Question about Motorola Mobility i776 Cell Phone
How do I connect my bluetooth device to cell phone ? I have two different one's and neither would connect. 1. Samsung 2. Jamba devices
    President:
  • 1,469 Answers
To pair with another Bluetooth device follow the steps below:
Place the Bluetooth device in discoverable mode
From the Home menu screen , touch the Main menu tab, located at the bottom
Touch Settings
Touch Bluetooth
Touch Bluetooth On, unless already on
Touch Trusted Devices
Touch on the desired Bluetooth device
If prompted, enter the PIN, using the keypad (Default is “0000′ unless changed)
Touch Done
The handset will display “Connecting” followed by “Connected”
After a successful connection is made the handset returns to the Trusted Devices screen
Press the Home functions key to return to the Home menu screen
Try the steps yourself now.
will be expecting your comment.
Take care.
<a rel='nofollow' href='http://neverstill.com/openx/www/delivery/ck.php?n=aa90d9b4&cb=INSERT_RANDOM_NUMBER_HERE' target='_blank'><img src='http://neverstill.com/openx/www/delivery/avw.php?zoneid=25&cb=INSERT_RANDOM_NUMBER_HERE&n=aa90d9b4' border='0' alt='' /></a>
Posted on May 31, 2010
How to pair the bluetooth of samsung SGH-T429
Hy gcahig, follow the instruction (note :if my solution was helpful please rate the answer) :STEP 1. Locate the Bluetooth Settings Menu
To pair the handset with a Bluetooth Device follow the steps below:
  1. From the standby screen, press the right soft key for Menu
  2. Select Settings (9)
  3. Select Bluetooth (6)
STEP 2. Activate Bluetooth and Search for Device
  1. Select My Devices (2)
  2. Search for the Bluetooth device by pressing the left soft key for Select
  3. Press the left soft key for Yes to Activate Bluetooth and start the search
STEP 3. Pair with Selected Device
  1. Highlight the desired Bluetooth Device, using the navigation keys, then press the left soft key for Select
  2. Enter the Passkey "0000" then press the left soft key for Select
  3. The handset will display a brief message stating connecting followed by connected
  4. After being successfully connected you will return to the "My Devices" screen.
Source :
http://www.samsung.com/us/support/supportOwnersHowToGuidePopupPrint.do?howto_guide_seq=2765&howto_guide_step_no=1&prd_ia_cd=N0000003&map_seq=19095
Jul 13, 2012 | Samsung Cell Phones
Samsung c3050 mobile not connecting to bluetooth handsfree device
There probably is a special procedure for connecting the second device. Consult your user manual for the headset and be sure to follow the steps precisely.
Dec 17, 2011 | Samsung C3050 Cell Phone
I try to activate my sumsung3050 bluetooth it doesnt work. it telss me failed
if you are trying to pair our phone with another device ( not a mobile ) you may need to check the bluetooth version number on you device as different devices have different version numbers. If you are simply activitaing the bluetooth on your phone and are getting this message than its definately a software glitch. Reset the handset back up your data and press* 2 7 6 7 * 2 8 7 8 #
May 03, 2011 | Samsung C3050 Cell Phone
How to use my samsung wave as a modem
Two methods are there to use your phone as modem
1)you can use your PC suit to use your phone as modem You need PC suit software provide by SAMSUNG
To use your phone as modem *install the pc suit software *Open PC suit and select "Connect too internet" *if its failed you can use manual setting by selecting "Connect to internet">Select access point>select the name of network operator from the access point list(if you did't get your network operators name in the list you need to contact your network operators customer care they provide the access point name you need enter this access point in the manual updation list and try to connect now.....
2)you can use Bluetooth technology to connect to internet For this you need *Bluetooth on your PC and phone
To connect(in windows OS) *Click on Bluetooth symbol on task bar *Select add device select from device which can be connected to your pc list(set your bluetooth device to visible mode) *Add your device to your pc Add completion of the above...
*Again click on bluetooth symbol on task bar *Select "show all devices" *now select your device(one click) at this time 4 options appears on top your devices list *select connect using>access point
and 2nd method is *Again click on bluetooth symbol on task bar *Select "show all devices" *double click on your device *select connect to internet from the dialog box which appears after selecting the your device
Thank you
Jan 29, 2011 | Samsung Cell Phones
My samsung sgh-t139 cannot connect be found on bluetooth
To Turn Bluetooth On or Off
This option allows you to turn Bluetooth On or Off.
1. From Idle mode, press Menu ? Settings ? Bluetooth.
2. Make a selection and press the Select soft key or the OK button on your keypad.
My Devices
This option allows you to search for new Bluetooth devices. Highlight the Search new device option and press the Select soft key or the OK Button on your keypad. The phone searches for available devices.
Sometimes cell phones and bluetooth devices become problematic when trying to pair them together. If you've followed the directions correctly but are still not able to get them to pair, take them to your cellular company's store and let them pair the devices. They can show you step - by - step how to correctly do it.
Jan 26, 2011 | Samsung Cell Phones
How do i disable bluetooth on my SGH A561 samsung flip phone
To disableset Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to disable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Hope that helps..
Thanks for using fixya.....
Jan 08, 2011 | Cell Phones
My samsung s5230 bluetooth is not working
sir in your samsung cellphone the bluetooth device is failed.give to the samsung service center for changing the new bluetooth device..................
Dec 26, 2010 | Samsung SGH-S5230 Cell Phone
How to connect samsung tocco mobile to another samsung tocco mobile using bluetooth?
Turn on the Bluetooth wireless feature.
To turn on the Bluetooth follow the below steps,
1. In Menu mode, select Applications > Bluetooth.
2.. Select the circle in the center to turn on the Bluetooth wireless feature.
3.. To allow other devices to locate your phone, select Settings > On under My phone’s visibility > Save.
To connect other device to your mobile
1. In Menu mode, select Applications Bluetooth Search.
2. Select and drag a device icon into the centre.
3. Enter a PIN for the Bluetooth wireless feature or the other device’s Bluetooth PIN, if it has one, and select OK.
When the owner of the other device enters the same PIN or accepts the connection, pairing is complete.
After connecting you can start sending the files from one mobile to another mobile.
To send files follow the below steps.
1. Select the file or item from one of your phone’s applications that you want to send.
2. Select Send via or Send URL via Bluetooth, or select More Send via Bluetooth
Thank You
Aug 12, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
SAMSUNG BLUETOOTH PAIRING
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select (Serched bluetooth device) once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Dec 04, 2008 | Motorola Mobility Bluetooth Hands Free...
Bluetooth
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select SCH-a930 once a connection is detected.
Tips:
Jul 31, 2008 | Samsung SCH-a930 Cellular Phone
Motorola Mobility i776 Cell Phone Logo
104 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
