Question about Thetford Norcold RV Cooler/Freezer
It has a nasty smell like diesel fuel in the freezer but it works fine.
  • 905 Answers
Your cooling unit may have a leak, and you are smelling the coolant, though normally this would be ammonia.
You may have food that is spoiling as well. Check the condensate / drip tray at the back of the fridge (inside). Look for water building up (likely green as well). If water is not draining, clean the hose that leads from the drip tray to the exterior back of the fridge. There will be a small evaporator cup / tray that the hose empties into. Check the end of the hose for insect activity. Note that it is normal for the end to be crimped, or it may have a plastic plug (perforated) inserted as well.
Posted on Jun 30, 2010
Mitsibushi pajero oil light time
White SWEET smelling smoke, or white OILY smelling smoke? If it's white thick SWEET smelling smoke, you have a blown head gasket - that's the smell of antifreeze burning in the engine, which it should NEVER do. If it's white OILY smelling smoke (smells a lot like diesel), then you're getting too much fuel into the cylinders.
If it's sweet-smelling smoke (antifreeze), pull the oil dipstick & check the oil level. If the oil level is HIGH and the oil looks like a mocha milkshake, that's absolutely conclusive - that's what happens when antifreeze gets into your oil, and it's nasty corrosive to engine parts.
I'm not at all surprised that the oil light is on if it won't start - you won't get much oil pressure until the engine is running.
Nov 05, 2013 | Cars & Trucks
Diesel fuel smell
see the diagram and test where is possible leak.
Jul 10, 2013 | 2006 Honda Accord
Turbo diesel dont want to strat
hve you run it out of fuel or changed the filter lately? diesels need fuel,air and compression to run.check your air filter too. that would not stop it from running but would produce nasty black smoke without load
Sep 25, 2011 | 2007 Ford F-150 Harley Davidson
Gas smell
This is a nasty problem with this car. It is the smell of mostly Sulphur. It comes when the Catalytic Convertor gets faulty. Replace it and get Smell-free. Thank you Sir, Have a nice day.
Sep 20, 2009 | 1999 Volvo S80
Nasty smell in garage.....think its coming from refrigerator
It's either the drip tray which is removeable from the front, or, mice are playing in the drip tray under the compressor. Soak in up, rinse with some ammonia water & repeat a few times. Rinse well when done. Line up some sticky traps behind the fridge. The mice found a playground amd they will return.
Mar 07, 2009 | Frigidaire FRT15B3A Top Freezer...
Freezer bad smell
the defrost pan is located under the frig. if there is a cover at the bottom on the front remove it and the pan should slide out
Nov 17, 2008 | Frigidaire Freezer Refrigeration White...
Strong Diesel Smell inside HJ Turbo Diesel Landcruiser
Since you didnt notice any change in the performance of your engine, ill presume there's nothing wrong with your fuel injectors.
look for moisture around your gas tank cap, the hose and clamps going down the tank, around the fuel gauge sending unit of your tank. have your fuel line checked from the tank to your fuel injection pump, give particular importance around the connections of your fuel filter, fuel pump, and the return hose from your fuel injection going back to your tank.
Diesel do emit strong hazardous odors that may stick on carpets inside your car.
Oct 11, 2008 | 1985 Toyota Land Cruiser
Car starts fine...but dosent run
ok... first question... the Tach(rpm guage) does change when you rev your engine in either P or neutral? Also.. is your check engine light on? any odd smells(burnt eggs) if your check engine light is on.. it's most likely a fualty sensor.. based on educated guess idle air control valve .. ot maybe posibly a faulty throttle position sensor.. if you have a foul smell.. similar to eggs or just nasty... could be a catalytic converter went bad... reply and lemme know if i help.. or raise new questions :D
Aug 23, 2008 | 1994 Volkswagen Jetta
Spoiled meat thawed in freezer, I cleaned the freezer but can't get rid of the smell.
thats a terible smell too if its a frost free you may have to take the inside panels apart and clean behind it also on the self defrost mod.their is a drain pan under or in the back that would have filled with nasty juices dan
Jul 15, 2008 | Refrigerators
Thetford Norcold RV Cooler/Freezer Logo
254 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
john h
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
