Question about Garden
My trimmer cranks good and starts off running good. After about 5 and sometimes as long 10 mins it will suddenly start running 1/2 speed. I 'm guessing something is getting hot and causing it to miss fire? Any suggestions. Stihl model HS 45 trimmer
  • 86 Answers
The ignition coil is shorting out...it's a stihl thing...seen it too many times...get another coil...if it's new, it's under warranty (a dealership "must" repair to get warranty)...
Posted on May 31, 2010
2000 mazda protege kills and it wont crank back up for 10 mins
Have you checked for spark and fuel pressure while it will not start ?
Feb 09, 2013 | 2000 Mazda Protege
Engine stops running after about 10 seconds
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets, but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me,
Good Luck, I hope this helped
May 19, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Start's great at times,then won't turn over,starters good
yes the switch would cause that problem with the brake light but not the dash lights, these cars had problems with the ignition swith and the chip reader on the ignition, hope this helps.
Jan 20, 2010 | 1998 Oldsmobile Intrigue
Cleaned carb on echo headge trimmer how do i redo
It will depend on what type of carburetor you have. You can go to this website and enter your model and it should give you the correct settings. If you cannot find the info, start with each about 1 1/2 turns out and go from there. A little hit and miss and you will figure the correct setting. When setting the high speed, you want to hold the throttle wide open and slowly adjust the screw. It will suddenly start to run very smoothly, and that's a good setting for the high speed.
http://www.echo-usa.com/faqs.asp
Oct 24, 2009 | Echo Garden
Husqvarna 323L gas trimmer runs & starts great but looses power after 10-15 min and if you give it gas it dies. let it cool and it runs great for another 10-15min. trimm has less than 5 hours
You have a clogged gas cap. Try this: The next time you run your trimmer and it starts to die, loosen the gas cap. It should start running again. It sounds too good to be true, doesn't it?! Well, give it try. Clear the breathing holes form debris, or buy a new gas cap.
Jim
Jun 07, 2009 | Husqvarna 28cc Gas Line Trimmer
99 intriped, Drives great but will turn off at ramdom
when it cranks and does not run does it have spark?
Feb 01, 2009 | 1999 Dodge Intrepid
Garden Logo
699 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
