Question about Intel D865GBF Motherboard
I have this motherboard and it won't post. The HD light stays on but does not appear to be spinning. I swapped HD's...same problem. I think the MB is bad. Any suggestions on what to check next?
  • 8,404 Answers
If the mother board will not complete the POST, (Power On Self Test) changing the drive will have no effect. You might want to remove all memory and check again ... your memory could be causing the problem. Remove all boards and attachments except mouse, keys and monitor of course so you can see what is going on.
If it will not POST, get another board.
Basics ... always go back to basics.
Thanks for your interest in FixYa.com
Posted on May 31, 2010
I have an 830GM and am suspicious of a hard drive crash or a motherboard failure and was wondering how to diagnose?
try replacing or swapping the hard drive with another machine and see if it happens again and on which machine if both machine's crash both MB and HD could be bad, If your machine with different HD works fine then it most likely was the HD If not then the MB might be at fault
Jan 24, 2011 | Gateway 830GM PC Desktop
Does not boot at all!
Did you check the power supply on another system to make sure it is operational. have you reseated all the connections to the MB..
Does it post any info ? are there any Beep codes?.. Or just sit dead . If it is sitting dead all I can think is that it might be a Power-supply problem but if it powers up or beeps or gives a green light or amber light on the MB then it is some other problem
Sep 03, 2010 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Dell Inspiron Vostro 530s won't boot.
I work for Dell, If the power button led light is flashing amber or amber (the Power supply is faulty) The Yellow light you saw inside the motherboard is the "Flea Light" (that is one way you could check if there is still power on the motherboard). Since the motherboard was replaced there are a few more things to check:
1. Video card (integrated or expansion)
2. Monitor (Make sure it displays self test feature when the cables are removed)
3. Monitor Cables (VGA / DVi)
4. Power Cable on the Monitor (try a different cable)
5. Power Supply (you already checked, but i suspect this is causing the problem)
Hope this helps.
Mar 16, 2010 | Computers & Internet
Computer does not post. Fans & lights on.
Good day sir, as you describe your problem, as I see it you forgot to replace your Power Supply box. Swap in a new one, see if it runs. Also make sure that your RAM is good.
Oct 13, 2009 | ASUS A8N32-SLI Deluxe Motherboard
Pc does not power on with hard drive plugged in
When you plug in the 2nd hard drive as a single drive does the drive spin up and the computer goes through the Power on self test (POST)?
If you cannot hear the drive spin up and the computer doesn't boot up then most likely the hard drive is faulty.
Feb 26, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Compaq evo 510 Won't power up.
Could be bad RAM modules. Try swapping out the RAM in the system with new RAM. Install one stick, in one slot. If it boots, that stick and slot are good. Try the stick in each slot to make sure all slots are ok.
Feb 20, 2009 | Compaq Evo D510 Minitower (Open Box)...
Replacement Motherboard (ASUS) P4S533
try using a bare system only means motherboard, psu, processor, ram then connect a speaker, does it make any sound ?
Oct 17, 2008 | ASUS A7S8X-MX Motherboard
No display at post
There are a few things that can cause no display on the monitor.
That single beep means POST = Power On Self Test. Post has tested everything on you're board to be good.
The cable between video card & monitor may be bad or not connected correctly (Swap out the cable as last resort).
2. You're monitor is defective, try swapping it with known working monitor.
3. You're video card is not functioning.
Lastly, when you reset the system cmos/bios everything went back to default. This means you're bios is now using the onboard PCI video graphics. Remove you're radeon 9600 video card. Try booting the system. You should see display again. The only way to test you're radeon would be to boot to the bios & set bios to boot using the AGP radeon. You need to change Init Display First to AGP & not PCI. If you loose video than you know you're AGP card is bad. Reset the cmos/bios before adding another AGP card or you will not get display. This setting is on pg 3-5. Integrated Peripherals. If you need you're manual you can download it from this link: http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF7-S2G&fMTYPE=Socket+A
Good Luck!
Mike
Jun 06, 2008 | Power Color RADEON 9600 (128 MB) Graphic...
No video
The only thing I can think of is that you are using a Video card as well as the MB has onboard Video & it has defaulted to onboard Video? If you have this.. then simply put your monitor on the MB VGA connection, NOT ya Video Card, and see if ya get Video, if ya do then go into the BIOS and set the default to your Video card. Ya be good to go..
Aug 08, 2007 | AOpen Motherboards: AX4SG-UN (AAX4SGUN)
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
Intel D865GBF Motherboard Logo
62 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
