Question about Drills
The cable keeps getting tangled up, then it kinks. How do I keep it from getting tangled?
  • 8,404 Answers
If you can figure this out ... please let me know ... we will be rich!!!
I solved this problem by changing to a battery operated drill ... 19.2 Volts.
If I were in the market for a drill today ... I would be purchasing the lifetime guaranteed Rigid 19 Volt tool available at one of the big box stores or from the manufacturer.
Posted on May 31, 2010
One of the three colors I have been running keeps getting all tangled underneath but the other two run fine. I've tried adjusting tension, changing the thread to a different needle, and putting in a new...
Many machines are overly sensitive to different brands of thread! My machine, specifically, does not like the small and tall, tightly wound threads (that are "curled-looking").
Just replace that one spool with a similar color and have fun instead of frustration.
Feb 11, 2015 | Sewing Machines
Tip
Taming Technology Desk Organizers
Traditional desk organizers have helped keep all our paper clips and pens in order and under control, but with the onslaught of technology that has been taking over our desks all the cables have become another thing on our desks that need to be tamed. There are all kinds of tips and tricks like using binder clips to hold wires on the edge of your desk or getting cute little cable clips to keep wires from getting tangled or in the way. <br>Some new desk organizers are being made with all the technology in mind. Some starting at around $40 will keep all your daily desktop essentials under control including charging your phone and any other devices you may have laying around, and still have spaces for pens and paper clips like an ordinary desk organizer.
on Aug 25, 2013 | Office Equipment & Supplies
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
Stuck drain cable
Yes, any cable can be untangled. There are three vent holes in the drum big enough to get your hand into. Start pulling the twisted section out of one of the vent holes closest to the problem, un-twist it and pull it out the front of the drum where you feed the cable in and out. It may take a little time, but they can all be un-tangled. After you've removed the cable from the drum, you should be able to remove the kink with must your hands in order to straighten out the cable. These drain cleaners come with a 3.8" cable and are fairly easy to un-kink.
Jun 17, 2013 | Ridge Tool Company Ridgid K-400 Drum...
It keeps getting tangled up here the bobbin is underneath and keeps getting jammed
try changing the needle--make sure it's the correct one for the fabric
being sewed
rethread the machine ---using every thread guide
try using a different bobbin
try turning the bobbin over the other direction
clean under the needle plate and in the bobbin area for lint
also could be a timing problem and the machine would need to be
checked at a sewing machine repair shop
Apr 12, 2013 | Singer 3116 Simple
How often should I brush my dog?
I brush my own dog once a week and I got a short hair breed (American foxhound). Brushing loosens dirt and helps to keep the coat shiny and tangle-free. The brushing process also allows you to bond with your dog better.
Aug 15, 2012 | Pets - Others
E-6 is flashing, even after I have removed the tangled thread. What do I do?
try turning off the machine for a few minutes. and see if that clears it
if the E-6 still keeps flashing then the machine may have to be taken in to be serviced
Jan 24, 2012 | Brother CE5000 Computerized Sewing Machine
The cord keeps tangling. How can I keep this from tangling? I've tried stretching it, etc. but nothing works
The float/handle has a reversable position. You must periodically flip, change it so as to avoid this problem. I would reverse it each time I used it.
Jul 21, 2011 | Dolphin Maytronics Advantage
How do i put threed into the bobbin and keep it from not getting tangled?
Is it getting tangled while you're spooling the bobbin on the top right corner of the Singer 1507 machine? If this is the case, you have to pull the thread through the top tiny hole in the bobbin, and hold on to the thread end. Then click the bobbin to the right to lock it in place, power up your machine. Keep holding the thread as you begin spooling the bobbin. Let go of the thread once the bobbin starts to spin a few rounds and the thread should not get tangled.
Sep 29, 2010 | Singer 1507
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
