Question about Dell Dimension 4600 PC Desktop
PC starts and goes to setup. Exiting setup starts
PC starts and goes to setup. Exiting setup starts a long series of beeps followed by a dianostic bar on bottoms of screne and windows starts.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 148 Answers
Hi update the BIOS though downloading from dell support site and load optimized default at the CMOS
Posted on May 31, 2010
  • 61 Answers
There is some hardware it doesn't like.
Black screen blue box saying
some one must have put in a boot password to your laptop,
follow this:
When booting up, enter your BIOS setup (usually by pressing the F2 key at the appropriate time).
Locate the BIOS Password section and turn the ON STARTUP password to off. There is no standard setup for BIOS, so I can't give you exact instructions.
If this does not work, try:
remove cell & start your pc you will here beep...beep...beep...
then turn off your pc & restore your cell.Start your pc and
password is removed.
there is a battery on motherboard,a button cell,you can try removing that and start computer, then put it back, bios settings will be lost.
you can also try removing any hardware like ram,if you have two,when system is off,turn on , it will prompt for changes , enter bios and try remove password.
Dec 15, 2013 | Gateway LT2001u Netbook
Loveno S10-2 - No bootable device found
Make sure your hard drive has higher priority in the boot options in BIOS. If it still doesn't boot then you will need to replace your hard drive. If it shows no hard drive in BIOS then the drive is most certainly bad and needs to be replaced.
Dec 02, 2012 | Lenovo IdeaPad S10-1211U Netbook
Mercury mother bord not loding satup manu with all f key and 'del' stop in start screen
1) Look at the bottom of the Mercury logo screen when it comes up.
2) Memorize or write down the -> enter BIOS Setup, or enter CMOS Setup key.
3) Restart the computer.
Let it go to Windows, then Start > Turn Off Computer > Restart.
Won't go to Windows? Hold down the CTRL and ALT and DELete keys AT THE SAME TIME. This will restart your computer.
AS SOON AS the monitor screen goes blank, (Windows is restarting), tap on the enter BIOS Setup key repeatedly.
Tap in 2 second intervals.
Hear a series of beeps? They are Stuck Key Error Code beeps, and you are causing them. Ignore the beeps.
Computer is off?
AS SOON AS you press the Power On button, start tapping on the enter BIOS Setup (CMOS Setup) key.
The enter BIOS Setup window goes by F-A-S-T. The above method/s will get you into BIOS Setup.
Regards, joecoolvette
Nov 05, 2012 | Computers & Internet
Hi i just switch my laptop aspire 6920 on and its start beeping and then its show me Intel UNDI, PXE-2.1 (build 082) Copyright (C) 1997-2000 Intel Corporation For Atheros AR8121/AR8113 PCIE Ethernet...
enter to bios setup and remove Ethernet controller from boot sequence or make it last on the list. and about operating system not found if you already use your system without problem then reinstall the system from a cd .
Jul 23, 2011 | Acer Aspire 6920 Notebook PC
I get 1 beeb followed by 3 beebs followed by 2 beebs then nothng happens dell diemension 8400
Your computer might emit a series of beeps during start-up if the monitor cannot display errors or problems. This series of beeps, called a beep code, identifies a problem. One possible beep code (code 1-3) consists of one beep, a burst of three beeps. This beep code tells you that the computer encountered a memory problem
you need to reseat your memmry modules just remove them and place them back in the same or a diffrant slot this cold be loose connection by connecting them again you fix it
------------------------------------------------------------ if you dnt know abt it see this it will help you
http://support.dell.com/support/edocs/systems/dim8400/sm/parts.htm#wp1052406
Apr 10, 2010 | Dell Dimension 8400 PC Desktop
I have a phillips 15NB57 series, model No. EAA-89 which came with vista. I have changed it to windows XP.However, I can not hear audio/sound except pictures only than before. What should i do?
  • These are the steps to setup and 'restore' the "Audio Drivers". Part (1) Click on the "Start" button, go to and click in the (right, pane) Control Panel. Scroll to find, "Ease of Access (or) Speech Recognition Options. Click, on" Replace sound with visual cues." In the See also: (Category), click, on “Audio Devices, and Sound Themes.” Click,' Playback', next, click on the "Active" speakers. Click 'Configure' to "Audio channels" The (Speaker Setup) "wizard", appear! Select (Test) click, Next! Follow the instructions. Part (2) Click 'Properties' change the "sound"(Level). Click on 'Enhancements', "Apply" changes. “The (Advanced), “not recommended!” In, the Controller Information (block), click on, Properties to "update" Drivers. Check to see if Device usage: (enable) if not? "Change it." *Note: Click "OK" to all change; 'Save' and Apply!, before exiting. "I hope this help Fix it"
Jan 25, 2010 | Computers & Internet
At start up, before windows loads, a consistent series of annoying beeping occurs....
If they're occurring right as you turn the computer on, it's your Power On Self Test (aka POST) letting you know. Since I can't be more specific, here's a synopsis of POST beeps:
One single beep followed by three, four, or five beeps -- System-board problems, possibly with DMA, CMOS setup chip, timer, or system bus. The computer usually won't boot when this is the problem.
Two beeps -- The POST numeric code is displayed on the monitor, usually nothing to be concerned about, but you might google the code on another computer and see what you get.
Two beeps followed be three, four, or five beeps -- First 64K of RAM has errors. Solution is to replace RAM.
Three beeps followed by three, four, or five beeps -- Keyboard controller failed or video controller failed. Either you won't be able to see or type with this error.
Four beeps followed by three, four, or five beeps -- Problem with serial or parallel ports, system timer, or time of day. Check your BIOS settings (usually F2 at start up) to make sure everything is correct.
Continuous beeps - problem with power supply. Probably won't do much with this error. At the very best, your computer will boot and run very, very slowly.
Hope that helped.
Sep 01, 2009 | Compaq Computers & Internet
Random series of beeps from Gateway 300C
How many beeps do you get, this is very important to your solution.
Nov 08, 2008 | Gateway 300 C PC Desktop
Dell Dimension 4600 PC Desktop Logo
76 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
