Question about Casablanca Fan 3245T Ceiling
Casablanca Delta II fan wobbles terribly at high speed. How can this be fixed?
  • 34 Answers
Use the balancing kit.
Posted on Jul 08, 2010
    President:
  • 1,099 Answers
Use the fan regulator to adjust the speed of the fan, and if it does not adjust the speed, then you have to replace the fan regulator.
Good luck...
Posted on May 31, 2010
How do you operate a inteli-touch casablanca ceiling fan
i looked everywhere,casablanca doesnt have anything but a picture,but,i eventually found this for you,dont break it,there are no parts being made http://www.casablancafanrepair.com/HTMLFiles/do_it_yourself/InteliTouchCommonRep/ReplaceElectronicsIT.pdf
May 28, 2015 | Casablanca Fan CAS 66668T Panama II...
I have a Casablanca slumber three delta ii that I want to get a light fixture to fit. Can I use a Hunter, or are there certain ones I need to use?
You have to use the bottom plate to attach the light kit to so whatever you get ,you have to be able to screw the two screws back on the fan. I have some older Casablanca light kits that will work without the bottom cap. fanman9952@aol.com
May 13, 2015 | Casablanca Fan Dryers
I have three casablanca fans in three rooms. An electrician installing electrical outlets, in the attic says he only accessed the main power line. However, all three fans suddenly malfuctioned in the
Are the fans all on one main line just for the fans and are they plugged into a GFI receptacle. If so you may have to reset the GFi or maybe your electrical box needs to be reset.
Jun 12, 2017 | Casablanca Fan Panama II 50" Ceiling
Ceiling fan stuck on high
The Inteli-Touch system does have a slight learning curve.
How the system works is. You turn the power switch on, and leave it on, all the time. To set fan speed, you press and HOLD the fan button and it will go. . beeeep. beeeeeeeeep. beeeeeeeeeeeeeep. beeeeeeeeeeeeeeeeeeeeep beeeeeeeeeeeeeeeeeeeeeeeeeeeeep beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep (higher pitched) when you reach your desired speed you let go of the fan button and it stays on that speed. So if you want to go to speed 4 you wait for the fourth beep and let the button go. To turn off the fan, press and release the fan button, to turn it back on to speed 4, press and release again. It has a memory. If you want to go to a higher speed while on speed 4 (or any other speed) just press and hold. To slow down the fan, you must turn the fan off by pressing and releasing the fan button, then pressing and holding until you get to the speed your desire.
The instructions which came with the fan should explain the rest. After you get used to using the IT control system, you will love it. I do. I have two Casablanca IT Victorian II fans in my living room. They are featured in this video. http://www.youtube.com/watch?v=2pv55wZqohs
May 20, 2010 | Casablanca Fan 6672G Panama® Ceiling Fan
Casablanca fan only runs at highest speed
When I turn on any of the fan speeds fan does not come on. When I remove the blades and turn on the ceiling fan on and give it a push the fan stays running. What could it be?
Aug 30, 2009 | Casablanca Fan Panama II 50" Ceiling
Casablanca fan speed problem
If this fan has a pullchain that also controls the fan speed, and you have a remote, the pullchain has to be set for the highest speed. If it is set at medium or low, it will mess with the remote operation. Note: usually high speed is the first pull after the "off" position.
Oct 27, 2008 | Casablanca Fan Bel Air 3811T Ceiling
This is actually a Delta II model fan. The fan blades and the ring they are bolted to recently dropped out of the fan housing and are sitting on top of the base of the light kit. Is this the flywheel? If...
it is the flywheel. I ordered one directly from the Casablanca web site, took the fan down and find the parts are pressed together. Looks like it needs some heavy tools or a jig of some kind. Any suggestions?
Jul 05, 2008 | Casablanca Fan 3245T Ceiling
Need a replacement fan speed potentiometer.
Okay -- first off, I don't know where she got that number from, but that's idiotic.
The variable-speed switch will provide different readings depending on where it's turned to. If the switch is busted ("open), it will typically display a reading of 'infinity' on your ohmmeter.
And yes -- the best place to find a replacement is Radio Shack, since Casablanca discontinued them.
HOWEVER---
Casablanca's variable-speed ceiling fans -- specifically the "SlumberQuiet" ones, which were made from circa 1980 or 1981 to the early/mid 1990s when variable-speed was discontinued -- are well-known for breaking down. The problem is almost never the potentiometer (variable-speed dial). Rather, the problem is almost always the resistor which is mounted in the heat-sink inside the fan's motor housing. There are NO replacements left for these -- so Casablanca makes a "variable-speed to 3-speed conversion kit", which will convert your fan to a more normal 3-speed pull-chain (hi-med-low) setup.
I hope that helps! If you have any other questions, please feel free to ask!
Jun 16, 2008 | Casablanca Fan Dryers
Casablanca Fan 3245T Ceiling Logo
302 people viewed this question
Top Casablanca Fan Dryers Experts
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
