Question about Craftsman 29cc 4Cycle Straight Shaft Weedwacker Gas Trimmer ()
What oil do you use in the four cycle motor/ 29cc
I need to know what oil to use in my Craftsman 29cc 4 cycle motor.
Generally speaking, if there is a place on a gas-powered device that is labeled "gas" & a separate location labeled "oil" than you will need to use a 4-cycle oil for that machine. If there is just a place to put gas, you would use a 2-cycle oil; however, you would need to read the directions/manual to find out the correct proportion of oil to use, because you will have to MIX the appropriate amount of oil with the correct amount of gas, making a oil/gas solution that you would use for that specific device.
Posted on Jun 01, 2010
Why when I pull the cord, the trimmer doesnot turn
Will not turn if it is clutch driven. When motor starts and revs are up it will turn provided the clutch is working correctly.
Aug 30, 2015 | Craftsman WeedWacker Gas Trimmer 29cc...
What oil weight is used in the TB 575
If it is a 2 cycle motor, then use an appropriate 2 cycle oil. I use a synthetic oil that 1 bottle is mixed with 1 gallon of fresh gas.
May 09, 2014 | Troy-Bilt 29cc 4-Cycle Straight-Shaft Gas...
Stay running
The carburetor needs to be adjusted very slightly, with a special tool. If still under warranty bring it to the Sears repair center quickly before you damage the engine.
Jul 07, 2013 | Craftsman 29cc 4Cycle Straight Shaft...
Craftsman 4 cycle weed wacker throwing oil
check the oil and see if its over full the carb might be leaking fuel into the crankcase
Aug 08, 2012 | Craftsman WeedWacker Gas Trimmer 29cc...
316.794711 4 cycle blower dies/loses power
My assessment is you have bad piston rings and a large amount of blow-by.Hence the misting you mentioned. I am also going to assume you need to top off the oil frequently. Another sign of bad rings or even a cracked piston. Check your compression if you have a gauge as it should be around 30 to 50 PSI. If not then you need a rebuild. You should be able to get a replacement piston and ring set as well as the associated gaskets at Sears or many on line sources. If you are not equipped to break the engine down, a trip to the big box store with credit card in hand is my last recommendation.
Jul 04, 2017 | Craftsman Garden
I have a craftsman blower /vacum 29cc 4 cycle 425 cfm ? would like to know if you use 2 cycle oil in the gas or is this a gas only unit , second question is there is an oil port on the back of the motor...
Hi lindseyhpaint...
DO NOT MIX OIL WITH GAS ON A FOUR CYCLE ENGINE use gasoline only, the oil will go into the oil port on the back of the motor with an oil level line (crankcase).
You will need a good grade of 10W30 to use in the crankcase.
Please take time to rate me
Aug 30, 2011 | Garden
My 29cc 4 cycle craftsman gas trimmer loses power when I increase the throttle
While Holding the Engine at Full Throttle, Adjust the High Air Mixture Screw In Until the Engine Revs Properly.
Jul 01, 2011 | Craftsman 29cc 4Cycle Straight Shaft...
Craftsman 29cc 4Cycle Straight Shaft Weedwacker Gas Trimmer () Logo
481 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
