Question about Dirt Devil M084600 Dynamite Bagless Upright Vacuum
New belt keeps breaking - Dirt Devil M084600 Dynamite Bagless Upright Vacuum
  • 903 Answers
Hve you cleaned the gears and brush? There is probably dirt or debris binding something up inside.
Posted on May 31, 2010
  • 8,404 Answers
Beater bearings clean??? Check em ... make sure you have the proper belt.
My vacuum has no suction
what is the model number? is the motor running? it the brush under it turning? is there a broken belt? Is the cannister or bag full? let me know these things...thanks
Jun 24, 2012 | Miele Vacuums
Belts keep breaking
Check to make sure the brush runs freely before you try to replace the belt. The front brush bearings often become clogged with hair or strands of cotton and once this happens it becomes difficult to get it to rotate and then the belt will fail. Once you've removed it, unscrew the end caps and clear out all debris and then inject a small volume of oil or silicone spray and reassemble. This should fix the problem!
Jun 09, 2012 | Eureka Vacuums
The belt keeps breaking lately. I've had the
Before putting on the new belt make sure the brush turns freely and nothing is wraped around the bearing ends, if it is not turning free and is clean try a little grease or vasaline on the bearing ends. dont get any on the belt though. check the motor shaft also it should be clean and no residue from the old belts on it. it can be cleaned with rubbing alcohol and a rag, if really caked try a scotch pad .
Oct 24, 2009 | Kenmore Vacuums
Belt keeps breaking
in some cases when you by a belt from the brand stores the belts are not always to spec's. for example: you pick out the belt that's for your machine you go home and put it on and not even 5 to 10 mins. the belt breaks, thats because the spec's or not at the company's spec's and they break fast. take the same belt from the company and you will notice that the belt can be stretched alot more and is easier to put on. if you put on a new belt and it still breaks, first see if the brush or agitator can move freely. if not then the agitator needs to be replaced. ( fyi : the agitator end caps need to be taken off and cleaned for dirt or hair that gets twisted in there)
Aug 02, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
Why does the belt keep breaking as soon as I turn on the vacuum?
Hi Have you got the correct belt? If its breaking then the brush end caps or something is clogged. If you can get into the floor head ensure you look at the actual brush roll to see if there is anything is clogged or trapped. Remove all matter of dust and see if that works.
Mar 23, 2009 | Eureka 431A Optima Bagless Upright Vacuum
The belt on my oreck xl keep breaking
the brush roller is siezing up on you.try to take the brush roller out and clean it real good .pull the ends off and clean them to things get caught up and wrapped around them and keep them from turning.before you put the new belt on clean the motor shaft .usually when a belt breaks it leaves burnt rubber on the shaft .if you don't clean it the new belt won't last long.please leave feedback.i hope i was some help to you...pete
Dec 26, 2008 | Oreck XL2200 Bagged Upright Vacuum
Belt keeps breaking on dirt devil 85335
check and see if the brushroll still turns easy. if it doesnt, u may need a new brushroll which can be found on ebay, or dirt devil's website
Nov 23, 2008 | Dirt Devil M085580 Featherlite Plus...
The rubber band that turns the roller on the vacuum keeps breaking. I just bought a new rubber band, put it on, and it broke immediately. Can it be fixed?
Generic problem for all Vacuums
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I see there could be 2 problems – either your revolving brush has hair or thread buildup in the ends of the brushroll of which is causing the belt to break and would need to be cleaned out, or check the bearings on each end – they could be **** as well, or the motor shaft or motor assm is not tuning freely and in that case the motor should be replaced and it is not the belt – one other thing is to make sure the motor is in there securely. Once you get the belt on then roll the pulley and the belt together to make sure the belt is on correctly if the brushroll spins freely.
Apr 18, 2008 | Vacuums
Belts keep breaking
Check the brush roll ends to see if they have melted or frozen. They should turn freely, part #361869-1. Make sure the belt isn't being pinched somewhere.
Apr 15, 2008 | Eureka WhirlWind Litespeed 5844 Upright...
Dirt Devil M084600 Dynamite Bagless Upright Vacuum Logo
154 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Jim Parker
Jim Parker
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
