Will not turn on . started filled with water then shut off and will not power up now. it still has water in machine this washer is a little over one year old .
  • chrizzoclark Jun 01, 2010
    I don't know what model or brand??
  • 333 Answers
Sounds like the timer motor didnt engage. Soon as the fill switch activates, when its full, the timer motor advances forward and starts the cycle. Since the water stops when full. Then part of the switch is working. The one that is nc at same time the one that is no engages. Try advancing the dial couple clicks into the cyckle then pull back out.
Posted on Jun 02, 2010
F&P GW512 Will not stop filling
If the water continues to flow into the washer with power removed from the washer, ie; unplugging it, then the water valve is faulty.
Jun 25, 2016 | Washing Machines
My LG TROMM Hot water continually fills even after machine is turned off and unplugged. I have to shut off water supply to stop it.
Unplug the washer removing all electrical power from the machine. Turn the water back on and confirm that water is still entering the machine.
If the condition is true no power to washer and water enters machine it is very likely that the fill solenoid has failed.
this part is not that difficult to replace.
Water Inlet Valve part 5220FR2008F LG Washer Repair
Dec 31, 2015 | LG Washing Machines
My washer water never shuts off water runs all the time had to turn off the valve to get washer from filling up
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
I hope this has helped you,
Gene
Aug 04, 2011 | Roper Washing Machines
Water willnot shut off keeps filling
Where you connect the hoses on the back are solenoid valves, electrically operated. One of these could be bad (staying open) or the controller is bad and holding power on all the time. If it fills while the machine is unplugged, it's probably a bad valve.
Feb 27, 2010 | Washing Machines
Washer overflowed while filling for wash cycle.
A quick test to split up your possible trouble makers:
Let the washing machine fill with water and when the washer is about 1/2 full of water unplug the washers power cord from the wall outlet. If the water keeps flowing into the washing machine with the power cord pulled the fill valve ( where the hot and cold hoses are attached to your washer ) has mechanically stuck open and will have to be replaced. If the water shuts off when you remove it's power cord from the wall outlet, try plugging the washer in and out a couple more times and if the water stops each time the fill valve indicates as being good = on to the next trouble makers.
The water level control is responsible for shutting off the power to the fill valve and redirects the power to the timer to start the washing machine running once the correct water level has occurred. The WLC itself could be bad. The WLC uses a hose that the water level pushes air into to tell the WLC what the water level is inside the washing machine...the hose could be pinched, fallen off of the tub spout, has a pin hole, clogged up with calcium or soap curd and the WLC cannot "sense" or "tell" what is happening inside the washer.
Nov 27, 2009 | GE Washing Machines
Water won't stop filling washing machine.
Hi, Will the water shut off if you turn the timer off or unplug the washer?
If it shuts off when power is turned off to the washer, you need to look into the water level switch. If turning off power to the washer will not stop the water, you need to change the inlet valve.
Please let me know so I can assist you further.
Thanks
Vic
May 30, 2009 | Washing Machines
Washer won't stop filling
if you can turn the washer off while it is still filling. and the water continues to enter the machine you have a bad inlet valve.
Do me a favor turn the washer to fill, with the washer still running unplug from the wall. If the water is still entering the unit you have a bad inlet valve
Jan 05, 2009 | Roper RAS8445KQ Top Load Washer
Amana washer won't fill with water
1st I checked the power, compressor in garage had tripped the breaker to the washer circuit. This model has no bells or whistles to tell you if the power is on to the unit. Reset the breaker and unit works.
Thanks FixYa
Dec 22, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washer powers down during wash cycles
It is most likely a very slow fill problem ,either the cold or hot water supply is restricted and the machine cannot sense the right water temp. and will shut down .
Machine cannot wash properly with a small amount of water.
Ckeck ,the screens in the water valve or at the hoses at the top where the faucets are ,clean them or replace them but never leave them out .
Dec 17, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
LG washer comes on then shuts off
I need a little more info, does it make any sounds b4 it shuts off is there any codes F1 or anything like that. Does the water start to fill? Does it start to rotate or anything at all b4 it shuts off?
Oct 27, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
