Question about Dewalt DG6000 Heavy Duty 6000 Watt Gas Generator
It ran when put away.about 6 month latter it wont start. gas from tank to carbuetor is ok and cleaned carbuetor bowl and not sure what to do
    Scholar:
  • 142 Answers
Check spark plugs.
Posted on Jun 16, 2010
Mower starts ok on choke but will not run.
Their's a bowl under the carb,has a screw under it.Empty gas tank or clamp gas line,the bowl has trash in it,remove bowl,be careful,their's a rubber washer their,remove bowl and discard gas.it will come out when you remove bolt,have rags their to catch gas,wipe bowl out and put back on and start it up and hopefully that was it.Best to use a socket to remove bolt,make sure air filter is clean and plug is too.your gas tank may have trash in it,to clean is run good gas in it and let run out of gas line.Uf you want you can add a filter in the gas line going to carb,Lowe's has them.When you remove bowl,the float will go down,easy to do.You may have to remove the air filter assembly to get to bowl.
Aug 01, 2015 | Garden
1996 Suzuki LS 650 Savage carburetor overflow
Hi, Jacob and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
8. Damaged petcock diaphragm allowing fuel to flow through the vacuum line into the combustion chamber.
9. Contaminated gas tank.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Savage LS650 dumping gas
Suzuki LS650 Carburetor Cleaning
Suzuki LS650 Savage Service Repair Maintenance
https://www.partsfish.com/page/oem-parts-for-suzuki
SUZUKI LS650P Owner Manual
Nov 14, 2017 | 1996 Suzuki LS 650 Savage
Ran outa gas now it wont run
Chech the fuel line/tank for blockage or foreign matter. Next check the car orator. B.
Aug 11, 2012 | Jeep Grand Cherokee Cars & Trucks
My Subaru backup generator won't start. It started fine last year and ran for about a few days. When I stored it I just shut it off and put it away, didn't add any additives or anything, now it...
you need to take the carburator off and clean it as well as the fuel tank,to start,maybe even a spark plug as well.always use a gas stable additive when you store it,better yet try to get in the habbit of running it once a month
Jun 12, 2011 | Coleman Powermate Subaru 5000W Portable...
Troy bilt mower ran fine then died and now it wont start back. It has fire and a new spark plug. It gets fuel past the filter. It starts if i put a small amount of gas into the intake. Whats wrong? My...
Remove the air filter and set aside.
Take a can of carburetor cleaner and spray the inside of the carburetor.
Let it set for a moment and then try starting the engine. It should run a few seconds. Repeat. When it starts squirt a small shot of cleaner in the carburetor to keep it running. That should remove the varnish the gas leaves as it evaporates over the winter.
If it still won't keep running then there is trash in the float bowl plugging the needle valve seat and the jets.
1) Turn off the gas or remove the gas line and plug it with a small screw or stick to keep it from leaking out of the gas tank.
2) Look on the bottom of the bowl for a nut .
3) Remove the nut and drop the float bowl.
4) Carefully remove the pin holding the float and needle valve assembly.
5) Take the carburetor cleaner with the straw it comes with and spray every hole in the carburetor to clean the jets . (up through the needle valve seat, down top of the carburetor , see a hole, spray it with the cleaner.)
6) Clean the float bowl.
7) Reassemble and make sure the gas isn't leaking and try to start it again.
Jun 06, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
Brand new 24MM MIKUNI CARBURETOR that floods out the bowl...
Carb's can be cleaned, hope you didn't throw money away on a new one for dirt.
You may have dirt in the gas tank getting to the carb. If you can, remove the bowl drain, (At the bottom) and see if there is sediment in it.(dirt)
Feb 11, 2010 | 2005 Honda CRF 150 F
After 1 season it ran great ,slowly died now it wont start
So many possibilities, so little data... <grin>
When you say "clean gas", do you mean that you added "fresh" gas, or that you emptied the tank, and refilled it with "fresh" gas?
Try this:
a. remove the "float bowl" screw, and put a regular "bowl" or pan underneath to catch ALL of the gas as it comes out.
b. if the gas is totally "clear", then it (probably ain't the gas), but... if it's "yellow", it's old and/or contaminated; alternatively, if there's any water (which may appear as a grey-ish liquid) then it's contaminated; also, don't forget to check the gas from your "storage" can, the same way...
c. re-install the the screw, and put some *FRESH* gas in the tank.
d. pull the spark-plug, and clean (or replace) it.
e. prime it, and crank it, and it should start right up.
Jul 03, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Wont start after 6 mos. I changed the spark plug, drained & added fresh gas, checked the fuel filter... Kicks over fine. Ran for 4 seconds, then it died. Always ran & started great before.
With a new plug and fresh gas it should start. Check to make sure there isn't a kill switch turned off or that the gas petcock from the tank to the carb is on.
How did you check the fuel filter? Disconnecting it from the fuel line that goes to the carb is the best way, making sure the gas is turned on under the tank. Bleed off a little gas into a can or something just to make sure the filter isn't plugged.
The last thing I'd do is take off the air filter and spray a little starting fluid in the carb. It may start and run several times if there is old gas in there somewhere. Remember the bowl on the carb is probably still full of old gas. After some fresh fuel reaches the plug it should start and continue to run.
(You might drain the bowl on the carb of ols gas before you go any further)
Sirwriter
May 22, 2009 | 2006 Honda Civic Hybrid
2008 Kawasaki Ninja 250R Wont Start
Gas in Europe ain't as good as gas stateside. But lets say the gas is okay. Got a fully charged battery? Put a 1 or 2 amp charger on the battery for an hour. Not starting yet? Check for a good spark on one of the sparkplugs.. Next check for water condendsate in the small bowl that makes up part of the petcock ( Fuel valve ). Dump the bowl then turn on the gas valve for a moment. Got gas flowing from the tank? If you have spark and gas and still no ride with the wind in your hair then shut off the gas valve and remove the drain screw from the carbs. Water may have collected there also. Still no go? Take it to a dealer, you have done what you can.
Mar 13, 2009 | 2008 kawasaki Ninja 250R
Dewalt DG6000 Heavy Duty 6000 Watt Gas Generator Logo
294 people viewed this question
Top Dewalt Electrical Supplies Experts
JOHN LAPIER
poellot86
Are you a Dewalt Electrical Supply Expert? Answer questions, earn points and help others
