Turn on tv ,all i get is a fast popping noise
  • 8,617 Answers
Sounds like the flyback is bad or the hv lead needs to be re dressed. Whats the model number?
Posted on Apr 09, 2008
What might be the problem with tv making popping noise when turned on
you must have a wire ( sound plug ) not connect properly ,
sometime those plug loose with time ,
when powered the make connection and those sound happen !
Apr 05, 2015 | RCA L32HD31 32 in. LCD HDTV
I replaced three cans. they were bulged on the top. i plugged the tv in and it did the same thing. i said it blinks 4 times fast but it is only three. blink code says 3=RESERVED. i pulled the the y-sustain...
Philips lists 3 models of your TV:
1) 50PFP5332D/37
2) 50PFP5332D/37B
3) 50PFP5332D/37E
User Manual for your TV (actually for the 50PFP5332D/37E):
http://download.p4c.philips.com/files/5/50pfp5332d_37e/50pfp5332d_37e_dfu_aen.pdf
The user manual doesn't document the logic board blink codes for errors.
What this tells me is that the TV went thru two revisions before reaching version E.
in case it helps: Philips Customer Support: 1-888-PHILIPS.
If they can't help otherwise, they can at least tell you if your set is eligible for warranty service.
Mar 24, 2011 | Philips 50PFP5332D 50 in. Plasma...
Samsung UA46B8000XY TV partly flooded making popping noise. Water reached 50 mm up screen. Dried out for a week. At turn on the display works but then turns off and get popping noise..
You have severe damage in TV. the power supply part and circuits board were get problem. Please check carefully the defective parts inside TV. And get repaired at repair shop or dealer is better options
Regards
Jan 24, 2011 | Samsung Televison & Video
RCA HD50LPW164 turned on TV made a pop
the loud pop you heard was probably a capacitor blowing its top. The grinding noise is likely high voltage arching that was occuring due to rising voltage since capacitor isn't there to smooth it out.
Nov 02, 2009 | RCA HD50LPW164 50" Rear Projection HDTV
No picture on my sony kds-50a3000 red blinking light at lamp spot
If by noise, you mean a loud, audible pop--then it's your lamp that imploded.
You should be able to just pop off the cover on the side (right side if you are facing the front of the set), remove the internal lamp cover (if present) and yank (I mean, gently pull) out your lamp.
Look for all the bright particles of glass inside your newly imploded lamp. Replace with a Sony original, as these sets can chew through generic lamps very fast.
Now, if by noise you mean something else, please elaborate.
Jul 30, 2009 | Sony XL5300 Replacement Lamp for XBR2 SXRD...
Tv went out after loud pop and has clicking noise does not turn on
If you have a Sony DLP, then the loud pop you heard is your lamp.  The lamps last approx. 4K-6K viewing hours.  Read your manual for replacement part number to reorder and very simple to replace yourself.
Apr 22, 2009 | Televison & Video
Sony Bravia XBR-2 32-inch LCD with popping noise problem
Unfortunately, we have the same problem. We hear popping and our sound goes lower. It is not the cable box for us, it's definitely the TV; however, it happens, on our set, after its been on for a few minutes and then goes away after half an hour or so -- however, this evening its been happening for the past hour and the TV has been on for the evening.
Jun 10, 2008 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Has anyone heard of something like this where the cable box/service is causing popping sounds? yes & it is common problem. And is this something I should be concerned about causing damage to the TV's speakers? not at all. The Sony tech-support representative (over the phone) diagnosed it further to a problem not with the TV but with the cable box/service because there were no popping sounds when I played a DVD on my Playstation 2 that is attached to the TV. they are right that your problem is not due to tv. it is due to cable box/service? yes but not defective it reqires to change the way you have connected tv to cable.please call tech to get it connected in such a way so that you do not get popping sound when you you put off cable box.
Sep 23, 2007 | Sony FD Trinitron KD-36XS955 36" TV
TV won't power up. I herd a popping noise and now the TV won't turn on.
A popping sound can be a good thing because it will be easy to identify a blown up or degraded component,if you are familiar with tv service you might spot the bad part fast just by looking at it and then change it,sometimes you actually have to check a component with a meter to tell is gone bad,check the main fuse ,it should be close to were the power cord comes in,if is black you will have bad components ahead and you will need the assistance of a servicer,if you are not too familiar be safe and call for help.Let Us know how it goes.
Oct 10, 2006 | Hitachi 50UX57B 50" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
