Question about Zephyr Elica Om EOM-M80A Kitchen Hood
I need to run my 7" venting 20 feet with 1- 45 and 1 - 90 elbows. Will this be acceptable or is the run to long?
  • 8,197 Answers
Yes that will be acceptable. You just can not have 4 at 90 elbows or anything that will make 4 - 90 elbows.
Posted on May 31, 2010
Where my dryer vent comes out of the wall and where the dryer actually vents from are offset about 3 or 4 inches left to right AND 3 to 4 inches up and down.
Your dryer vent is way too far to the exit. Look around and find an alternate. You are risking everything from poor performance to fire going 25 feet. Should be more like 5-7 feet max.
Mar 07, 2018 | Dryers
Powers on, then immediately shuts off. More detailed in comments below This is too aggravating!!!!!!! Characters characters
Hello Kathy: All clothes dryers work on the same basic principle...
1.) Air Flow
2.) Heat
3.) Rotation
Your problem may lie in your duct work configuration and how the exhaust gases are vented; the mere fact that you had blockage could have overheated the dryer's high limit thermostat and/or the thermal fuse...BUT, before I go any further...I need to talk to you about safety!
Gas dryers give off combustion gases that are toxic and DEADLY; DO NOT VENT YOUR DRYER UNDER YOUR HOUSE SLAB to the outside! Especially that you report that it gets WET inside that underground slab- it's against NFPA fire codes (municipal and state building codes, as well) to do that. If that slab ever collapses partially or fully, you'll have no way of knowing it and the toxic gases will back-up into your house.
The safer venting method should be done with 4 inch solid wall vent pipe; and should be vented directly outside. Maximum duct work (straight run of ducting without the use of any elbows) for your model gas dryer, is 65 feet.
If you are using 1- 90 degree, the total length reduces to 55 feet, including the elbow in that measurement
The use of 2- 90 degree elbows, 47 feet; for 3- 90 degree elbows, 36 feet, and for 4- 90 degree elbows, 28 feet- maximum length.
These are per your manufacturer's installation specifications.
Although you should not use more than 4- 90 degree elbows in your configuration, in the event you do, you would deduct 6 feet for each additional elbow used. You want to make sure that you can visibly see the vent pipe (to visually inspect it for defects or for ease of access to clean and service)- and never keep flammables of sorts near the vent pipe due to the heat that they radiate.
I choose solid vent pipe over foil or plastic (in my home, rental properties, and when I do installs) because lint does have a tendency to burn inside the duct work...which could lead to perforation and/or fire. Plus many manufacturers recommend solid vent pipe over other types; and I do not recommend using screws to connect solid vent pipe together with, since lint can catch on the exposed screw that protrudes into the duct. Use a combination of, heat rated duct tape and dryer vent clamps.
Some installers or readers of this will think that this is excessive, costly, and not necessary; through my life's experiences, I have seen unfortunate yet avoidable tragedies. (Don't forget to check & clean your dryer ducts at least once-a-year!- I do mine at the start and end of DST- the same day we change the clocks and the batteries on our smoke and carbon monoxide detector alarms.)
Now, concerning the rest of the troubleshooting process, are you getting any trouble code errors on the electronic panel? If so, what are they?
You have several choices, you can disconnect and remove the high limit thermostat and thermal fuse and check them for continuity or call tech support using their smart diagnosis procedures as outlined on page 35 of you owner's manual. Or you can disconnect the dryer at it's power source (outlet or circuit breaker) and wait a half hour; see if the electronic computer panel resets. Then try running the dryer.
Please let me know how you made out or if you need more help.
Mar 15, 2015 | LG DLE2240W Dryer
How do I eliminate Large quantities of lint in the dryer tube?
It's the length 30 ft. + 4 90 degree elbows.
the dryer just does not have the velocity/volume to discharge that far with (most importantly 4 90s).
4 90s at 10% reduction of flow = 40% reduction
at 30 feet add another 15% and your down to only
effective flow 45%.
replace 90 with two 45s drop of flow= 20% plus the run length 15% now you'll have a 65 % flow rate.
I do not know what appliance make and model you have, all differ so this is a basic guide but those 90s with the length are what is doing it.
hope this helps you.
Jan 27, 2018 | Whirlpool LGR8648 Gas Dryer
Is there a way to vent a basement bathroom without cutting into the cement foundation
What is in the room above the basement bathroom?
And how large is the diameter of the vent pipe you need to run?
Do you have a maximum number of elbows, and runs of feet maximum you can't exceed?
Is the Frame wall above the foundation, accessible by going up thru the ceiling of the bathroom, and the elbowing over and into the outrside frame wall at that point?-- and then up a ways, and then out thru the outside wall?
Another possibility would be: How far to a window, or vent already in the basement?-- Could you run the piping there, and then out?
How thick is the concrete wall?-- Is it reinforced Concrete-- or just Masonry Block wall? A block wall is not as hard to get thru--
I know I asked a lot of questions-- but maybe it helps you think thru your options?
Le4t me know if I can help further.
Mack B
Jan 29, 2011 | Fantech Fans Exhaust Fan In-Line
Max length and amount of elbows allowed in venting 4" hard pipe. I want to move the dryer to a new location
10 feet is the max .remember 1 elbow counts for 3 feet .
Check your installation instructions or go to a appliance store and find the installation manuel to check this
Nov 04, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Thermal fuse change on Kemore 970.c85042-00
First you need to know your dryer over heated and the thermal fuse tripped for a reason.
You will need to replace the thermal fuse, thermal fuses are there to protect the dryer. When you have the dryer apart clean all the venting and vacuum out the dryer. Look online for a parts supplier in your area, you will need your model and serial number to order the thermal fuse they are about ten dollars.
how long is the venting, does it exceed 20 feet, how many elbows. Make sure the outside hood is clean
May 05, 2008 | Kenmore 63942 Dryer
Zephyr Elica Om EOM-M80A Kitchen Hood Logo
132 people viewed this question
Top Zephyr Kitchen Ranges Experts
reliableservice
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
