Question about Kenmore 22932 Top Load Washer
Inner tub does not sit corrects and water is leaking bad when run
I just moved houses and our first load of wash floaded the laundry room. My wife then informed me that the inner tub was off center. As you look at the machine, the tub is tilted toward the front right corner, as though it is not sitting properly. I have detached the front. All the hose are still secure, the springs are all attached as they should be, and there is no noticeable fracture of any part of the frame. I am a newbie to self-repair work, but would like to diagnose and fix the problem instead of calling a repair man. Any thoughts on what the problem is and how I can fix it? Thanks
  • 333 Answers
There is 6 springs? And all of them are on right? Sounds like one of the back springs came off or broke. You should be able to shake the whole thing around and it should center up. Take the top of the washer off. Remove the cover on the control panel then unplug the wire harness and pull the fill switch hose off of the switch. There is two screws holding the top on at the side panels in the front. then lift it up and slide it forward to release the back hinges. Then you should be able to see the back ones.
Posted on Jun 02, 2010
Leaking into wash tub
The water inlet valve needs to be replaced. It is not sealing.
Here is a link to the part you need.
Aug 13, 2012 | GE Profile WPRE6100G Top Load Washer
Magkakatuluyan ba kami ni shelumiel
Instructions
things you'll need:
* Laundry detergent
* Clean cloths
* Measuring tape
* Plywood (if necessary)
* Wrench (if necessary)
1.Verify that the Kenmore top-loading washing machine is completely plugged into a grounded, three-prong power outlet. Reset the fuse or circuit breaker, if necessary; do not plug the washing machine into an extension cord.
2.Make adjustments to the feet on the washing machine if it is shaking or vibrating. The front and rear feet must all be touching the floor evenly. If the floor under the machine is flimsy and cannot adequately support the washer, set a 3/4-inch piece of plywood under the machine for better stability. Load the tub evenly when placing items inside the washing machine and do not overload the tub.
3.Examine the washing machine drum, including between the inner and outer basket, if the machine is clicking or rattling during use. Remove loose objects from inside the drum. If objects are caught between the drums, unplug the washing machine and pull the items out with a pair of pliers, if possible.]
4.the fill hoses behind the washing machine if there are water leaks and ensure the drain hose is connected to a laundry tub or drainpipe. Look at the plumbing throughout the home for drainage problems and correct as necessary.
5.Turn on the water valves behind the washing machine and clean the water inlet hose screens if the water is not running or filling. Do not overload the tub, and use only high-efficiency (marked HE) laundry detergent in high-efficiency Kenmore washers. Note that energy-efficient washing machines often use less water than other machines; this is normal.
6.Choose a wash cycle with a higher spin speed if the water is not draining as expected or items are extremely wet when washing is complete. Reduce overall load size and select a new drain/spin cycle to remove the extra water from the washer. Ensure the drain hose is properly installed on a drainpipe or tub and is not set more than 96 inches above the floor.
7.Reduce the number or volume of items inside the washer tub if the clothes are not rinsed when the cycle is complete. Verify that the water valves are turned on and the correct type and amount of laundry detergent is used.
Mar 12, 2011 | Kenmore 22422 Top Load Washer
I have a Maytag Atlantis top-loading washing machine, which was in a flooded laundry room while I was away on vacation. The flood came from "above," so the washer filled up with water. Now it...
It does seem that in your case it would be cheaper to by a new machine.but you can look up the parts if you want to at www.searspartsdirect.com and price them yourself.the motor runs about 130.00 dollars and the transmission if needed runs 253.82 dollars.the tubs run about 130.00 dollars each
Mar 01, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine leaking water from underneath
It is possible it is just a loose hose or it could mean your trmp or the tub itself is leaking. I would try going to the back of the machine and take off the bottom panel.and take off the back panel. After removal start it and observe where the leak is happening.
Jun 14, 2017 | Estate ETW4100SQ Top Load Washer
Two speed auto washer - found water all over floor - no leaks on any hoses or drain. Wife said last load was unbalanced and machine was rocking around bad. Tub seems very wobbly to me when I move it...
having a very unbalanced load can cause the water to go over . yes the tubs are supposed to be able to move around some.run a load with no clothes in it if it leaks then you may have a more serious problem
Jul 26, 2009 | Whirlpool LSB6200KQ Top Load Washer
I just did a load of laundry at my mom's beach house. Second load so far is fine, however, first load seemed to leek from underneath. All water/drainage connections were dry. We moved and cleaned area and...
If all connections were dry, the water may have overflowed the top of the tub during a spin /rinse cycle. That could happen if there was a lot of water (i.e. set for large load) and a small amount of clothes.
Jul 08, 2009 | Washing Machines
Leaking water
Does not sound like a bearing problem. Check to see if water is overflowing the top of the tub during spin cycle (due to spin action) and running down the side of the tub.  Water rising up the side of the tub during spin cycle could also be squirting up through bleach dispenser opening and running down side of tub.
May 30, 2009 | Washing Machines
Washer Shaking Violently on Spin Cycle
Yes, there is...The legs on the washer are adjustable, the rear legs are often ( not always ) self adjusting, make sure the legs are not stuck and that they can move freely. But the front legs can screw in and out to move the washer depending on the floor the washer is sitting on. Make sure the washer is as low to the floor as possible. When the legs are screwed out too far the washer becomes wobbly. Often on the metal style legs there are lock nuts that can be tightened to secure the legs so they don't move on you. washers where really meant to sit on a cement floor, if your washer is on a wooden floor look carefully at the strength of the floor. If the floor is moving up and down when the washer is running, the floor may not be strong enough to support the washers weight. Most main floor laundry rooms floors are nailed down, the sub-floor is more secure if the sub-floor has been screwed down. Sometimes extra support may have to be added under the flooring to add some strength for leaking issues Check the easy stuff first, fill hoses tight?- drain hose cracked?
Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
Nov 24, 2008 | Maytag PAV2300 Top Load Washer
Something chewed up
What you have is called spider failure. This is the three spokes that connect the basket to the spindle. The plastic is shavings of your tub.You need to get the rear of the tub replaced and the basket replaced.
Sep 18, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Tub is leaking
You could have a crack in the pump housing. Take the back panel off the machine and run a small amount of water in it, then turn on the spin cycle and see if you can see any water spraying from the pump itself. 20 yrs is not unreasonable for most older models.
Mar 11, 2008 | Washing Machines
Kenmore 22932 Top Load Washer Logo
82 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
