Question about Home
No instructions for a B&K Mueller 120-005nl single handle basin faucet, I'm not sure where all the pieces go
    Scholar:
  • 81 Answers
B&K does not supply install instructions with their faucets. A single basin faucet (****) is fairly straight forward. Ideally you will not use all the parts supplied by an import brand faucet. With plumbers putty, (feels like Silly Putty or Play-Do) work it into a worm looking rope about 1/8" in diameter and lay around the edge of the hole where the faucet goes and join the ends. Insert faucet into mounting hole and hold ti approximate final position. On the underside of the sink, first install the rippily flat washer (rosette washer) then the larger 6-sided flat washer (which is actuall a large flat nut) and tighten using a basin wrench. You should reconnect the water supply line to the faucet before the faucet is tight to the sink and make sure the opposite ent is free to turn. If the sink is still hanging on the wall you will need to have someone hold the faucet while you perform this procedure. I recall B&K supplies a flat rubber washer to go between the faucet and the sink but I personally think it's tacky looking.
Posted on May 31, 2010
How to remove moen bath faucet handle that has no set screws and is all 1 piece
1.) its not all one piece
2.) the tower threads onto the valve body, you may need to loosen the mounting nut under the sink top with a basin wrench to relieve the pressure on the handle tower
3.) this is the exploded parts view for your faucet: http://www.moen.com/shared/docs/exploded-parts-views/s498pt.pdf
4.) this is the instruction sheet for your faucet, including a technical support number you can call: http://www.moen.com/shared/docs/instruction-sheets/ins1207.pdf
Aug 26, 2014 | Moen Showhouse S498 Savvy Two Handle...
Single moen faucet base plate moves
The mounting nut below has come loose. Have someone hold it in position while you go under and tighten the nut. You may need a basin wrench to do theis.
Oct 28, 2012 | Moen 7065 Vestige Single-Handle Kitchen...
Fix b & K leak tub faucet
I think some super glue would work in my opinion
Jun 03, 2012 | B&K BK Mueller 122048RP Single Lev Kitchen...
Do not know what seris of Moen facet I have. The house was built in 1984. I have got water lines off underneath but can not get faucet it self off. Took out the screw and the ring screw and base ring screw...
If it is a single hole faucet, there should be a single nut on the threaded brass piece underneath the sink. You may need a basin wrench to get access to it if you cannot get to it with an adjustable jaw wrench. This nut normally clamps against a U shaped washer that is against the underside of the sink.
Mar 10, 2011 | Moen 87440 Single Handle Kitchen Faucet...
I just installed abrand new single handle delta shower faucet and the water does not get hot enough.
Many single-handle shower mixers have a hot limit, usually limiting the throw of the handle. You could go to the mfg's website (www.deltafaucet.com) & find instructions for adjusting it. Or, if you're handy, you could take off the handle & have a look; it shouldn't be too hard to see what's stopping the handle from turning more towards the hot side. Make changes in small increments & remember where you started.
Mar 01, 2011 | Delta & Single Handle Shower Faucet
I"m removing and replacing a
Since you are replacing the Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray faucet, bend the water supply lines out of the way, and then use a standard basin wrench to remove the nut.
Jan 25, 2011 | Delta Faucet Delta 470-BL-DST Signature...
After replacing seats & springs, no water will come out of spout. Sprayer works fine. Put old seats & springs back in & same problem.
need to put in little round ball back.. the right way..make sure ball is in right before putting hold down holding piece w notch in it
Nov 21, 2010 | Delta Faucet Delta 470-BL-DST Signature...
We have a single handle Moen kitchen faucet with the built in sprayer in the faucet. No hot water will come out and no water pressure in the hot position. Any ideas?
Check the cutoff valve under the sink to be sure it's fully on. If it is then the cartridge in the faucet may need to be cleaned or replaced.
May 24, 2010 | Moen 7437 Chateau Single Hole Kitchen...
Cannot remove Kohler ceramic valve
is this a single handle faucet. If not the part goes in under the handle
Nov 02, 2017 | Kohler Model 10433: Fort® Single-control...
I have a delta single handle kitchen faucet. It has shifted and is not centered. It is hard to move the handle to the left for hot water. How do I center it and tighten it back?
Loosen the retaining nut holding the faucet to the underside of the countertop/sink. Use a deep socket or basin wrench (http://images.lowes.com/general/b/bwrench.gif)
Straighten out the faucet and have someone hold it straight
while you tighten the retaining nut.
This problem may be a sign that the faucet needs some maintenance. You may want to read this as well:
http://www.fixya.com/support/t2480325-delta_single_handle_kitchen_faucet_pull
Aug 28, 2009 | Delta 2402 Classic Single Handle Kitchen...
Home Logo
250 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
