Question about Brother MFC 210C All-In-One InkJet Printer
Will not send a fax
My brother mfc-210c will not send a fax the line will just ring until it finally disconnects
  • hoovernikeya Dec 02, 2008
    i can send or receive faxes it says something wrong with the line,poor line usage
  • 832 Answers
Http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc210c_all
Posted on Apr 08, 2008
6ya staff
SOURCE:
Need to hook up a brother MFC-210c so it can fax
Install the software (Brother MFLPro0 relevant to the printer. If you do not have the original CD download the appropriate suite from Brother Solution Center.
When you install the software you will be asked to choose USB, or Local Network. You can always install the USB and connect the printer to the calculator through USB. Different installations for different connection types (USB, LAN)
After you configure the software, you can open the Control Center 3 software and use the fax.
To be able to fax, you need to connect a telephone cable to the port marked line. After you do try pressing the unhook button. If connection to the phone line is correct you will hear the tone.
The MFC can fax without being connect to a computer, just the phone line.
Jul 30, 2012 | Brother MFC-210C All-In-One Printer
Change baud rate on brother fax machine
Lowering the Baud rate on Brother fax machines.
  • Press the Menu or Menu/Set key. Then Fax, Miscellaneous and Compatibility.
  • Press the Up or Down key until you can select Basic. Basic reduces the modem speed to 9600 bps.
  • Press OK or Menu/Set or Set key.
  • Press Stop/Exit.
Note these instructions should work for the following models: Fax-1835C, Fax-1840C, Fax-1940CN, Fax-2440C, Fax-2820, Fax-2825, Fax-2920, MFC-210C, MFC-215C, MFC-240C, MFC-3240C, MFC-3340c, and most other MFC models.
http://www.voipmechanic.com/voip-fax-settings-9600-baud.htm
Mar 06, 2012 | Brother FAX-8360P Plain Paper Laser
Change baud rate for brother fax
  • Press Stop/Exit.
How do you send a fax from a brother mfc 210c machine?
hi goes through below link and download the document and goto page number 43 .............. i think it will help you
http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000222/Mini2LowBase_UkEngUsr.pdf
Dec 17, 2009 | Brother MFC-210C All-In-One Printer
Can't send faxes
First disconnect the fax from the phone line. take regualar phone and plug into the wall outlet. dial thefax number. and listen for the the fax tone.
if the line is good. connected the fax and do the follwoing:
Manual Fax mode:
Press the fax icon (should turn green)
Load the document on the scanner glass.
Dial the fax number
press Mono Start.
if not, try to find a good phone line to use.
Feb 02, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210c printer
Check the basic settings for your printer to see if they offer 'manual' pickup of the line instead of only the number of rings. I've had the same problem years ago and had to set the fax machine for 6 rings, answering machine for 4 to allow me time to pick up the phone in case I was present. You should be able to find complementary settings with your two devices.
Sep 09, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Jim Keysor
ctnozil
