My name is Tina and I am with Suddenlink. Please see the following link on our Support site for instructions on how to enable closed captioning... To disable, follow the same steps, except choose "Disable or Off" (depending on your DVR. http://help.suddenlink.com/Television/Pages/ClosedCaptioning.aspx
Oct 06, 2010 | Motorola Televison & Video
My brand new Insignia tv has closed captioning that will not turn off. I followed the instructions in the manual but the menu item under settings can not be selected. Please helpw
You can use the TV buttons to get access to close caption by pressing menu. go to features make sure that cc when mute is on.
then use the mute button on your universal remote to toggle to cc1 or off.
May 21, 2010 | Televison & Video
How do i turn off the subtitles on my toshiba 36hf72 tv, without the remote
The subtitles in dubbed videos VCD/DVD the process to follow are :-
The closed caption feature has two options:
• Captions—An on-screen display of the dialogue, narration, and
sound effects of TV programs and videos that are closed
captioned (usually marked as “CC” in TV listings).
• Text—An on-screen display of information not related to the
current program, such as weather or stock data (when provided
by individual stations).
To view captions or text:
1. Tune the TV to the desired program.
2. Press MENU, and then press x or • until the CUSTOM menu
appears.
3. Press z or y to highlight CC.
4. Press x or • to highlight the desired closed caption mode, as
follows:
• To view captions, highlight C1, C2, C3, or C4 (C1 displays
translation of the primary language in your area).
Note: If the program or video you selected is not closed captioned,
no captions will display on the screen.
• To view text, highlight T1, T2, T3, or T4.
Note: If text is not available in your area, a black rectangle may appear on your screen. If this happens, turn the Closed Caption feature OFF.
To turn off the Closed Caption feature:
Highlight OFF in step 4.
Note:
A closed caption signal may not display in the
following situations:
• when a videotape has been dubbed
• when the signal reception is weak
• when the signal reception is nonstandard
PS: If you do not want to set these function & their commands can be entered via the buttons on the TV set. Using the remote is much easier to operate............ sodeep
Oct 08, 2009 | Toshiba 36HF72 36" TV
Can't get closed caption
Press the menu button on the front panel of the tv or the remote control. Use the up and down arrows to find the features section.Press the right arrow to enter the sub-menu for the features section. Use the up and down arrows to find the closed caption section. Press the right arrow to enter the closed caption sub-menu.Used the up and down arrows and the enter button to go into each of the features, use the right and left arrows to adjust each control for you preferred viewing.Press enter again to select the feature in each of the controls.When you are satisfied with you selections press menu to exit the feature. This information can be found on the PROSCAN website in the customer section under manuals. Go to www.oncorpus.com.the information can be found on pages 21 and 24 of owners manual for your model television.I hope this information helps you with your problem.
Feb 08, 2009 | Proscan 32LA30Q Television
Unable to stop closed caption
go to the menu of the movie and turn them off from there
Jan 23, 2008 | Televison & Video
DV2150 Close Captioning
Same problem here.
Instructions for DV2150 say you can access closed caption toggle by going to SETUP, then OTHER then CAPTION, but this (CAPTION) option is missing from the menu. I, too am struggling with the Jeopardy game buzzers, which I cannot program. Was wondering if the lack of "closed caption" is the reason
Dec 28, 2007 | GoVideo DV2150 DVD Player/VCR
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
