Question about Apple iPod nano
EVERY TIME I TRY TO UPDATE ITUNES OR UNINSTALL OR REINSTALL I GET THE SAME MESSAGE. IT'S LOOKING A FILE ''WINDOW/SYSTEM32MSIEXEC.'' ALSO ''OLD VERISION OF QUICK TIME CAN NOT BE REMOVED. CONTACT YOUR TECHNICAL SUPPORT GROUP'' AND THE INSTALLATION OF QUICK TIME DID NOT COMPLETE SUCCESSFULLY, ITUNE REQUIRES QUICK TIME.'' HELP!!!
  • 50 Answers
Go to the "Control Panel" of your computer, then "Add/remove programs". Look for quicktime and uninstall it from there. Then reinstall quicktime again.
Posted on Jun 01, 2010
I recently purchased the Ipad2 - I synced it with my itunes library only one time - when I try doing it again - my computer does not recognize it. Error -42408 comes on.
Check to see if you have the current version of Itunes via update If you do, then try plugging the ipad into another usb port, if available. If not update and then try. Turning all other applications helps Certain antivirus applications sometimes interfere You may need to uninstall itunes and then reinstall if the above tips fail
Aug 04, 2011 | Apple iTunes
It will not download itunes saying window error 2
Download the right file such as 32bit or 64 bit?
Uninstall all previous versions..
Feb 28, 2011 | Computers & Internet
Everytime i try to download itunes it freezing at
try uninstall old version then reinstall new version
windows vista
http://support.apple.com/kb/HT1923
windows xp
http://support.apple.com/kb/HT1925
one of the file my not being updated
also you can install itunes on a new user on you cpu and it will update all users !
Jan 24, 2010 | Apple iTunes
Itunes wont open and says cant find needed file?
hi
This usually happens when you have either renamed the file, moved the file somwhere else, or deleted it all together. Sometimes you may forget editing the filename or moving it to a subfolder.
Whenever you do this be sure to go to itunes and either add the file again and delete the old one from the database or "Get Info" and update the current file. tho u ve not mentioned any specific name of the file i m tryin to give u an example..suppose u are cant locate the music file m sure the files are where they are supposed to be then they must have been renamed. You can verify this - Find a track with an exclamation mark next to it
Open your iTunes Music Library.xml file with Notepad (the iTunes Music Library.xml file is usually in C:\Documents and Settings\YOURNAME\My Documents\My Music\iTunes).
Search for the track name
A dozen or so lines below the track name will be the full path to the file and the filename.
Compare this to where you know the file to be. If it is different then that would show that something/someone has moved/renamed the file. hope u will b sorted out wth ur problem... all the best regards.
Jul 15, 2009 | Apple iTunes
I have a classic iPod 80Gb. I have just loaded iTunes v8.1 onto my laptop using Vista home. When I try to ope iTunes the following message comes up:"The folder iTunes cannot be found or created and is...
Uninstall the egzisting itunes by following steps. Start menu> Control panel>click on the Control Panel home on the upper left side>same windows you will see the programs and under Unisnstal a program waith for list of programs refreshes highlight Itunes and press the Uninstall tab and reinstall the Itunes
May 01, 2009 | Apple iPod MA446LL/A MP3 Player
IPOD VIDEO 30GB WITH ERROR MESSAGE
I found this on the ipod forum on Apples website. See their site for any further assistance.
Sometimes you can resolve it by doing the following:
- Download the .exe file from Apple.com/iTunes
- Go to Control Panel > Add or Remove Programs
- iTunes > Remove
- Open C:\Program Files (default location)
- Find "iTunes" (default folder name)
- Shift + Delete > OK
- Run a registry cleaner, such as PC Tools Desktop Maestro, to remove all old shortcuts and registry keys no longer valid on your computer.
- Start > Shut Down > Restart your computer
- Run the iTunes install program
This should fix the problem, however may require also to update your Windows software (update.Microsoft.com) and download the latest Visual Basic Runtime executable. One time during my clean reinstall the iTunes software mentioned an error with a vb run executable and couldn't continue the install until I found it online.
Dec 30, 2008 | Apple iPod MA446LL/A MP3 Player
Error message 2330 when attempting to install/uninstall iTunes
You have most likely hdd errors and the programme to be uninstalled is fragmented or damaged.
Try running chkdsk/f as you are on the old system.
Jun 29, 2017 | Computers & Internet
Itune update and now it won't even open
try to uninstall the the latest version of itunes on your pc and then go back to what the version you are using. After that, update your old itunes, not install your latest version.
May 13, 2008 | Apple iPod MA446LL/A MP3 Player
Brother 5460cn won't scan to email,file,ocr,image
Brother Scanner error message.
After much time with Brother Tech support. The solution finally turned out to be as simple as downloading this file to reset the drivers.
http://support.visioneer.com/utilities/twain_reset.exe
Oct 14, 2007 | Brother MFC 420CN All-In-One InkJet...
Apple iPod nano Logo
77 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
