Question about Pride Mobility Products Go-Go Elite Traveller 17AH Battery Pack
Loud clicking noise coming from rear wheel drive section
  • 177 Answers
Hi. Does it make a click about every revolution of the rear wheels? If so it is probably the square key in the axle that drives the wheels. Raise the rear of the machine on blocks, and remove the rear wheels. Wipe a thin smear of grease on the axle and key. then reassemble and test.
I have done this on many machines because of the noise. Just about all brands have this problem.
Good luck. Neil.
Posted on Jun 01, 2010
Loud humming noise coming from the rear/tires? of 07 pt cruiser?
Rub your hand over the tread and try and feel for cupping or uneven tread patterns. This will create alot of road noise. If not, have your wheel bearings checked.
Feb 21, 2018 | Cars & Trucks
Loud thumping from under drivers side that started with a squeal.
16 costly car noises - Bankrate.com
www.bankrate.com/finance/money.../16-costly-car-noises-1.asp...
BankrateYou should not ignore certain thumping, banging, clicking and squealing sounds. These sounds often rear their heads or intensify whenever the driver takes ... Hissing or sizzling under the hood: Heard when the engine is first shut off, .... my rear right wheel makes a loud bang when switching from park to drive/reverse.
Sounds coming from drivers side front wheel - AnandTech Forums
forums.anandtech.com > Social > The Garage
AnandTech
Dec 1, 2009 - 21 posts - ‎10 authors
Sounds coming from drivers side front wheel The Garage. ... slightly left, I get a slight metalish-squealing sound coming from the drivers side front wheel area. ... but before I start the wild and expensive goose chase of bringing it to mechanics I ..... Those twoloud clunks when turning hard right give it away.
Ford Explorer Questions - Thumping from front end - CarGurus
www.cargurus.com > Questions > Ford > Explorer
CarGurusDec 22, 2009 - Thumping from front end - I have a hard thumping noise coming from ... without problem then I'll take a turn or something and it will start. ... I just recentlystarted having a rubbing and thumping and squeaking noise in the right front sidewhen driving ... Thumping sound coming from under the truck 4 answers.
Car Noises: Consumer Reports - Consumer Reports Online
www.consumerreports.org/cro/...noises/.../index.htm
Consumer Reports
Feb 03, 2016 | Cars & Trucks
Growling noises and viberations coming from rear of 1998 honda crv when driving
You may have a bad rear wheel bearing. It would also be a good time to replace the rear brakes.
Dec 17, 2013 | Vehicle Parts & Accessories
When I am driving I hear a clicking noise. It sounds like it is coming from the rear of the vehicle
Hello, it wigit with his/here finger nail stripping the rubber of you tires in the back of you vehicle.
Is it a timely click that is unformed sound. Does the clicking intervals get louder with the speed increasing? It sound like a rear wheel bearing that out of grease. If it start squalling really loud. You will need to a new wheel bearing install. Don't let go to far it can out the wheel bearing and cause the particular wheel to come off. GB...stewbsion
Aug 26, 2011 | 2005 Jeep Grand Cherokee
Hello I have a 1999 Chevrolet Silverado 1500 2WD (2x4). While I am driving i have a loud thumping (flat tire sound) coming from the right rear. You can hear it as well on the left just not as loud. when...
Sounds like it might be a damaged rear end. Chock the wheels or put rear differential on jack stands and put vehicle in neutral then by hand turn the drive line back and forth and see if there is any loud noise when u do. There should not be a lot of play. if on jack stand you can also turn one of the rear wheels and see if there is any load noises or excessive play
Nov 28, 2017 | 2007 Chevrolet Silverado 1500 2WD
Back wheels make a loud clicking noise
Hi. Loud clicking noises from the rear wheels are usually caused by movement of the square steel key that fits into a groove on the axle inside the wheel hub. This is what drives the wheels.
You will probably get a click for each revolution of the wheels.
To fix it, remove the rear wheels and wipe a thin smear of grease on the key and axle, then replace the wheels.
The grease will allow the key to move slightly without making a noise, and help stop it from wearing.
It sometimes helps to also remove the front wheels, and wipe a thin smear of grease onto the front stub axles. There is no key in the front hubs, but the grease helps to prevent the bearings siezing on to the axles.
Good luck. Neil.
Jun 24, 2010 | Pride New Mobility Legend 4 Wheel Scooter
Noise coming from the rear end of my 2004 honda pilot it really only occurs during cold weather and after it warms up you hear it slightly
When does the noise occur, while driving only, or driving and idle, in gear, or in neutral and park? If it occurs all the time (while driving and at a stand still in cold weather) it could be the fuel pump. If it occurs only while driving, it may be a wheel bearing. Describe the noise (humming, grinding, whirring, etc), and what is the mileage on the Pilot? Answer my questions so I can fine tune my answer. Thanks!
Mar 18, 2010 | 2008 Honda Pilot
I hear a loud rumming sound towards the back under the body while driving. Sounds like its coming from the axle or tires. Tires are aired up.
First get your wheel balance checked .... Sometimes the balance weights come off !
If that checks out ok and the tires are good then I would be checking the rear wheel bearings.
Let me know how you get on.
Jun 27, 2009 | 1990 Dodge Ram
Pride Mobility Products Go-Go Elite Traveller 17AH Battery Pack Logo
986 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
