Question about Autotek Street Machine SM12D4 Car Subwoofer
Are is speakers good autotek sm12d4 - Autotek Street Machine SM12D4 Car Subwoofer
  • yadayada
    yadayada May 31, 2010
    don't understand the question, please clarify
  • 94 Answers
What kind of system are you looking for? heavy hitting? hitting all the lows or just a good sounding system?
Posted on Jun 07, 2010
Im trying to build a custom box for a sub. I have one 10in ss autotek 4ohm dual-core and i would like to cut out the right measurements to build a ported box. Can anybody give me the right measurements...
Down load a program call bass box pro and it's realy easy to use it will ask you what type of box you want then speaker specs after that put in the specs or the size of space you have to put it and it will automatically figure it for you and tell you program is all over the Internet
/uploads/images/im-trying-build-custom-box-sub-one-10in-34868166-4-1.png
Jan 13, 2015 | Autotek Car Audio & Video
I have two kicker cvr dual voice coil 4 ohms to a
what about the remote power wire from the radio? 2 channel or four channel(amps)? are the speakers running parallel or in series? are you using a mono block? or an EQ?
Oct 13, 2014 | Car Audio & Video
Amp light is green getting a base like heart beat nothing else fuses are good
The only thing I'm wondering is if you shorted out the RCAs somehow. Try switching the RCA's to another output on the back of the deck, if you have more than one set.
If that's not it...you will have to add pieces of the system one by one, starting at the deck, to see if you can troubleshoot the problem. Very Odd.
Good Luck
Dec 07, 2013 | Autotek Car Audio & Video
I got an autotek bts 7150 which is the positive and negetive speaker wires?
for stereo
speaker #1 (white = pos ,green = neg.)
speaker #2 (yellow =pos. ,blue = neg.)
for mono
white = pos., blue = neg.
Feb 22, 2011 | Autotek Car Audio & Video
Need specs on Autotek mx 1222- airspace requirements - sealed and ported enclosure?
If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long Box size will be 13 inches x 13 inches x 13 inches
Apr 02, 2010 | Autotek MX-1222 Car Subwoofer
STEREO SHUTS OFF BY IT SELF. IT IS AUTOTEK MM1400.1D what size fuse shoud be in it?it has two 40s in it now.
sounds like the protection circut of amp. check for solid ground and continous power from battery. Doed it get very hot?
Sep 17, 2009 | Autotek Car Audio & Video
Autotek Bass Thrust 44 Wiring
thin blue wire is the remote wire and goes to the deck remote line
large diam wire goes to battery
large diam "black" goes to ground
rca ... wires with the metal ends plug into the white and red holes
you have two sets of speaker wire comming off the amp also
hope this helps
Dec 11, 2008 | Car Audio & Video
Aplifier gettieng protection signal and excess heat
for that amplifier, it is recommended that you are driving a 4 ohm load. It can drive a 2 ohm load, but will produce more heat and shorten the life of the amplifier. Is the subwoofer a single or dual voice coil? You'll want to make sure that you're not running below a 2 ohm load or you'll always go into protection. Also, try disconnecting the speaker wire completely from the amp so nothing but power is connected. If the amplifier is still in protection mode when no speakers are hooked up, then the amp is bad and will need repair or replacement.
Sep 28, 2008 | Autotek Car Audio & Video
Autotek Street Machine SM12D4 Car Subwoofer Logo
134 people viewed this question
Top Autotek Car Audio & Video Experts
kli99gunrunn
Tom Chichester
FastHarley
FastHarley
Are you an Autotek Car Audio and Video Expert? Answer questions, earn points and help others
