Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT WFW9200SQ/A it has code F21 coming up. I have owned this machine for a year and half, but just out of the blue this code came up - can't figure out what it means.
  • 15,935 Answers
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@@@@
Posted on Sep 28, 2010
ERER CODE 5D?
Whirlpool Duet Sport ht 5D/F21 Error Fix - YouTube
? 5:40
https://www.youtube.com/watch?v=2dV3FLzWPTM
Aug 6, 2013 - Uploaded by Mariela Gonzalez-Aroche
Steps in this video may be used to repair both F21 and 5D error codes. ... which is located on the bottom right corner of thewasher machine.
Nov 01, 2015 | Washing Machines
Whirlpool Duet wfw9250ww will not drain F9E1 code is displayed. How do I toubleshoot this?
F9E1 or F21
  • When users observe the F9E1 or F21 error code in their Whirlpool washer's display, it indicates a drain pump system error. The drain hose should be checked to ensure that it has been installed properly and not having a blockage.
Read more: Code List for Whirlpool Washers ' eHow.com http://www.ehow.com/list_7735284_code-list-whirlpool-washers.html#ixzz1wPUs4Ry6
May 31, 2012 | Washing Machines
Error code F-11
F11 Motor control unit internal failure MCU board failure or broken wire.
Check your wiring harness for a loose connection or a break in the wireaa6d6a5.jpg
Tech sheets for wfw9200sq
Jun 27, 2010 | Whirlpool Washing Machines
F32 comes up when we just installed our new Whirlpool Duet Washer WFW9200SQ.
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our wash machine will not spin after draining the water.
if this is really the old 9150 version then f21 is a ccu communication error with user interface. likely ccu is bad. 5d is not a error code.
bearings will make noise when out. unplug wait 1 min the reconnect power. If this doesnt work open top cover and check connections on ccu in rear. (unplug and replug). then buy new control. if your machine is newer duet (wfwxxxx) then f21 is different. (pressure sw) tech sheet on bottom front cover.
Apr 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F21 showing on screen
Take the bottom panel off of the washer and there should be a instruction guide in the washer that will tell you what the error code indicates.
Apr 01, 2009 | Washing Machines
We get an F2 error and the machine shuts off.
to long to drain,,,press pause/cancel twice..that should it ...happy new year
Jan 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport HT front load washer keeps having F21 Error
remove the lower access panel (3 screws along the bottom of unit) behind htere you will see the pump and an access to clean the pump filter, probably filled with assorted debris. be aware when you unscrew there will be water behind it,
Nov 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Plug off the wall. Close the wall faucet and check the hose & small screens on it. Open the faucet to see if the flow and pressure is good (keep bucket handy). Refit carefully, try machine. Code is nt seen anywhere as you said.
Jan 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT WFW9200SQ Ser CST50067K7 Power Problem
I have the same problem. Did you ever find the solution to this problem?
Dec 10, 2007 | Whirlpool GHW9200L Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
489 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
